Go Back   HeliFreak > R/C Electronics Support > OpenTX Radios
OpenTX Radios OpenTX Radios Discussion and Support Forum
Old 04-01-2014, 09:52 AM   #1 (permalink)
Default D4R-II and Mini VBar via CPPM: Possible?
Has anyone gotten a D4R-II to talk to a Mini VBar using the CPPM connection? There's not much out there about it other than not trying to use all 8 channels without a firmware update. I have used this RX on a multirotor with KK2.1 board, so I know it's properly configured for CPPM output.
I tried for over an hour to get it to talk without success. It's no biggie if it won't work, I can always use a newer S-Bus RX but I had one and it's soooo tiny! Perfect for the Mini Protos.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 04-01-2014, 11:16 PM   #2 (permalink)
I know its not your exact config but I just got a dr4-ii and made it work with my robird but am only using 6 channels on my taranis. Someone else here has mentioned the robird having issues with 8 channels.
Im surprised your kk2 works with the dr4-ii and 8 channels, I have heard of issues with those two working together but only at stick extremes.
FrSky D4R-II PPM Problems. Investigation and Solution with a KK2 and Bitscope. RCHacker #23 (19 min 40 sec)
I did buy the USB setup to upgrade the dr4-ii firmware and will do it this weekend (have 4 more dr4-iis in the mail). I wanted to make it work for 6 channels first to simplify the inital setup and learning curve with the taranis.
Do you need 8 channels (Im not familar with vbar at all)?
Perhaps you can try 6 channels at first to see if using 8 channels is really the problem.
MCPX BL, 130X, 180cfx, 300x,300cfx, Compass Warp 360, ZMR250 FPV, EMax 250FPV, Morphite FPV,Taranis
linklemming is online now        Reply With Quote Quick reply to this message
Old 04-02-2014, 10:14 AM   #3 (permalink)
I've got it set to 6 channels, and it worked fine with the KK2.1 (Steveis firmware). I too have read about the issue with the stock firmware and more than 6 channels, but that doesn't seem to be the issue here. I just couldn't get the VBar to recognize it at all, it saw no signal from the receiver.
I think the VBar just doesn't recognize CPPM.
PS: That's a great video! Thanks for the link!
Chris Boultinghouse
Old 04-02-2014, 05:26 PM   #4 (permalink)
I use the D4R-II on my Warp in CPPM mode no problem. Okay it's a Fubar on there, but I have Vbars too and it's the same. What a fab little Rx it is.
I set the Taranis to D8 mode, and channels 1-6 only. I bound it, set fail safe, jumpered across the signals of channels 3&4 on the receiver and set the Vbar to single line (futaba, Jetti, Graupner, Hott). Plugged channel 1 on the Rx into RXC on the Vbar as per Sbus and it worked first time.
That's all I know.
Current fleet: Goblin Thunder Sport, Trex 700L, Logo 600, Trex 500 ESP, HiSKY HCP100S - Vbar Control - 5" and 3" FPV racing quads and a Taranis
Next heli(s): Logo 550, Logo 700 or a maybe an XL power Specter
Bigpops is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 10:12 PM   #5 (permalink)
Hmm... OK, I tried that and got nothing. Apparently I've done something stupid, so I will try it again!
Thanks!
Chris Boultinghouse
Old 04-03-2014, 12:40 PM   #6 (permalink)
I have a spare D4R-II, so I'll rig it up on the bench tonight along with a new model in the Taranis and see if I can recreate my success.
I'll let you know how it goes and what snags I hit, if any.
Old 04-03-2014, 12:56 PM   #7 (permalink)
Thanks, I appreciate that! I have another heli to finish tonight for an event (tomorrow!!) so I may not have time to go back to my Mini Protos and try it again before the weekend.
Chris Boultinghouse
Old 04-03-2014, 01:35 PM   #8 (permalink)
Right, I just set up the other Rx.
Other than having the cable plugged into the wrong port at first (I put it in any to bind it), I did get it working as it should. I even created a new model from scratch and entered all the mixes myself rather than copy an existing model over then edit it as I usually do, and it all worked as it should.
