Old 02-28-2014, 03:07 PM   #1 (permalink)
Default My Stealthy Stretched Mini Protos (Build Report)
With the help many of the great Protos forum guys, this heli has been a fun build. I ran into some gnarly problems early on getting the bearing blocks to line up but once I got past that hurdle everything went smoothly.
I was a bit taken aback initially that there was no paper manual since I like to write notes on my manuals, but that was a non-issue after I printed one out. I have to admit that occasionally it was pretty nice to look at the electronic version and blow in up on screen to look at specific details. It was also cool that an updated manual came out mid build.
I didn’t take the choice of the Mini Protos lightly. I was in the market for a high quality 450 size heli that I could put my first bail out system on in hopes of it becoming my "go to" trainer. The consensus after this thread was the MiniProtos or the JR Forza:
https://www.helifreak.com/showthread.php?t=576109
The MiniP was a proven design and readily available so it was my choice.
The next question was whether to stretch or not. I’ve always found smaller helis to be somewhat squirrelly so stretching to larger blades seemed worthwhile.
The next question was 3S or 6S. This one was a bit harder. I opted for 3S since it was the stock configuration and so that I can swap batteries with my planks and my TREX 450SE. I may still shift over to 6S if I’m not happy. Time will tell.
https://www.helifreak.com/showthread.php?t=580057
I opted for the short head tee since I didn’t like the looks of the hole where the flybar could have gone on the stock head tee and I liked lowering the disk. I also opted for aluminum pulleys just because I liked the looks of them as well.
Finally which pinion to use. It comes stock with a 16 tooth version but I opted for a 15 tooth for longer flight times. Only problem is that I ordered a 15 tooth for the 500 size Protos, like a dummy, so I am using the 16 tooth, for now.
The Mechanical Build:
Do NOT follow the manual and put together the servos and bearing blocks first. Put together the frames and bearing blocks aligning them with the main shaft as you go. Once you have the frames and bearing blocks aligned and tightened, proceed to tighten screws on the rest of the frame and add the servos. (make sure you have the bearing blocks properly spaced for your servos though)
If you want to mount the DS95s using 4 screws rather than 2, you will need to do some work. I widened each mounting hole with a rat tail file on the DS95s to allow the screws to fit properly. I had some stainless screws laying around that I sell with certain products so I used them to mount the servos and all my aluminum parts. I'm not usually into bling but they do look pretty nice IMHO. Also, I had to lengthen the middle bearing mount slots in the frames to allow the middle bearing mounts to shift low enough for the DS95s to fit in properly. Its much easier to just mount them with 2 screws and I'm sure they work just as well. I'm just a glutton for punishment I guess.
Note: The frame sides are not identical. Make sure the holes next to the boom blocks are on the correct side.
This thread outlines everything you need to know to get your bearing blocks aligned.
I highly recommend the aluminum bearing blocks.
https://www.helifreak.com/showthread.php?t=593742
For the FBL head, use the long spindle and wide spindle spacers. Its normal for the grip to be a little notchy with no load. Thread here:
https://www.helifreak.com/showthread.php?t=601352&highlight=notchy
When you put together the plastic halves of the tail assembly, you may find that it will not close flush. I tried different bushings on the shaft to make everything the right width but ultimately I didn’t have anything laying around that would make it perfect. I had been told not to tighten the two halves together snugly and I assume if it had it would have deformed them. As an alternate approach, I put in a spacer between the halves on the rear screw. It seemed to solve the problem and I’ll look for vibes later.
When you build the tail slider, make sure everything slides smoothly. If there is any binding whatsoever, takes steps to resolve it. On, mine, the arms that push/pull the slider were binding just a little. I reamed out the two holes in the arms with a 1/16” drill bit in a hand chuck. Do each hole from the outside rather than trying to align the bit and go the whole way through both. Don’t ream out the inside holes on the edges of the slider since they hold the pin in place.
There is not much to note for the rest of the build other than the link lengths for the cyclic servos were changed from 17mm to 18.5mm in the new manual. Mine links ended up spot on and my swash perfectly level with NO adjustments. That was a first!
Other than the bearing blocks, the mechanical build was sweet. I like the innovative belt design and how quiet it makes the drive train along with how simple it makes the overall design. I’m still a bit worried about the pinion/OWB. Time will tell how that holds up in my particular build
I really like that there are three bearings on the main shaft and that the motor has a counter bearing as well as the sliding motor mounts. These are all things I like to see but seldom see on small helis.
The socket head screws are high quality and much better than the button heads used in some designs.
I also like the other little niceties like the screws ends for the CF tail rod linkage and the holes pre drilled at the right locations in the frame for wiring. I only had to drill one extra hole during the wiring job.
Overall, other than the plastic bearing blocks, I thought the mechanical build was very well done.
One nit: I love the look of the stock canopy but I’m not that thrilled with how difficult it is take it on and off. I may well replace the stock mounts with some quick connects but I hate to add any more weigh to a heli that’s already a tad tail heavy.
Update from dr dremel: For easier canopy removal/attachment you can smear a little silicone/oil on the posts. I also glued the rubber grommets in the canopy so they do not deform during install. Further more I would recommend to coat the ears of the canopy (from the inside) with a thin layer of epoxy or similar to prevent cracking.
Update in response (Thanks Doc):
The Electrical Build:
Since my earliest builds, I have always followed the following set of rules. That proved to be very easy with this build.
1) Isolate high current noisy components (Main Battery, ESC, and motor) from low current parts (Antenna, Battery, gyro, gyro controller, and receiver)
2) Protect all components from crash damage
3) Make heli parts you replace regularly easy to replace (Bottom Plate, Tail boom, belt, tail pulleys, etc)
4) Keep wiring runs short
5) Protect all wiring
I’m always a bit leery about static buildup with belt designs, but I was convinced by the helifreak community that static is not a problem with this heli. My guess is that the belt from motor to tail keeps the entire heli at the same potential so no hot spots of electrical potential are able to build up at inopportune locations. Thread confirming no need for anti-static strapping here:
https://www.helifreak.com/showthread.php?t=580323
I opted to use the stock ESC since it seemed up to the task and the community likes it. It also fits well in the intended location under the battery mount. The one drawback to this mounting is there is no easy way to disconnect one motor wire for safe maintenance. I was tempted to run the motor wires along the outside so I can get to them, but I like the clean look of hiding them for this small heli.
Update thanks to dr dremel: Instead of disconnecting the motor leads I just remove the belt from the pinion. If you slide the belt down from the maingear there should be enough slack. One of the nice details IMHO, no pinion mesh to mess up
The main point of this build was as a trainer so I knew I was getting the Baverian Demon well before I even knew which heli I was going to build. I basically built a heli around the BD. It turns out the wiring to the BD is very simplistic like the VBARs I am used to so it allowed for a very basic wiring task. I did use a custom lexan mount as a more solid mounting surface that was big enough to accommodate the BD.
I took Capi’s lead and used heat shrink to protect my wiring for this build instead of braid. Both do a nice job and I do like how the shrink keeps the wires in place with no stress on the BD.
I like that it will be really easy to connect the PC line to the BD when I am doing adjustments.
I used one satellite for now but I may add a second underneath if I have any connectivity problems. I used the 3 position Aux3 switch on my JR X9503 transmitter to control the bail out feature but I’m up for suggestion of a better place for that. I still have some homework to do on that one.
Edit: Found a great thread on this:
https://www.helifreak.com/showthread.php?t=479597
Left Side
Right Side
With Canopy
Thanks to MSH for a design well done and all my helifreak friends that helped to make this build go so well. Building this was a blast and many thanks to Bill at
msh-direct.com for feeding my addiction!
I hope this build was informational and fun and hopefully it will make other peoples builds go more smoothly.
Rick
Some of my other builds:
Ravenous Rush 750 Build
https://www.helifreak.com/showthread.php?t=507842
Sexy TREXY 500 Build:
https://www.helifreak.com/showthread.php?t=69894
Lovely Logo 400 Build:
https://www.helifreak.com/showthread.php?...71#post4743971
Wiring Sheathing Tutorial:
https://www.helifreak.com/showthread.php?t=501879
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 02-28-2014, 04:21 PM   #2 (permalink)
Nice write-up!
Good to hear you liked the build. I also loved how straight forward and easy it all fits together.
I do not see why the tailbox would be problematic, but i feel it is a bad idea to fit it loosely. Mine snapes together fine and i could push the tailshaft through the bearings without resistance, so its confirmed it all lines up. It was actually a little too wide and put an extra shim om the tailshaft to give a slight pre-tension outward on the tailshaft bearings.
I assume you will spool up without mains to make sure it runs vibration free?.
You seem impressed now...lets see your reaction when you fly it... hehe
MSH miniPRTOS & PRTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 04:27 PM   #3 (permalink)
Originally Posted by sp00fman View Post
Nice write-up!
Thanks!
I spun it up on my bench without the mains and it was smooth as silk. It was so unusually quiet it was almost not scary (like it should be, lol).
I got to hover it out front last week on a warm day but I'll have to wait for winter to break to get some real flight time on it. I was VERY impressed with the initial hover!
Rick
Old 02-28-2014, 04:41 PM   #4 (permalink)
Member
How did you mount the custom gyro mount, Rick?
Old 02-28-2014, 04:50 PM   #5 (permalink)
Good question Bob. I didn't photograph that. With some of that high octane 3M sticky tape. It wedges pretty well between the frames but the tape locks it down. I considered screws but decided this worked fine.
Rick
Old 02-28-2014, 04:51 PM   #6 (permalink)
Member
That 3M grey stuff is solid for sure!!
Old 02-28-2014, 04:52 PM   #7 (permalink)
Old 02-28-2014, 06:03 PM   #8 (permalink)
Wow that is some nice and clean wiring, mine looks nowhere near as clean as that...
Well a big part is that I didn't shorten the servo wires or the BEC wire at all.
I've put some electrical tape on the wires in contact with the carbon plates, I don't think i'd have enough heatshrink (of the correct size) to protect all the wires on my mini
"Beater" Mini Prtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 06:13 PM   #9 (permalink)
Thanks. I enjoy making them neat like that. Its part of the fun for me. I savor the initial build but I hate rebuilds. It just seems like punishment to me.
Rick
Old 03-01-2014, 05:30 AM   #10 (permalink)
Rick
Well it was my first build so I mainly did as the manual told me, it was after I finished the build that I realised there might be an issue with servo wires touching the carbon frames
Since I couldn't be bothered to rebuild everything I just put some electrical tape where it touches
In my next build, i'll probably work more on the wiring during the build.
Old 03-01-2014, 08:10 AM   #11 (permalink)
No problem with that. It should work fine.
Rick
Old 03-01-2014, 09:57 AM   #12 (permalink)
Very nice build summary, lots of updated info This thread begs to be a sticky with all the links to further discussions, would be very useful for those interested/new to the Mini Protos!
Small additions: For easier canopy removal/attachment you can smear a little silicone/oil on the posts. I also glued the rubber grommets in the canopy so they do not deform during install. Further more I would recommend to coat the ears of the canopy (from the inside) with a thin layer of epoxy or similar to prevent cracking. (ignore if you already did this, pics are not showing for me?)
Re: motor disconnect for safety: Instead of disconnecting the motor leads I just remove the belt from the pinion. If you slide the belt down from the maingear there should be enough slack. One of the nice details IMHO, no pinion mesh to mess up. Consequently I have buried my motor cables neatly under the esc.
Looking forward to your flight report!
2x MCPX I Gaui X1 I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 03-01-2014, 10:05 AM   #13 (permalink)
Love your build threads Rick. Great work as always.
[Oxy5 Meg / 12S] [JR Vibe 55] [Align 700N] [Oxy4 Max]
JR E12 ITO / 12S] [Goblin 770C / 14S] [800Xxtreme / 16S]
OXY rep
DCflyer is online now        Reply With Quote Quick reply to this message
Old 03-01-2014, 11:07 AM   #14 (permalink)
Thanks for the updates. I went into my first post and added that great info. Great idea with the belt, and no I had not done the grommet work on the canopy. I will now! I will also stick the thread.
Thanks DCflyer. I appreciate the nice words. I enjoy doing the build reports. Thinking about what I plan to write always helps me do a better build.
Rick
Old 03-01-2014, 11:16 AM   #15 (permalink)
Stuck
Old 03-01-2014, 01:20 PM   #16 (permalink)
How's this Doc?
Old 03-01-2014, 02:49 PM   #17 (permalink)
nice, looks like my canopy
Also pics are showing up now. Wow what a clean build, congrats Rick! Too nice to crash (almost).
Old 03-01-2014, 04:03 PM   #18 (permalink)
Thanks, No crashes allowed. Bail out baby!
Old 03-01-2014, 09:09 PM   #19 (permalink)
The Capi
Nice Rick, glad I could convert another I do usually leave the last inch or so of the leads exposed tho.
Old 03-01-2014, 09:32 PM   #20 (permalink)
Yeah, I hate that.
I even considered covering the rudder servo wire but I decided to leave it nice and flexible.
Rick
