Like Tree3Likes
Old 04-14-2014, 05:58 PM   #61 (permalink)
Originally Posted by fabian1675 View Post
... I don't have one of those fancy gopro camera. I'm glad to hear that you're finally enjoying yours, nice flying
Thanks! Glad to hear yours is flying well also.
I do not have one of those fancy go pros either....I don't even have one of the ever popular key-chain style cams... You know what I do? Realy hill-billy like but I just stick my phone to my hat using some styrofoam and rubber bands. Works pretty well and you can uploaed to youtube right away and delete from your phones memory.
wsntme is offline        Reply With Quote Quick reply to this message
Old 04-16-2014, 07:20 PM   #62 (permalink)
My package came from China today!
I might try to load new firmware on it tonight, well see. Not sure if I need seperate power of not, dont have any servos for it yet either.
I might be needing help from you guys soon, well see. I hope its as easy as it seems.
For the Vbar software are you guys using the regular mini vbar software of the sillverline version?
jaybyrd is offline        Reply With Quote Quick reply to this message
Old 04-16-2014, 08:27 PM   #63 (permalink)
Are you guys using vstabi? Application or something else?
Old 04-16-2014, 08:58 PM   #64 (permalink)
yes, we're using the Vstabi software from Mikado. You have to register on their site and then you can log-in and download it. No cost, you just have to register.
This unit is a clone and therefore using Mikado firmware most likely without proper licensing or approval from Mikado so I personally would not attempt to update it. It works as is and is running 5.3.4b pro already. An update *could* leave you with a brick....I'm no expert so this is mostly speculation. Risk it if you want.
To program the unit it does need to be powered up and hooked to your USB connection.
Old 04-16-2014, 09:01 PM   #65 (permalink)
Default 130X with GY280RX
Ya that was my issue, no esc battery power yet.
I downloaded it n messed with the simulator part.
Old 04-17-2014, 04:33 AM   #66 (permalink)
HI,
I have a 130x with MH rotary servos and quantum motor. I am very interesting by this GY280RX (I have a DX9 radio) with a CC talon 15A. The problem is the servos plugs. How can I do with the MH rotary servos ? is it OK with the GY280RX plugs ?
sorry for my bad english language, I am french !!!!
derailleur is online now        Reply With Quote Quick reply to this message
Old 04-17-2014, 06:00 AM   #67 (permalink)
you simply have to put some new ones on. You can solder on leads with the connectors already attached or you can actually place just the connectors on. Both of the methods are listed on the previous page well as links to the parts.
pmerritt is offline        Reply With Quote Quick reply to this message
Old 04-17-2014, 06:38 AM   #68 (permalink)
Oh yes, in page 3, I didn't saw. Thank's a lot pmerritt. I think it's the next upgrade for my 130 X
Old 05-07-2014, 01:41 PM   #69 (permalink)
Isn't one of the MH rotary servos reversed for the 130X original board? Does that matter, or can that be reversed again in the vstabi software?
Tom
Synergy E7SE / SAB Goblin 630C / SAB Goblin 500 / Logo 550SX v2 / Blade 700X
Blade 180CFX
tomatwalden is offline        Reply With Quote Quick reply to this message
Old 05-07-2014, 01:54 PM   #70 (permalink)
You can reverse the servo in any good fbl unit software. Not an issue!
scott s is offline        Reply With Quote Quick reply to this message
Old 05-07-2014, 02:19 PM   #71 (permalink)
Like scott said, not an issue. I thought I answered this question with my last pm to you an hour before you ask it here...
Originally Posted by wsntme View Post
With the gy280 or any fully adjustable FBL you won't need to worry about having one of your servos reversed since you can do this within your setup. If using the AS3x board then you would indeed need to reverse one of your servos since the stock board gives you no adjustability other than gain settings.
Old 05-07-2014, 02:35 PM   #72 (permalink)
You did. I'm just reading a lot and asking a lot of questions. Afraid not all the information is soaking into my brain quite as quickly as it should ... Information overload!
Tom
Blade 180CFX
Old 05-07-2014, 02:39 PM   #73 (permalink)
Understandable! Kind of why I haven't taken the dive into FPV...just a whole 'nother bunch of stuff i gotta learn/read/research
Old 05-08-2014, 07:53 AM   #74 (permalink)
Has anyone experimented using the GY280RX and suitable ESC, but with the standard servos? l was thinking of trying this initially - more while I wait to see what the lynx frame may offer - so interested to know if the standard servo's have the resolution/mechanical gain to work?
Now: OXY2 || OXY2 || OXY3 || OXY4 ||
Then: Lots
TEAM LYNX/OXY
MinskUK is offline        Reply With Quote Quick reply to this message
Old 05-08-2014, 01:28 PM   #75 (permalink)
Default Some Video
I had a nasty crash last week, inverted tail in, broke the boom and cracked the case of my tail servo (DO3013). Got the boom replaced and servo with (D05010). Did a couple of flight, noticed my tail is wagging. The difference with this set-up compared to before is the servo and tail blade now KBDD vs stock and I'm also getting some slight friction on my tail push rod. I'm sure the friction has something to do with the wag and I'm assuming this servo does not like the tail settings I had from the previous servo, anyways I finally was able to take some video. Here's the first flight after repair.
130X with GY280 (3 min 36 sec)
and here's the second flight
130X -GY280 test (3 min 41 sec)
I don't always fly but, when I do, I fly Gaui "X1" and "X1.5"
fabian1675 is offline        Reply With Quote Quick reply to this message
Old 05-08-2014, 01:43 PM   #76 (permalink)
Sweet, nice flying! Thank you for sharing. iIm still not good enough at the inverted tailfirst circles to try them IRL but I'm working on it since I think they're cool, good work.
It looks like whatever mount you went with works well at holding your phone . Something I've started doing to help with recording quality is to fix the focus once I start recording, on my S4 I hit record and then tap the center of the screen to focus on my heli while I'm a few feet away.
Old 05-08-2014, 08:27 PM   #77 (permalink)
Thanks for the tips I was wondering on how to focus the camera to heli. I'll try that next time.
Old 05-10-2014, 03:17 PM   #78 (permalink)
Yes can anyone give feedback who is running stock servos? Do you have to change the servo plugs on the stock servos or do they plug right in?
180 CFX - 600SX - Goblin 380 - Goblin 570 - Goblin 630c - Vbar Control
vertico is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 03:24 PM   #79 (permalink)
You would have to change the plugs, they are different. Why anyone would upgrade to a full function FBL and stick with the stock servos is beyond me though . You don't have to get $30/ea hitecs (I have 5 blue arrow 3013's that all together cost less than one of my Hitecs)
Old 05-10-2014, 03:47 PM   #80 (permalink)
Good to know. I only want full function fbl so i can get some piro comp and run gov off the esc. i prefer to keep things simple without upgraded frame, servos blah blah blah. I fly the snot out of my 130 and i doubt tiny servos are going to be durable for me where the stock servos are quite durable in crashes. Not saying i dont have upgrades because i do. I just like moderate modification only where needed. My 130 flys great with the stock servos but if i could get piro comp it would be dreamy.
