Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Mini CP
Mini CP Walkera Mini CP Helicopter Support
Old 03-14-2014, 04:03 PM   #41 (permalink)
Default Yeah... it's pretty bad :(
Every week this helicopter has another issue, I haven't flown it in about 5 months because i was too lazy to fix it and was enjoying the V120. My main motor broke, my bl conversion doesn't work, my new motor died out, my feathering shaft was being replaced constantly, and finally my receiver broke.
I decided to finally buy a new receiver and get the bird back in the air (took a month to get here from China) but I can't seem to get the screws in tight enough. The receiver is pretty loose and I can move it with my finger very easily. I know tis causes the FBL unit to go crazy so I was wondering if there is a certain way I'm suppose to get these in... Sounds like a stupid question but The screw really will not go any further. Also, can I just glue the board to the screws? To eliminate flight shaking at least...
My next purchases are gonna be: Metal Rotor Head, Better charger (been using stock for the whole year I've been in this hobby), a few nano techs, and KDBB blades. A little after I get use to flying the mini again, eventually I'll try a brushless upgrade for the second time. Which reminds me... Anyone have a solid BL setup they'd like to share + where you bought it from? I'm kinda looking to spend about 50 bucks, but share yours even if its more.
Thanks a ton!
Mini CP | New V120D02S
MiniCPflyer0110 is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 05:29 PM   #42 (permalink)
Default Re: Mini CP is garbage
Thanks a ton!
As far as the screws, I recently replaced my Rx and if you don't get the screws in straight they may have trouble going in all the way. So I'd make sure they're straight. If they are I would check the length of them as well to make sure they aren't too long. If your Rx came with screws, try those. If you're using those then try the ones that originally came with the mini cp.
As far as the metal head, I wouldn't get it. It will just add weight to your heli and more weight makes it more sluggish, less battery life, and crashes are more likely to cause damage. Plus an aluminum head will bend where plastic may have survived, and if it didn't it would have broken one piece that absorbed all the force instead of breaking multiple parts like metal will.
As far as a brushless kit, wowhobbies has one for $55 that I have heard good things about. I would get the one that comes with a main gear.
Honestly if you have a v120 then I wouldn't put too much into the mini cp. The v120 seems better than the mini cp and your money would be better spent upgrading that IMO. Not to mention a brushless upgrade on the mini will probably require a better tail motor as well to keep the tail authority. Where the v120 has a shaft driven tail so only requires one motor and doesn't seem to have many problems with tail authority.
Sent from my XT1028 using Tapatalk
tstivers is offline        Reply With Quote Quick reply to this message
Old 03-31-2014, 05:32 PM   #43 (permalink)
I got the parts to get this thing running again today (finally). I cannot believe how stable it is. Night and day difference. It goes through a whole pack now and never tries to pull in any direction. I can let go of the sticks and it will literally hover in place moving very slightly. Its amazing. It was definitely a defective receiver causing it to pull to the right.
The parts couldn't have arrived on a better day either. I took it outside and there was zero wind at all. It hovered just as stable as it did inside, and required no collective correction at all.
The 3DPro blades I got from rc711 made a huge difference in smoothness as well. I can't feel any noticeable vibration at all. Perfectly balanced, and they look awesome too. Haven't tried the upgraded tail motor/blades I bought yet because I figure I'll kill the stock one then install the upgraded one, but I'm sure that will make a huge difference too.
Now I just need to build this 250 I got the new airframe for today as well.
I'm a happy camper.
Old 08-03-2014, 09:17 AM   #44 (permalink)
Coming from motor trouble with my (returned) nCPX, I purchased my Mini CP & Devo 8S from Helipal. Flew great and stable out of the box. There is a sense of quality with this set, in my opinion. I like this little bird so much, that I will also upgrade my "old" V120D02-V2 with the more solid V120D02S canopy, new blades...and maybe a new 6-axis receiver in the future.
mSR, mSRX, Mini CP, mCPX, V120D02S, T-Rex250/iKon, Forza450EX/iKon
Helicrush is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 10:59 AM   #45 (permalink)
sometime its not the heli to blame ,sometime its the pilot
Walkera Mini Cp indoor 3d flight (3 min 51 sec)
jamichx is offline        Reply With Quote Quick reply to this message
Human Verification
