Like Tree3Likes
Old 08-08-2014, 08:17 PM   #41 (permalink)
I just did this to my DX9 and Taranis and it's so smooth. I went to Joann's fabrics and bought the teflon pressing sheets. Thanks for the tip!
___________________________________________
DJI Naza F-450, Blade 450x, 130x, Kalt ZR, Trex 450x, Trex Sport, MSR, MCPX, MQX, Dynam Sbach 342, Stinger 64, Sky Angel Rare Bear, EF-16, Edge 540QQ 280, DX8
minizoom is offline        Reply With Quote Quick reply to this message
Old 08-11-2014, 12:10 PM   #42 (permalink)
Default Spektrum TX Teflon Smooth Throttle Mod
Thanks guys. Just did this with my DX8 and the throttle/collective stick is smoother now. Excellent simple to do mod.
Lanman is offline        Reply With Quote Quick reply to this message
Old 08-12-2014, 05:33 AM   #43 (permalink)
I do not want to piss on anyones parade in here and the teflon tape looks like a great mod but I just do not understand what the fuss is all about in the first place. Why do so many of you have the sticky throttle?? I bought DX18 over a year ago and immediately opened the case, cleaned thoroughly the factory grease with contact cleaner spray and applied the Tri-Flow clear synthetic grease onto the spring and the throttle plastic half moon. Have not re-greased since and the throttle, adjusted to the right tension has been smooth as butter ever since. To me and reluctantly admited by my friend even smoother than on his $3k pride and joy Futaba18MZ!!!
mmarian is offline        Reply With Quote Quick reply to this message
Old 08-12-2014, 06:33 AM   #44 (permalink)
The fuss is a sticky stick. I've tried the same grease as you, and unless I left my stick looser than I prefer, it had stickiness to it. The beauty of the Teflon mod is that you can add tension while maintaining butter smooth movement.
Goblin Thunder Sport | XL Power Specter 700 | Synergy 516 | V Control Host of Full Pitch RC Heli Podcast My Youtube Channel
jimmy77611 is offline        Reply With Quote Quick reply to this message
Old 08-12-2014, 11:33 PM   #45 (permalink)
Yeah, I get it but I never had any of the problems described here since I put the Tri-Flow there whilst the radio was brand new. Maybe the DX18 is a bit different? I do not know but I am perfectly happy with the way the stick moves on this radio even when compared to the best radios out there. No signs of stickiness at all. Maybe I am just lucky :-)
Old 08-14-2014, 02:46 PM   #46 (permalink)
Thanks jimmy77611 for a great solution to a :sticky problem". I happen to have a sheet of material on hand which I use with my T-shirt transfere press. It is light brown in color and a woven type material which is extremely slick and is 0.005" thick. I cut a strip,used heat shrink as per your photos and now my DX6 has a great feeling Throttle stick. Now I can do piros without moving the collective and having the heli either go up or down unintended.
mS/R --3ea. mCPX 2 converted to BL 4ea. mCPX BL 2ea. BL-130X
400 FBL ,.Blade 450X ikon Blade 450X with Ar7200BX
Blade 300X MIcroheli CF frame many upgrades 230S , LOGO 690 Brain / HD , Trex 450 Pro with Brain ,planks...
everydayflyer is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 05:46 PM   #47 (permalink)
I too had the same thoughts as you about my own DX18 having a pretty good stick, but anyway I decided to give a go on this teflon mod as it was too simple to be done and wow.... I have never looked back ever since.
CZorzella is offline        Reply With Quote Quick reply to this message
Old 08-18-2014, 06:56 PM   #48 (permalink)
This was the only way i could get my throttle tight enough for me.
Fusion 480,OMP M1/M2,600N,lots of Planes Powered by NX10 AMA 33 yrs.
Old 08-20-2014, 06:34 PM   #49 (permalink)
Did the mod today. It's smoooth finally!
Horizon needs to read this thread.
Thanks all for sharing this mod
ryahelg is offline        Reply With Quote Quick reply to this message
Old 08-20-2014, 08:40 PM   #50 (permalink)
Did the mod today, butter smooth!
Old 10-23-2014, 03:41 PM   #51 (permalink)
Thumbs up
Thanks great idea !
I will try the plumbers tape first.
Terry
rigdent is offline        Reply With Quote Quick reply to this message
Old 11-02-2014, 05:54 PM   #52 (permalink)
I just wanted to say thank you to all who have contributed to this thread. It applies to more TX's than just Spektrum, I just did it to my FrSky Taranis
I had previously slipped a piece of fuel tubing over the throttle tension spring/band. That, plus a bit of grease, made it feel MUCH better than stock. But the grease eventually wore off, and the feel became worse. When I opened it up tonight, I found the fuel tubing actually had a small section worn away, like a little divot in the tubing where it rubs.
I wrapped some teflon film around the fuel tubing, and the feel is fantastic I held the film in place with heatshrink at both ends. I'm hoping the teflon will last longer. If I wear it out, I'll replace it, and use more wraps next time.
I did want to share my source for the teflon film. I bought a 12"x12" square for $3.55 including shipping from eBay, the seller is trueseals .
This is the auction link:
http://www.ebay.com/itm/171461726490...%3AMEBIDX%3AIT
The film is smooth, not textured, which is what I wanted. It is 0.005" thick. Heck, I bought one sheet, and there were 2 sheets in the package! Great seller.
Old 02-08-2015, 11:20 AM   #53 (permalink)
For the Teflon mod I used this adhesive Teflon tape instead. No shrink wrap required. I also straightened out the tensioner just a little so that it would apply a little more tension. It worked great. Just clean off the old lubricant and stick on a piece of the the Teflon tape to the tensioner.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
FrankFuss is online now        Reply With Quote Quick reply to this message
Old 02-08-2015, 12:10 PM   #54 (permalink)
Nice find frank fuss. I think I'll get some of this to try out.
Old 02-13-2015, 01:49 PM   #55 (permalink)
I orderd the PTFE tape that Frank posted about.
This stuff is great. I stuck a piece on the bottom of the spring, then messed around bending or reshaping the spring a little. Now I have a perfectly smooth throttle on my DX9.
Synergy N5
Compass 6HV
Blade 700X
iKON DX9
Greg B is offline        Reply With Quote Quick reply to this message
Old 02-14-2015, 03:12 PM   #56 (permalink)
+1 Got the same tape as Frank, and it works excellent. Much easier that having to heat shrink the ends, and I believe gives as good a feel or better than the stuff talked about in the beginning of the thread.
Old 02-16-2015, 10:34 AM   #57 (permalink)
CHC Benefactor
Thanks guys. Great info. Just ordered the tape version to upgrade my Tx! Hoping it does the trick
Old 02-16-2015, 11:16 PM   #58 (permalink)
Just did this mod and could not be happier! So nice…
FWIW, I used this tape as it was a little cheaper.
Thanks to the Freaks.
C_M_H is offline        Reply With Quote Quick reply to this message
Old 04-12-2015, 03:37 AM   #59 (permalink)
Just did this with my DX6. Night and day, I feel way more control over the collective. Thanks!
flytye
flytye is offline        Reply With Quote Quick reply to this message
Old 04-15-2015, 07:33 PM   #60 (permalink)
After five attempts on my X9503 I gave up. This transmitter along with my 11X has fine serrations on the half moon that the tension spring rides on. Using this tape from a previous post: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 tried single, double, and triple layers as well as smoothing the edges and face of the tension spring. As I tightened the throttle the serrations from the half moon pressed themselves into the tape. Very smooth action but felt like the ratchet spring some plank guys use was installed and became more pronounced after a couple of days.
Removed the tape, polished the spring with Dremal pad and compound, added triflow grease and the stickiness is gone.
Anyone had any luck with a JR radio, maybe with different tape?
TRex 700E (2) - Fusion 50 (4) - Goblin 630
TRex 500 (5) - Trex 450 (6)...
Hell, lots of Helicopters. Lots. Airplanes and Quads too.
Unless this is my wife reading this, then just a couple.
rkweekly is offline        Reply With Quote Quick reply to this message
