Servo saver mod - Page 5 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-13-2014, 11:51 AM   #81 (permalink)
Default #007 orings
If any one needs some orings pm me. I just finished my mod works great on the bench
crhelipad is offline        Reply With Quote Quick reply to this message
Old 04-20-2014, 02:40 PM   #82 (permalink)
Has anyone confirmed that fuel tubing works? Also is it standard procedure to file a groove for the o-ring to sit in?
Thanks!
blbills is offline        Reply With Quote Quick reply to this message
Old 04-21-2014, 02:42 AM   #83 (permalink)
Mine have been working great by applying a tiny amount of CA to the o-rings, but obviously not over the cut.
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 04-21-2014, 08:04 AM   #84 (permalink)
Thanks!
Naturally that doesn't apply if you're using fuel tubing but it's very easy to do.
Just take a main post of a stipped set of gear, you may have a few if you haven't done the mod yet , glue the metal pin in it with ca. Then insert it in the chuck of a late or a dremel or any other drill that is kept horizontal with a vise or otherwise.
Once that is done, just slip the servo arm on it and secure it with the screw on the end.
While it's turning, you apply the tip of a pointed object, a tiny round file is ideal but the tip of a not too pointed knife should do. (See photo on post #64)
That's it. Mine have stay in place in the few hundred flights I've put on it since they are installed and have saved at least a dozen set of gear.
Good luck.
T-Rex 150 || Blade 180 CFX with ÁBrain || T-rex 250 pro DFC with Vortex Vx1p || T-Rex 450 PRO DFC || Mcpx BL || Mcpx v2 || Futaba 14SG (KDH-Modul) || DX8
Go for it is offline        Reply With Quote Quick reply to this message
Old 04-22-2014, 04:02 PM   #85 (permalink)
I'm using fuel tubing leftover from the nitro days. Works great for me, just cut a relatively thin slice of it. Necessity is the mother of invention eh?
Thanks!
Current favorites...
Oxy 3, Goblin 380, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote Quick reply to this message
Old 04-22-2014, 06:18 PM   #86 (permalink)
I had clearance problems with the o rings I was using. Switched to fuel tubing and have no problems at all.
Hydros27 is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 12:39 AM   #87 (permalink)
Originally Posted by ininverno View Post
Lynx is working for a ready to use safe gears arms.. testing going very well.
Sent from my GT-I9500 using Tapatalk
When do you think they will be ready ? I need some.
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 05-08-2014, 06:57 PM   #88 (permalink)
Gotta say that this mod is worth it's weight in gold. It has already saved me countless times.
Just using standard fuel tubing back from my nitro days.
Old 05-08-2014, 10:16 PM   #89 (permalink)
Gotta say that this mod is worth it's weight in gold. .
+1
+2
+3
+too many crashes to count now.
I got some 1/4" latex bands meant for teeth on ebay for cheap, took care of my clearance issues.
Chopper Crew: T-Rex 250 DFC, T-Rex 550e DFC, Goblin Black Thunder 700 T-Line
Multi Chop Crew: Nano QX, E010S, 200 QX, Martian II 250, Scratch V-Tail 355
Planks: Too Dayam Many
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 05-23-2014, 08:40 PM   #90 (permalink)
Lynx Heli now make servo arms with this modification.
Old 05-26-2014, 07:48 PM   #91 (permalink)
DPW
Default Servo Gear Saver Arm
Lynx Servo Gear Saver Arm
Arm split and gaped w plastic washer w Latex tube.
Have 2 sets will post any issues
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Old 05-26-2014, 09:27 PM   #92 (permalink)
Lynx design:
Latex tube w split and gaped arm w plastic washer.
Looks like an interesting design.
Split and gaped arm will insure spline contact pressure (better than the simple cut).
Latex like tube is probably a better design than the O ring (needs testing).
Washer (needs testing)
But
Was going to order a few sets and test drive their servo arm.
NIX
No vendors are selling them and Lynx shipping to USA is $17.
I had some in my cart also, got to the shipping and said.... Hell no!
Align T-Rex 150 - Align T-rex 450L Dominator 6S - Futaba 14sg
Hobbico Extra 300S Supertigre G75 - AMA #636581
FliHi is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 10:29 AM   #93 (permalink)
AMainHobbies carries Lynx products....
It will be a little while before they show up... but they'll be there first.
000pitch is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 11:54 AM   #94 (permalink)
I"ve been watching HeliDirect and AMain...
Old 05-28-2014, 03:25 PM   #95 (permalink)
Wonder how they tested them ? (run a 150 into the ground over and over and over )
Thunder Tiger X50 TT FBL (OS 50 SX Hyper | Align 3GX Gyro\Gov | Align DS610 x 4 | Align DS650 x 1 | 2 Spektrum Sats)
Align Trex 450Pro V2 (HS5065MG x3 | DS520 x 1| Castle ICE 50 | MiniV 5.3 Pro)
Align Trex 150 DFC (Lynx Metal Swash | Spektrum Sat)
Taxus812 is offline        Reply With Quote Quick reply to this message
Old 05-28-2014, 06:02 PM   #96 (permalink)
HeliDirect has them listed as available tomorrow! link below:
http://www.helidirect.com/lynx-micro...pc-p-36470.hdx
Old 05-29-2014, 03:13 PM   #97 (permalink)
They're in, get 'em while they're hot.. ordered mine today!
Old 05-29-2014, 03:37 PM   #98 (permalink)
DPW
Red face
on
Microheli and Align Performance Frames.
Microheli Frame
fwd (A&P) arms make frame contract (file or grind CF frame?)
fwd (A&P) arms do not make contact
M & A frames aft E servo arms make contact with fwd servo.
Old 05-29-2014, 04:10 PM   #99 (permalink)
+1 on order
So
We shall see whom has the first crash review.
But
I got to warn Y'all I'm not a very good flyer and I'm getting better at Heli repair every day!
was thinking I didn't want to be the first to test crash...
Old 05-29-2014, 07:00 PM   #100 (permalink)
My order is on the way as well. Thanks for the tip
Human Verification
