TREX 150 FAQ + Mod List - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree1Likes
Old 02-20-2014, 12:37 PM   #1 (permalink)
Default TREX 150 FAQ + Mod List
Disclaimer, this is NOT my original work. Every piece of info came from this forum, Align, the internet and your fellow HeliFreaks! Any modification you make is on you. No warranty is implied with this gathered list of tweaks, mods and info.
Align TREX 150
Align's smallest and most petite 3D helicopter T-Rex 150 DFC, carries the same superior pedigree and design concept that originated from the successful T-Rex line of helicopters. Featuring strong power, superior flight control stability, and equipped with high end components, far exceeding any other helicopters currently on the market.
Twin brushless motor design, paired with 2s 7.4v 250mah battery, creating power that will surpass all your expectations. Metal DFC main rotor head assembly featuring high end aesthetic and superior flight performance; in addition, an integrated control system with specially optimized 3-axis gyro, receiver, electronic speed controller, and 4g servos. All of these enable the T-Rex 150 DFC to possess the same stability, superior agility, and tail holding effectiveness as the larger helicopters.
T-Rex 150 features built in Futaba S-FHSS 2.4Ghz system, and support the use of Spektrum DSM2/DSMX / JR DSM2/DSMJ/DMSS satellite receivers. To get the T-Rex 150 airborne, all that’s needed is inputting of parameters listed in manual into your transmitter, and binding of your transmitter.
Miniature size, control precision that resembles the larger helicopters, enables you to enjoy flying inside a confined space. Beginners can even enjoy this with ease by just turning down the speed dial. The innovative breakthrough T-Rex 150 will bring you a new dimension of flying enjoyment.
Specs:
Battery: 250mah 30c Dimension: 47x21.5x12mm Weight: 15g
Orange blades: Length: 120 mm Weight: Approx. 7.2g/set
Black blades: Length: 120 mm Weight: Approx. 5.8g/set
Tail blade: Length: 41.35 mm Weight: Approx. 0.21g
150DFC balls are 2.10mm
The top board is a FHSS receiver.
Middle board is the brains and gyro system.
Bottom board is main and tail escs, with a 5 volt switching regulator for the servos and brains
Length: 255mm
Height: 80mm
Main Blade Length: 120mm
Main Rotor Diameter: 271mm
Tail Rotor Diameter: 41mm
Motor Pinion Gear: 10T
Main Drive Gear: 78T
Weight (w/o Battery): 53g
V1 released in Nov/Dec 2013. Poor T43 resistant plastics used. Possibly manufactured with too much Loctite which soften ABS plastic parts. ABS
V2 released in Jan 2014. Updated plastics. PA66 (Nylon) Parts marked with "A" in various locations. Different main and tail motors. Motor connection pins removable.
Manual link: http://ms.align.com.tw/mpeg/manuals/...s/RH15E01X.pdf
Flight adjustment link: http://ms.align.com.tw/mpeg/manuals/...01_m_fligh.pdf
Contact info:
Assurance R/C USA
3626 Briggeman Dr.
Los Alamitos, Ca 90720
Email: sales@alignrcusa.com
Align parts list:
http://www.alignrcusa.com/index.php?...5284ae483f7bff
Align 150 product page: http://shop.align.com.tw/product_inf...en#tabbed_info
RADIO:
To use with Spektrum equipment, must add satellite receiver.
Options:
Lemon discussion: https://www.helifreak.com/showthread.php?t=598242
Lemon DSM2: http://www.lemon-rx.com/shop/index.p...&product_id=98
Lemon DSMX: http://www.lemon-rx.com/shop/index.p...product_id=109
Orange: https://www.hobbyking.com/hobbyking/..._Receiver.html
Spektrum DSMX: http://www.spektrumrc.com/Products/D...ProdID=SPM9645
Spektrum DSM2: http://www.spektrumrc.com/Products/D...ProdID=SPM9545
DSMX will bind DSMX at 11ms on Spektrum and Lemon DSMX receiver if you have compatible radio.
D/R & expo settings for tame, VERY tame, 3d, etc. http://www.rcproreviews.com/align-t-...r-3d-settings/
How to solder receiver directly to mrs (voids warranty): https://www.helifreak.com/showthread...21275&page=142
To bind in DSMX mode, must press the SET mode when powering on the heli the first time.
Spektrum radio bind procedure video:
Trex 150 DFC Setup/ Bind Procedure for Spektrum Radio systems (16 min 44 sec)
Futaba radio bind procedure video:
Trex 150 DFC Futaba Radio Setup and Bind Procedure (7 min 41 sec)
Transmitter setups by the manual: https://www.helifreak.com/showpost.p...postcount=2219
Head:
Members have posted that adding additional spacers on the feathering spindle decreases any play, applies more pressure to the dampers and allows you to turn gain up higher.
https://www.helifreak.com/showthread.php?t=602191
Feathering spindle stuck: https://www.helifreak.com/showthread...51#post5673451
Feathering spindle stuck: Use quality tools. REV1 may have had the screws CA'd or extra locktite applied.
Vibes in the head? Check your bearings: https://www.helifreak.com/showthread.php?t=608327
Swashplate tool=Pitch tool: https://www.helifreak.com/showthread.php?t=607847
Body/Frame/Servos:
Make sure you have "A" parts.
Available aftermarket frames and frame stiffeners.
Performance frame discussion: https://www.helifreak.com/showthread.php?t=605897
Servo gear issues: https://www.helifreak.com/showthread.php?t=606673
Servo saver mod. Protects the servo gears. Have spare set of gears and arms just in case. Link: https://www.helifreak.com/showthread.php?t=602182
Tail:
Adjustable gyro gain. Set through radio.
Tail motor issues, parts: https://www.helifreak.com/showthread.php?t=603370
Tail motor replacement video:
Align Trex 150 Tail Motor replacement How-To-Video (14 min 38 sec)
BLHELI mod: Note this voids your warranty.
BL HELI is a test flash right now to work through issues.
BLHELI can be flashed to the ESC for both main and tail motor.
It'll give you computer programmable options.
Blheli is code first written specifically for double brushless micro helis. The main has a soft spool up and governor, with adjustable gains.
The tail has very fast response, both accelerating and decelerating the motor, and holds the tail motor at an idle speed for several seconds after it sees a 0 throttle signal to avoid the tail stopping in flight under certain conditions.
Pwm, timing, gain, lvc, startup method and power, low and high ppm signal range and a lot more are adjustable.
Link: https://www.helifreak.com/showthread.php?t=598010
Another link: https://www.helifreak.com/showpost.p...postcount=3225
Solder points: http://cdn.shopify.com/s/files/1/007...Blheli.jpg?477
Tools:
Avoid using included tools. They strip the heads,
Instead buy higher quality tools in the sizes below:
0.9mm, (2) 1.3mm, 1.5mm.
Recommended you have a swash leveler.
Homemade ball link pliers: https://www.helifreak.com/showthread.php?t=596421
Micro pitch gauge: http://www.snhobbies.com/product_inf...67f6881c51a59d
Manual notes:
There are some errors in the manual. See these links:
https://www.helifreak.com/showthread.php?t=590229
https://www.helifreak.com/showthread.php?t=603588
https://www.helifreak.com/showpost.p...postcount=2687
https://www.helifreak.com/showpost.p...postcount=2525
https://www.helifreak.com/showpost.p...postcount=2527
Batteries:
Mod's available to use MCPX BL batteries. https://www.helifreak.com/showthread.php?t=589490
MCPX BL battery tray mod: https://www.helifreak.com/showpost.p...postcount=2353
Battery charging: https://www.helifreak.com/showthread.php?t=582178
Parallel charging cable example: http://www.progressiverc.com/paralle...t-rex-150.html
Recommended tweaks out of the box:
-Metal swashplate. Plastic one has a tendency to separate.
-Servo saver mod. Protects the servo gears. Have spare set of gears and arms just in case. Link: https://www.helifreak.com/showthread.php?t=602182
-001 o-rings on all head, servo and swash balls. Link: https://www.helifreak.com/showthread.php?t=599996
-Re-level MRS unit. Stock install seems to be coming crooked from the factory. Do NOT strap down or let it touch the actual frame.
Link: https://www.helifreak.com/showpost.p...36&postcount=3
Link: https://www.helifreak.com/showpost.p...postcount=2612
-Balance and dynamically balance your blades. Or at least balance and CG your blades if you find you cannot dynamically balance. This heli does NOT like any vibrations at all. https://www.helifreak.com/showthread.php?t=592897
Other goodies members have done:
Easier insertion of batteries: https://www.helifreak.com/showthread.php?t=596094
Potential tweaks:
CF main shaft. Stock aluminum one reported to bend easily in crash.
Servo gears. Probably best to have at least 1 spare set on hand.
Parts:
Reported that MCPX BL feathering spindle is a match.
Main Drive Gear H11011. Same as TREX 100
Bearings in the blade grips are 681ZZ-d2. Same bearings found in the DFC arm of TREX 250 and 450 if you need one in a hurry. 2mmx4.5mmx2mm
Shaft bearing, H63 Bearing H11021, same as TREX 100
Other:
V2 skid strength test video: https://www.helifreak.com/showthread.php?t=586988
How to:
Landing gear pin broken? Heat up a needle with a torch, stick the (still red hot) needle into the landing gear peg (still stuck in frame), let cool, and pull it out.
https://www.helifreak.com/showpost.p...postcount=2766
Set pitch: Use micro pitch gauge, or fold blades flat and measure the angle between them at high and low. EX: for 12* pitch, fold blades together, put into full pos collective, measure blades with protractor. You should get 24* do same for neg collective.
Example photo of a micro homemade pitch gauge.
http://compusmurf.smugmug.com/Airpla...16.07.20-M.jpg
Tail wire broken or having issues: https://www.helifreak.com/showthread.php?t=603370
Skids falling out of body? Use a tiny drop of "shoe goo" on the posts. Removable, yet holds rather well.
Night flying setup: https://www.helifreak.com/showthread.php?t=592492
Link to tons of basic heli knowledge:
https://www.helifreak.com/showthread.php?t=41692
Great write up of what DFC is and how it works: http://www.rchelicopterfun.com/DFC.html
Link to HELI SAFETY FORUM.
Be safe out there. Everything you do affects everyone around you.
https://www.helifreak.com/forumdisplay.php?f=71
__________________________________________________ _
Align TREX 150, Align TREX 250, MCPx BL, Nano CP, Nano Qx, Blade 180qx
Member: AMA
Compusmurf is offline        Reply With Quote Quick reply to this message
Old 02-20-2014, 12:38 PM   #2 (permalink)
Hopefully this helps someone. If you see something you want added or changed, let me know.
I spent a bit of time compiling the tidbits from various threads into 1 spot to help someone/anyone to find stuff easier. It's easy to misplace good threads with info.
Member: AMA
Old 02-20-2014, 12:48 PM   #3 (permalink)
I subscribed! Thanks for taking the time to put this together. Will be very helpful for many I'm sure.
Every morning, I get up and look through the 'Forbes' list of the richest people in America. If I'm not there, I go to work.
jbobb1 is offline        Reply With Quote Quick reply to this message
Old 02-20-2014, 01:15 PM   #4 (permalink)
Very cool. Thanks for putting this together and let's get an admin to sticky it ASAP.
What's the latest scoop on mounting the MRS. I know you want to make sure it's straight and not rubbing on anything. But is 3M 4011 tape sufficient? Or does is really need that spongy stuff that comes on it stock?
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 02-20-2014, 01:29 PM   #5 (permalink)
Couple of options added to main post.
Member: AMA
Old 02-20-2014, 06:40 PM   #6 (permalink)
Great thread, Thanks very much for the time and effort needed to put this together. It is appreciated
Align 800 PRO DFC w/CGY750 / Align 700L Dominator w/CGY750 / 74" EF Slick 580 EXP / Futaba 18SZ / RealFlight 7.5
shawnlh is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 01:36 PM   #7 (permalink)
DIdn't see it but ProgressiveRC has a Parallel charge cable
Colin
Build.....Fly.....Crash.....Repeat.....
SG14, Gaui X3, Oyx 3 qube, Oyx 2, LOGO 550sx,
Protos 700, Protos 380
ccg123 is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 01:42 PM   #8 (permalink)
adding. Keep coming up with goodies. Tho I'm trying to keep things vendor neutral if at all possible.
Member: AMA
Old 02-21-2014, 04:33 PM   #9 (permalink)
Default Older vs. newer version
Is it safe to assume that buying one now will get the desirable newer version, or is it possible or likely that there are still older units lurking out there?
Mr. Headless is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 04:57 PM   #10 (permalink)
I can say it's safe if you get it from AlignTrexStore.com. I'm not sure about anywhere else since they're usually not very good about keeping their product descriptions up to date.
Old 02-21-2014, 10:03 PM   #11 (permalink)
Did yours come with the new reinforced frame?
Hydros27 is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 10:30 PM   #12 (permalink)
As far as I know it is. I got this one that came bundled with the metal swashplate...
And the one on the helicopter appears to be exactly the same.
ID:	489235   Click image for larger version
Old 02-21-2014, 10:31 PM   #13 (permalink)
I just received mine earlier this week from aligntrexstore.com and the frame on it is exactly the same as the new one that comes in the bag with the aluminum swash that I bought separate. So it seems they do have the latest version as advertised.
Old 02-21-2014, 11:18 PM   #14 (permalink)
Default Re: TREX 150 FAQ + Mod List
Mine was latest version from local hobby store that just got them in. Was able to check, thanks to this forum, before spending the cash.
No spares carried there yet.
Sent from my SM-N900T using Tapatalk
Member: AMA
Old 02-21-2014, 11:50 PM   #15 (permalink)
Thanks for the info. I'm trying hard not to buy another helicopter.
Do you have a 130X? If so how do you think the DFC's flight performance compares to the 130X?
Old 02-22-2014, 12:16 AM   #16 (permalink)
If you don't want to buy another heli, you don't want to know that answer, trust me.......
Member: AMA
Old 02-22-2014, 11:26 AM   #17 (permalink)
I actually don't own a 130X, but I have flown a few. I've been able to resist that urge because I've seen so many people at our club and on these forums having trouble with the upkeep. I normally fly at a large AMA field so I much prefer larger helicopters. My 300X is really my go to "micro" heli. I don't have a whole lot of need or high expectations for small micro helicopters. What I typically use them for is practice when I can't get out the field or when traveling. I have an mCPX BL and have had my share of electrical issues with it which is why I'm giving the T150 a try. It's more of a direct comparison to the mCPX BL than it is to the 130X.
Old 02-23-2014, 04:35 AM   #18 (permalink)
Very useful thread !
I wish it existed last week when I was looking for info about buying my own 150
ibutcherjp is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 09:53 AM   #19 (permalink)
few updates. If anyone has stuff they want added, let me know.
Member: AMA
Old 02-25-2014, 10:47 AM   #20 (permalink)
So how do we get this thread stickied.... It certainly deserves to be.
Tags
150, faq, mod, trex
Human Verification
