Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 05-23-2014, 04:36 AM   #81 (permalink)
Thanks George
Nice that gear sounds great. Tapping the hole for the extra set screw is something that could be done in the home work shop. The whiplash may get to fly once again.
Chicko is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 07:36 AM   #82 (permalink)
I will strip down a Whiplash Electric that has about 20fligts(i'm flying nitro).
So if anyone is interested in electric frames, ex gears, the new oneway etc send me a pm.
/christoffer
www.helistore.se
Mikado SAB Kontronik Scorpion dealer, so I might be a bit biased.
christoffer is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 09:42 PM   #83 (permalink)
Does anyone have a flybarless main shaft they care to sale?
kevinbj is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 05:07 PM   #84 (permalink)
Hi Kevinbj,
Try the RJX Gasser mainshaft. It has 10mm, the holes are slightly off, but should work, give it a try. You may need to set up the linkages at the mainrotor anew.
You can get it at:
http://olivershobbies.ecrater.com/p/...shaft-in-stock (US)
or http://www.ercmarket.com/main-shaft-...t90-61115.html (Belgium, Europe)
or google XT90-61115.
Be sure not to confuse it with the EP90-61115, which is for the electric version of the RJX 90 only.
Kind regards
George
OldGasser is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 11:33 PM   #85 (permalink)
Originally Posted by OldGasser View Post
Hi Kevinbj,
You can get it at:
Kind regards
George
Ok thanks
Old 07-02-2014, 01:05 AM   #86 (permalink)
Hi Chicko,
From the 700x manual I conclude that the gear has only a 5mm bore while the Whiplash has 6mm. Also the gear is secured by a pin, while the Whippy uses two setscrews.
IMO, the gear A 1Z 2MYZ1002706 from sdp-si.com is the easiest way to go. I ordered one to check and it is almost identical. It has a brass insert which is prefferable to acetal only for setscrews. You will only have to tap a hole for a second setscrew. Stock it only comes with one, which I would not want to rely on. Maybe grind off a little from the hub. That's it.
Kind regards
George
I ended up getting the gear from sdp-si and your right it is almost identical. Had to grind/sand the upper part of the hub down and also the lower side of the gear need about 1mm off it to clear the torque tube gear. (Set screw is a little higher up on the hub). Haven't tapped a second grub screw hole yet as I need to get a hold of a tap.
Old 09-01-2014, 11:09 AM   #87 (permalink)
Good day, Has anyone found a source for the Torque tube? I need one. Is the RJX Gasser mainshaft a good replacement for the mainshaft?
Keith Smith
Keith Smith, RCHN #231
Spartan, Synergy E7, Legend FBL, Goblin 700, Whiplash E, Furion 6s,GAUI R5, Furion 450s, Xcell 60 , T-REX 600s, T-REX 450s, 300X, 130X, MCPXs. I'll fly what I want to fly. You do the same.
flyul1 is offline        Reply With Quote Quick reply to this message
Old 09-01-2014, 12:06 PM   #88 (permalink)
Default arrow
If I remember correctly you can use an arrow shaft.
frito169 is offline        Reply With Quote Quick reply to this message
Old 09-01-2014, 08:23 PM   #89 (permalink)
Keith Smith
I have those parts if you need them . . . .
We had a great country once. You know what made it great? I can. Then the weak came along, the I cants and destroyed it.
Rudy is online now        Reply With Quote Quick reply to this message
Old 09-01-2014, 08:43 PM   #90 (permalink)
Good evening Rudy, Yes I do. What so you need for a FBL Main shaft and torque tube.
Old 09-18-2014, 11:54 PM   #91 (permalink)
Hi together,
I am looking to get some nylon-bevels made too. I have a guy who would make me a couple 131-17 shaft-side-bevels. The bevels only, the screws you can get at a hardware-store, not worth sending them around.
Ron has the 131-18 tt-side-bevels in stock, I do not want to interfere with his business.
It will take at least until Easter. Shipping would be from Europe, should be approx. 7,-- Euros worldwide with registered mail, but have to check that back.
Payment would be via paypal in Euros. Price is not sure yet.
Anyone intrested? Please let me know and I will see what I - or better my friend - can do.
Kind regards
George
Hi,
Is it still available to buy MA 131-18 and 131-17 gears. If yes is it possible to send 5 of each in France?
Regards,
Jol
Cordialement,
Jol
raptor90se is offline        Reply With Quote Quick reply to this message
