Old 02-02-2017, 07:32 PM   #81 (permalink)
Can anyone explain in simple terms the difference between PPM Negative & PPM Positive? I was happily flying in PPM Neg, and then read that someone was saying Pos was correct, so, I just switched from Neg to Pos. I didn't even rebind and it works fine. What up?
kcasser is offline        Reply With Quote Quick reply to this message
Old 02-02-2017, 08:03 PM   #82 (permalink)
Ppm negative is inverted ppm positive. Your module will generally only work with one and it depends on the module.
Raleighcopter is offline        Reply With Quote Quick reply to this message
Old 02-02-2017, 08:07 PM   #83 (permalink)
Hmmm... I should check with my other stuff, but it worked with my Nano both Pos & Neg.
Old 02-03-2017, 06:55 AM   #84 (permalink)
I get it - it is my Phoenix Simulator that requires PPM Negative. It wouldn't work in PPM Pos. I guess the BNF's are not so picky.
Old 02-04-2017, 10:18 PM   #85 (permalink)
With the module:
The ppm out wire goes to both the module and the sim jack.
Sim jack --> Phoenix might need one. It's possible that another sim might need another.
Module --> The module will likely require one or other also, but go figure... some may be just as happy with positive or negative.
Worst case you could use a DSMX module that needs ppm negative, an EZUhf module using ppm positive and a FrSky 16ch module using ppm 16. You'd just need to change that setting when you swap modules.
gunny_jeeves is offline        Reply With Quote Quick reply to this message
Old 02-02-2021, 07:21 AM   #86 (permalink)
Hi everyone.
I made one with DM9 from spektrum with jeti R4light and its working good with any spektrum reciver. Also setup from jeti is :
PPM negative
computed
So my question is
Way i can't see any control on my realflight usb (SPMWS2000).
I Plug the usb to my computer and driver is installed correctly. And bind it with my DM9 .
I can see it in my connected device's but nothing move .
When i bind my usb to dx6 its work . But not my jeti to spektrum bridge????????
Any idea
coolt5 is offline        Reply With Quote Quick reply to this message
