SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters |
02-25-2017, 08:23 PM | #161 (permalink) |
What's Your 570 Setup!
Red And Black Carbon Edition
Vcontrol and Neo, Pro Rescue Xnova 4025 1120kv (23t pinion) Headspeeds/Bank1-2050, Bank2-2180, Bank3-2300 Hobbywing 100A v3 with Mikado UI Current Sensor Scorpion Tribunus 120a SBec! On its way to pair with the Vcontrol and test all the new goodies out. 570 Thunderbolt, 570 Zeal Main Blades Rail 96 Tail Blades RJX HV Cyclic and Tail Evo Power 6s 5000mah Pulse 6s 5500mah
V... |
07-04-2017, 04:55 PM | #162 (permalink) |
Hello,
My setup - pyro 650 - 62 / 21T pinion - Hobbywing 130A hv v4 with telemetry by msh Brain 2 + MZ24 Hott - Brain 2 - 3x rjx Fs 0521 HV on cyclic - MKS BLS 980 HV (tail) - SAB 3D 570 blades - Lynx option Upper tail case - Lipo : 2x Zippy compact 3300mah 6s 60c Best regards SImon |
09-29-2017, 12:57 AM | #163 (permalink) |
My setup
- HKIII-4025-550 12S / 23 T pinion (2500-2600 rpm) - Castle Phoenix Edge 120A hv - Vbar v5.3 pro - 3x TORQ 9180 HV on cyclic - TORQ 9188 (tail) - Zeal 570 blades - WR BEC (20A) - Lipo : 2x 3300mah 6s 65c |
10-15-2017, 03:04 PM | #164 (permalink) |
I will soon buy a 570 KSE.
At home i have a Scorpion HK-4025-740 kv engine. This engine is for max 10s , could it work ? i was thinking with 3300mAh 65-130 c and, a 130A ESC and 19 pinion ? I do some very beginners soft 3D, and i would like to get into tic toc and rainbows. Will it have enough power ? or should i go for other engine and 12s right away ? Thanks |
10-16-2017, 09:24 AM | #165 (permalink) | |
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX |
10-16-2017, 01:35 PM | #166 (permalink) |
Thanks for the answer !
Because my post is a bit out of topic, i have created a serperate thread. And yes, i forgot to mention, i would like to run it on 10s |
10-30-2017, 07:57 PM | #167 (permalink) |
Just started a 570 build. Hope to be able to maiden it by the weekend.
Flight Style: Scale / Sport FBL System: iKon 2 (also have a Naza H coming in) Transmitter: Spektrum DX9 Reciever: SPM4649T & 2 DSMX Satellites Motor: Xnova 4025-1120Kv Pinion: 22t Target Headspeed(s): 2200 / 2550 ESC: Hobbywing Platinum 120A V4 Governor: iKon BEC: Hobbywing Cyclic Servos: BK 7001 Tail Servo: BK 7005 Main Blades: SAB 570mm Tail Blades: SAB 95mm LiPos: Gens Ace 6s 5000mah
SAB / Jeti / Spirit / Xnova / YGE / Pulse LiPo |
01-07-2018, 03:49 AM | #168 (permalink) |
Here's mine:
Goblin 570 running 6s FBL: VBar NEO Motor: Xnova 4025 - 1120kv ESC: HobbyWing 130A V4 BEC: HobbyWing built in Cyclic: BK DS-7002 Tail: BK DS-7006 Pinion: Stock 21T HS: 2000 / 2200 / 2400 Gov: VBar NEO Main Blade: Stock Tail Blade: Stock Batteries: Revolectrix 6s 4500 Pitch: +/-14 deg Training flight time: ~ 4:00 Show off flight time: ~ 2:30 Goblin 570 KSE running 12s FBL: VBar NEO Motor: Scorpion HKIII 4025 - 650kv ESC: Scorpion Tribunus 130A BEC: Scorpion built in Cyclic: BK DS-7002 Tail: BK DS-7006 Pinion: 24T HS: 2200 / 2400 / 2600 Gov: VBar NEO Main Blade: Stock Tail Blade: Stock Batteries: Revolectrix 6s 3300 x2 Pitch: +/-12 deg |
01-07-2018, 01:40 PM | #169 (permalink) |
Slow Thumbs, could you please share the ready to fly weight for both?
SAB: G420, G570, G660 |
01-12-2018, 02:31 PM | #170 (permalink) |
Just ordered a 570 KSE to run 7s
FBL: VBar NEO Servos: BK 7002 on cyclic and 7006 on tail ESC: CC Phoenix Edge 130 BEC: 2 x 2s lipo straight in to FBL Motor: TBC but thinking the Xnova 4025-1120 and 18T pinion should be a solid choice for 7s on the tri blade head Blades: Stock Packs: Revo 4400mah |
01-13-2018, 03:23 PM | #171 (permalink) |
My 570 6s setup
Flight Style: 3d / hard 3d FBL System: Brain 2 Transmitter: Graupner MZ 24 Reciever: GR16 Motor: Kontronik Pyro 650 1030kv later: idem competition pyro Pinion: 23t Target Headspeed(s): 2550 tr/mn ESC: Hobbywing Platinum 120A V4 / I wait for a graupner T160 Hv Telemetry with Brain 2 Governor: Hobbywing BEC: internal Cyclic Servos: Outrage Torq Bl 9180 HV Tail Servo: Mks BLS 669 HV Main Blades: SAB Thunderbolt 570mm Tail Blades: SAB 95mm LiPos: Gens Ace 6s 5000mah 60c / KD Lipo 6s 5200mah 60c / DInogy graphene 6s 5000mah 70c Flying weight : 2520gr without Lipo / 3300gr with lipo flight time : 3 mn 30 - 4mn Wonderfull Heli : powerfull, agile, smooth |
04-18-2018, 10:25 PM | #172 (permalink) |
Goblin 570: Canomod XLC Carbon Ferrari combo
Motor: Scorpion HKIII-4025-650KV Motor Pulley: 21T ESC: Scorpion Tribunus 130a Bec: Internal @8.0v Governor: Vgov Cyclic servos: Xpert Minis MM-3301-HV Tail servo: Xpert Mini MM-3302T-HV FBL/RX: Vbar Neo Lipos: Revolectrix Blend 435 12s 3200mah w/ec5 Main blades: Sab 570TB Tail blades: Sab TB Target Headspeeds: 2000rpm - 2200 - 2400 14 Degrees Radio: Vcontrol Upgrades: 19T Tail Pulley Big Belt/Pulley Lynx Dampers Lynx Tail brace Lynx tail control horn Sab Delrin main gear Heli-Option Tail Control Rod Sab Servo Horns Modified Sab 500 sport landing gear Sab 500 mini servo supports Lynx Mini tail servo support AUW: 7lbs 4oz / 3.288kg
https://www.youtube.com/channel/UCTN...O1AJMoBiO8hX1g Last edited by Martinshelis; 04-26-2018 at 09:27 AM.. |
06-04-2018, 08:38 AM | #173 (permalink) |
Goblin 570 SPORT
Weight without lipos 2.75kg Quite heavy...Flight time about 4 minutes
Goblin 570, HW platinum 100A HV v3, Quantum 4125 560kv, 24t pinion, Align bl815h cyclic, KST DS515MG tail, Ikon 2 , 12s 3300mah, ~ 3.8 kg Gaui x3, xnova 2618 1860kv, HW 50A, Ikon Taranis qx7 |
06-10-2018, 03:51 PM | #174 (permalink) |
SAB Goblin 570 Sports Yellow
Helicopter: SAB Goblin 570 Sports.
Motor: Scorpion HKIII 4025-1100 KV Motor. ESC: Hobbywing 130 V4 Platinum ESC. Servos: Bk Servos 7002/7006 Battery: KD Lipo 6S 5000 Mah 70 C Gold Edition Transmitter: Mikado V-Control FBL: Mikado Vbar NEO Lubrication: DryFluid Extreme Lube. Connectors: Rcproplus Suprax S7 Connectors 2450 RPM / Pitch 13.
Team Pilot SAB Heli Division. Team Pilot Scorpion Power Systems. Team Pilot BK Servos. Team Pilot KDlipo Batteries. |
09-04-2018, 05:21 PM | #175 (permalink) |
Model: SAB Goblin 570 Sport
Motor: XNOVA 4025-560KV ESC: Scorpion Tribunus 12-130A FBL: Mikado VBar Neo with Vlink Transmitter: Mikado VBar Control Extra: Mikado Battery ID Sensor Cyclic Servo: MKS HBL-960HV Tail Servo: MKS HBL-990HV Main Blade: SAB 570BT (stock) Tail Blade: SAB 95BT (stock) Pinion: 23T Battery: 2xHRB 6S 3300mAh 35C Upgrade: H0321-S SAB Quick Release Canopy Pin H0398-S Aluminum Cooling Motor Mount LYX1510 Lynx Heli Goblin 380/500/570 Precision Tail Bell Crank Lever (Black) Weight: 2795g, 3855g with battery |
09-05-2018, 04:41 AM | #176 (permalink) |
Mine just maidened last Sunday.
570 Sport Orange Flight Style: Scale / Sport FBL System: Brain 2 HD (c/w inbuilt bluetooth) Transmitter: Spektrum DX9 Reciever: SPM4649T & 2 DSMX Satellites Motor: Scorpion 4025 550kv Pinion: 21t ESC: Castle Phoenix Edge 80HV Governor: Brain Receiver Pack: 1300mah 2S Gensace (future will be 2200mah) Cyclic Servos: BK 7002HV Tail Servo: BK 700HV Main Blades: SAB 570mm Tail Blades: SAB 95mm LiPos: Gens Ace 6S 45C 3300mah x 2 (12S setup) The orange is an absolute stunner in the air. Images on line don't do it justice.
Trex 450 Pro v2 FB, Trex 500 ESP DFC Neo, Trex 600 DFC Neo, Trex 600E FB, Goblin 570 Sport with Brain 2 DX7 & DX9 Mode 1, Phoenix (free crashes, yahoo!!) Citizen 272 |
09-07-2018, 08:31 PM | #177 (permalink) |
Goblin 570 Freedom Edition #19
Flight Style: Mild 3D/Big air FBL System: Brain2 Transmitter: Spektrum DX18 Reciever: SPM4649T & 2 DSMX v2 Satellites Motor: KDE600XF-1100-G3 Pinion: 22t Target Headspeed(s): 2250 ESC: Kontronik Kolibri 140 @ 84% Governor: Kontonik BEC: Kontronik 10amp with Spektrum cap SPM1600 @ 8.4v Cyclic Servos: Xpert R2 with 17mm Secraft arms Tail Servo: Xpert R2T with 17mm Secraft arm Main Blades: VTX 557 Tail Blades: Rail 95mm LiPos: Gens Ace 6s 5500mah 60C x three sets and trays Upgrade HS tail pulley Canopy quick release Alum servo mounts BK tail rod thread mod
Gaui X7 FZ, Gaui X7 Formula, Gaui X5v2 Formula , Gaui X3 6S , Trex 800 DFC, Trex 700E, Trex 600N, Goblin 700 Tri-oblin, Goblin 570 Freedom Edition #19 .... MSH Brain, Spektrum, MKS, Xpert, Scorpion, Kontronik, KDE, Helix, VTX Last edited by Chigoe; 09-07-2018 at 08:43 PM.. |
12-08-2018, 04:27 PM | #178 (permalink) |
My Goblin 570 Sport Orange
Xnova 4025-1120kv Hobbywing 120a V4 BK DS7002hv cyclic BK DS7006hv tail Ikon2 w/ BT aluminum version Spektrum 4649T with 2 Satalites Gene Ace 5000mah 60c VTX 557 mains SAB 95mm tail Headspeeds 1800/2050/2300 Flight style: sport/just learning Awesome Heli!
XL Power Protos 380 Evo 0xy4 Max Goblin Kraken 580 Goblin Raw 700 KSE Ix20 Ikon2 Last edited by Ravmano7; 12-19-2018 at 02:18 AM.. |
02-13-2019, 04:02 PM | #179 (permalink) |
sab 570
so i finaly got the sab goblin 570 switching from nitro to electric so any help would be great what do you guys recommend for the fly bar system ive ben looking at the
the ikon besides whats listed what else would i need i have a spectrum radio and a futaba 14sgh radio have not desided witch radio to go with yet sab goblin 570 Drake edition motor going with the Scorpion HKIV-4025-1100KV lipo PULSE 5500mAh 6S 22.2V 65C - LiPo Battery Bert Kammerer FULL SIZE CYCLIC SERVO DS-7002HV Bert Kammerer FULL SIZE TAIL SERVO DS-7006HV Last edited by daveisdiving; 02-13-2019 at 11:26 PM.. |
