Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 03-05-2014, 09:58 AM   #41 (permalink)
Are you making any of the -15s ?
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | T450 Sport FBL | OMP M1
Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery
jharkin is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 10:48 AM   #42 (permalink)
SamIAm -sounds good.
If the 27 tooth spur gear was made from aluminum and hard anodized, the same way it was done on the EX, it would never strip, so the only strippable gears would be the -18 TT and the main gear.
This would make for a very robust gear train
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 07:18 PM   #43 (permalink)
Sounds great.
Keith Smith, RCHN #231
Spartan, Synergy E7, Legend FBL, Goblin 700, Whiplash E, Furion 6s,GAUI R5, Furion 450s, Xcell 60 , T-REX 600s, T-REX 450s, 300X, 130X, MCPXs. I'll fly what I want to fly. You do the same.
flyul1 is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 08:42 PM   #44 (permalink)
jharkin - I have ordered a blank so I will look into the -15 gears as well.
Lots of X-Cells and little sense.
SamIAm is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 10:54 AM   #45 (permalink)
Heliproz have the main gear for the EX back in stock. Leon
MA Graphlte 46, MA 98 SE, MA IonX2, 2 Whiplash EX, Synergy E7SE
boomstrike5 is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 11:53 PM   #46 (permalink)
Default Have you checked the classifieds today???
See Classifieds for whiplash parts!!!!
Doctorfixjet is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 12:26 PM   #47 (permalink)
This appears to be a nitro ver that is being parted out. All used parts.
Dont mean that as bad just saying
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 03-21-2014, 12:46 PM   #48 (permalink)
No worries, some new parts will also be posted as well, you have to go to (Everything Else Helicopter Related- Heli Parts, blades, etc...) I wasn't even aware that forum existed until the Forum god's notified me....
Old 03-27-2014, 04:49 PM   #49 (permalink)
I'm also a Whiplash owner in the UK.
I have upgraded mine to the EX helical main gear to get rid of the problem with the 15 gear but when checking everything out, it looks like I have a crack in one of the 18's. If someone could produce any of the 17's and 18's I'd happily buy a stock pile of them. Looks like I'm grounded until I can find some
Andrew Bird is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 08:24 PM   #50 (permalink)
There is a 17 and 18 listed on e-bay right now.
Old 03-28-2014, 03:41 AM   #51 (permalink)
Thanks!
We'll see if I can get it. I'd still be in if someone were to do a production run of these though
Old 03-28-2014, 08:20 PM   #52 (permalink)
Heliproz had a batch of the 131-17 gears in by the looks of it.
Don't know how long they have been on there though.
Managed to order a couple and now they are back out of stock again.
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 ——
malc1 is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 08:47 PM   #53 (permalink)
gone already
MSH mini-p VBar ,G380, Goblin 500, TREX 600N LE VBar, Trex 700N 91hz FB, Whiplash 105HZR VBAR, Nitro Citizen 414
mr008 is offline        Reply With Quote Quick reply to this message
Old 04-01-2014, 05:30 PM   #54 (permalink)
Here are some pictures of how to make the -18 gears without a cnc mill. I turned the blank on a lathe to 15 mm and then plunge cut the gear on a small rotary table with a 1/4" end mill. I should probably use a 5mm end mill as 1/4" is a little too big, but the end result is encouraging.
ID:	499369   Click image for larger version
ID:	499370   Click image for larger version
Arrow2 is offline        Reply With Quote Quick reply to this message
Old 04-01-2014, 09:20 PM   #55 (permalink)
What did you pay for the blank?
Old 04-01-2014, 09:47 PM   #56 (permalink)
from earlier post
SDP-SI.com
A 1M 4-Y24024
$3.45
I have around 8 blanks, PM if interested
Tom
TRM Power
Old 04-02-2014, 08:42 AM   #57 (permalink)
Originally Posted by fastflyer20 View Post
from earlier post
SDP-SI.com
A 1M 4-Y24024
$3.45
Dont need them now, I have 5 set of spares, but there may be a time
Old 04-02-2014, 09:45 AM   #58 (permalink)
I have some spars except for 131-17. I am one tail strike from grounded. Has anyone come up with a replacement for the 17?
Keith Smith
Old 04-02-2014, 09:48 AM   #59 (permalink)
That's the gear to concentrate on I think.
Old 04-04-2014, 10:06 AM   #60 (permalink)
time to check the (Everything Else Helicopter Related- Heli Parts, blades, etc...) forum for info on -17 & -18 gears...
