Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
Old 02-04-2008, 03:03 PM   #1 (permalink)
Default 2.4 Latency Charts are here
JKos is the owner of these charts and info so please PM him with questions, as I do not know. I just wanted this all together and in one thread
Code:
PCM, DSM, DSM2, FASST, XPS in eCCPM Mode
Transmitter    |Receiver|MLF|MLL|MaxLF|MaxLL|Avg
ATX Stylus     |92186Z  |13 | 16| 27  | 30  | 21.5
Futaba 12Z     |R5014DPS|14 | 14| 31.5| 31.5| 22.75 (1)
Futaba 12Z Md A|R5114DPS|11 | 11| 29.5| 29.5| 20.3  (1)
Futaba 12Z Md B|R5114DPS|15 | 15| 37.6| 37.6| 26.1  (1)
Futaba 12Z/TM14|R6014FS |19 | 19| 57.8| 57.8| 38.4
Futaba 14MZ    |R5014DPS|14 | 14| 31.5| 31.5| 22.75 (1)
Futaba 14MZ    |R5014DPS|14 | 24| 31.5| 41.5| 27.75 (2)
Futaba 14MZ    |PCM1024 |29 | 93| 42  |106  | 67.5  (3)
Futaba 14MZ    |DM8/AR9 |20 | 23| 74  | 76  | 47    (4)
Futaba 9C      |R149DP  |44 |110| 57  |123  | 83.5
Futaba 9ZWC2   |R149DP  |29 | 93| 41.9|105.9| 67.5
Futaba T6EX    |R606FS  | 8 | 15| 54  | 60  | 34.25 (5)
Futaba T7C 2.4 |R617FS  |11 | 13| 39  | 41  | 26.4
Hitec Eclipse7 |QPCM    |41 | 43| 62  | 64  | 52.5
JR 8103        |649S    |27 | 59| 47  | 59  | 48
JR 9303        |649S    |15 | 47| 36  | 47  | 36.3
JR 9303        |770S    |15 | 47| 36  | 47  | 36.3
JR 9303/Spektru|AR9000  |40 | 45| 63.8| 68.3| 54.4
JR 9303/XPS    |XPS 8-ch|33 | 52| 74  | 81  | 60
JR X9303       |AR7000  |24 | 26| 45.5| 49.5| 36.2
JR X9303       |R921    |24 | 26| 45.5| 49.5| 36.7
JR 10X         |649S    |34 | 66| 54  | 66  | 55
Spektrum DX6   |AR6000  |59 | 63| 80.6| 88.6| 72.8
Spektrum DX6i  |AR7000  |23 | 25| 47.6| 49.6| 35.74
Spektrum DX7   |AR7000  |14 | 16| 36  | 40  | 27.5
Spektrum DX7   |AR6100  |14 | 16| 36  | 40  | 27.5
Spektrum DX7   |AR6000  |31 | 35| 53  | 61  | 45
PPM and eCCPM
ATX Stylus    |FM      |13 | 17| 37  | 45  | 28
Futaba 9C     |FM      |50 | 55| 72.3| 82.3| 64.9
Futaba 14MZ   |PPM8    | 4 |  6| 39  | 41  | 22.5 (1)
Hitec Eclipse7|FM      |22 | 28| 42.6| 50.5| 35.8
JR 8103       |FM      |10 | 14| 32  | 40  | 24
JR 9303       |FM      |10 | 14| 32  | 40  | 24
JR 10X        |FM      |10 | 14| 32  | 40  | 24
Multiplex Evo9|FM      |10 | 14| 32  | 40  | 24 (6)
PCM, DSM2, and FASST in Normal mode (Channel 6)
ATX Stylus    |92186Z  |13 | 13| 27  | 27  | 20
Futaba T6EX   |R606FS  |17 | 17| 61  | 61  | 39
JR 8103       |649S    |38 | 38| 58  | 58  | 53
JR 10X        |649S    |35 | 35| 55  | 55  | 50
JR X9303      |R921    |25 | 25| 47  | 47  | 36
PPM and Normal (Channel 6)
Futaba 9C     |PPM     |32 | 32| 59.3| 59.3| 45.65
Futaba 14MZ   |PPM8    | 3 |  3| 40  | 40  | 21.3
JR 8103       |PPM     |16 | 16| 38  | 38  | 27
JR 10X        |PPM     | 8 |  8| 30  | 30  | 19
All times are in milliseconds.
MLF - Minimum latency to first change at receivers output
MLL - Minimum latency to last change at receivers output
MaxLF - Maximum latency to first change at receivers output
MaxLL - Maximum latency to last change at receivers output
Avg - Average of MLF, MLL, MaxLF, and MaxLL
(1) Using channels 4, 5, and 6
(2) Using channels 1, 2, and 6
(3) Deduced numbers from observed behavior
(4) Channels 4, 5, and 6 on 14MZ and channels 2, 5, and 6 on AR9000
(5) Subject to collective input slew rate limiting
(6) In PPM 8, JR channel assignments, HELIccpm model and NOT an IPD receiver
ID:	37624   Click image for larger version
ID:	37625   Click image for larger version
ID:	37626   Click image for larger version
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote Quick reply to this message
Old 02-04-2008, 03:38 PM   #2 (permalink)
Wow, no wonder my DX7 / AR7000 felt so much more locked in than my DX6 / AR6000 previously had , 2.6X lower average latency.
-Fog
This heli stuff is a pretty deep Rabbit hole, you just have to decide how deep you are willing to go...
Check out my vids http://youtube.com/profile?user=wuestng
fogger is offline        Reply With Quote Quick reply to this message
Old 02-06-2008, 11:58 PM   #3 (permalink)
This is interesting. I thought the JRX9303 and Spektrum DX7 used the same specs internally but it looks like the DX7 is tuned a little better by getting about 10ms better averages for latency.
Also, I thought the XPS system was supposed to be faster than what I'm seeing here.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
Old 02-07-2008, 07:31 AM   #4 (permalink)
DX 7 = 7 channels of data. X9303 = 9 channels of data.
More data, more time for the data stream.
Also the X9303 will work at 2048 resolution versus 1024 for the DX7, so a extra bit per channel.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 02-07-2008, 10:11 AM   #5 (permalink)
Perhaps they should allow a user to inhibit unused channels to prevent them from transmitting on the 9303...
-Fog
Old 02-07-2008, 11:16 AM   #6 (permalink)
I may be wrong. But I think the only channels that JKos checks is the 3 channels that would control the swash on a eCCPM heli.
Not sure what they are doing with the new radios. But in the past all the channels did not update every cycle. An example with be the JR 10X. You had to be aware of where you plugged the Aux plug for the gyro. Because it you plugged into a channel that did not update but every other cycle or more. Then it would screw up gyro operation.
Same thing with the new Futaba's, they grouped the channels different so the update cycle would have the groups updating at the same time.
When you see the 100% synchorization, they are talking about a group of channels operating at the same time.
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 02-07-2008, 12:11 PM   #7 (permalink)
I have not heard of radios not updating channels every cycle. That would have to be controlled in the PCM conversion as PPM has to send the entrie string.
Servo Sync on the Spektrum takes care of reordering the channels during the transmit to have like functions work closer. And the nice thing is, it is dynamic, so different models will have different channel order in the transmit stream.
Terry
Old 02-07-2008, 12:49 PM   #8 (permalink)
....I think of all the wasted ms just standing there waiting for my model to repond to my radio.
WARNING! This post contains chemicals known to the state of California to cause cancer, birth defects or other reproductive harm.
N11634 is offline        Reply With Quote Quick reply to this message
Old 02-07-2008, 02:43 PM   #9 (permalink)
It is the processor in the transmitter that controls the channel cycle update. If you used a JR 10 series radio, it was well known that some of the 10 channels didn't update every cycle. The primary control channels updated every cycle. But the AUX channels did not. Was not a problem till governors came into being used. Then it was crucial which AUX channel they were plugged into.
David
Old 02-14-2008, 03:15 AM   #10 (permalink)
Team Taco VP
Awesome! I was hoping Jkos would maintain these here.... Thanks Jkos!
I think this should be a sticky so I am making it one.
Bob
Old 02-23-2008, 05:03 AM   #11 (permalink)
10ms advantage to the dx7, can't help but wonder what more people think about that
mjr_larkin is offline        Reply With Quote Quick reply to this message
Old 02-23-2008, 07:31 AM   #12 (permalink)
Mor channels, higher resolution, more data to transmit.
Terry
Old 05-30-2008, 11:43 AM   #13 (permalink)
Going back to my last stastitics course (many, many years ago), there appears to be no statistically significant differences in the first 2/3 of the chart (sorted by minimum latency).
ie ... 20 5 is not stastically different from 22 5 as they "overlap".
Any chance we can get the results re-processed to include all channels available in each transmitter?
marchambault is offline        Reply With Quote Quick reply to this message
Old 06-06-2008, 10:10 AM   #14 (permalink)
Any idea where the 12X figures into this?
Old 06-06-2008, 10:31 AM   #15 (permalink)
The bars are not error bounds. They are minimum at the lower end and maximum at the upper end.
> each transmitter?
My results incorporate the three channels used for the swash servos except those listed as "Normal swash mode". It would be a monumental task to go back through all the radios to capture every channel.
The 12X numbers are available in my thread on the otheRR site. Someone needs to keep the charts copied over to here up to date.
- John
JKos is offline        Reply With Quote Quick reply to this message
Old 06-07-2008, 12:36 AM   #16 (permalink)
Jkos,
Thank you!
Old 12-18-2008, 03:13 AM   #17 (permalink)
DX7'z ROCK BABY YEAH !!!
"So What is 3D Flying"
Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place.
satchy is offline        Reply With Quote Quick reply to this message
Old 11-01-2009, 09:39 AM   #18 (permalink)
how much difference is there between the dx7se and the jr9303 with xps?
is the jr a heck of alot slower? I was considering but after looking at the chart its like the lowest on the totem pole
phantom2005 is offline        Reply With Quote Quick reply to this message
Old 09-04-2011, 02:41 AM   #19 (permalink)
Anyone found or measured latency of the new XG7/XG8?
I am looking for replacing my DX7, i do not need advanced radio, so the XG7 could be an option, because it have the same case like DX7.
Just for info, i measured the DX7, the numbers are right, 25-30ms average, but we measured on the digital output of Spektrum sattelite.
And also measured Jeti Duplex module in Graupner MX-22 or MC-22 (not sure which one it was).
Duplex have about 22ms latency between TX input and RX output, but the radio have another 20-25ms (from stick to PPM output, which the Duplex use).
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar NEO
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 09-12-2011, 06:50 PM   #20 (permalink)
Default 11x?
how fast is a 11x?
audio131 is offline        Reply With Quote Quick reply to this message
