Go Back   HeliFreak > Multi Rotor Support > DJI Multirotor Support > Phantom Multirotor Support
Phantom Multirotor Support Phantom Multirotor Support
Old 07-19-2014, 03:01 PM   #41 (permalink)
Default Phantom vision +
Got the same problem with my phantom, i`m using Samsung S4 .
Preview quality
640x480/30fps no way
640x480/15fps open field ok . around buildings and tree`s then it flickers and get stucks
320x240/15fps all OK
Snopsi is offline        Reply With Quote Quick reply to this message
Old 07-19-2014, 04:54 PM   #42 (permalink)
Default Loss of camera picture
HI all. yust wonted to post my Experience
Got the phantom 2 vision +
phone samsung S4.
On preview quality
640x480/30fps picture yust get stuck
640x480/15fps open fild it freezes time to time . Around building and tree`s the picture freezes alot.
320x240/30fps all ok
320/240/15fps all ok .
Old 07-19-2014, 07:05 PM   #43 (permalink)
Every thing except video, just a rotating wait icon
Mine worked fine when received from UAV products, just not a few weeks later
I can rotate the camera, read all parameters, take Picts and vids.
Help!
Davekrek is offline        Reply With Quote Quick reply to this message
Old 07-19-2014, 09:56 PM   #44 (permalink)
What kind of phone or iPad?
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote Quick reply to this message
Old 07-22-2014, 08:10 AM   #45 (permalink)
Tested
iphone 5, 5s
iPad mini, iPad with retina display
Reset the iphone 5 and the iPad to stock, still no video !
Dave
Old 07-22-2014, 02:54 PM   #46 (permalink)
Only thing I can suggest is to again check the connectors from the camera out....
Chris D. Bergen
Old 07-23-2014, 03:52 AM   #47 (permalink)
guys i have the same problem...using a note 3 and a mini ipad latest edition...the apple holds a better image, the note 3 is pretty much usless....
PropWashThreeD is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 01:28 PM   #48 (permalink)
Same problem here. I get all the telemetry but no FPV. I've sent my off to DJI for repairs. (probably not the best idea given how well their tech support is loved on forums) but i need the FPV to work and it's the only way I know of to fix it...
-Kerberus
Kerberus is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 08:04 AM   #49 (permalink)
DJI has released a new update that MAY address your video problem.
You need to download the new Asst program, then update your aircraft.
Chris D. Bergen
Old 07-30-2014, 09:10 AM   #50 (permalink)
Sent mine in. Still waiting for answers.
-you can't FIX stupid-
AMA# 935732
Altec is offline        Reply With Quote Quick reply to this message
Old 07-31-2014, 05:39 PM   #51 (permalink)
Just tried the new software... no difference...
DJI are you out there ????
Please help !!!!
PS. Thanks Chris for trying to help
Old 08-01-2014, 02:21 AM   #52 (permalink)
Please help !!!!
We are here. I use mine with an iPad mini with the A7 processor, i.e., the retina display. The App loaded from iTunes and after the upgrade I was able to display at 640x480. I also have a S4 and it works as well. The only issue for me has been thermal shut downs because of temps above 100. I do loose video before total shutdown.
I talked to a user today that had a similar problem. We went through the entire diagnostics and could not get a display. He could take pictures and start/stop video but no picture. I recommended that he contact the dealer for a replacement. I would do the same to you.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
Old 08-01-2014, 02:39 AM   #53 (permalink)
Hey,
I have exactly the same problem.
This guy shows in the video, exactly the same:
DJI Phantom Vision Plus Problem (4 min 36 sec)
I'm pretty sure it's a software problem.
My P2V+ was working very reliable before all the recent upgrades and ground control.
(IOS7, latest app, v3.06 firmware)
ktamas77 is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 07:53 AM   #54 (permalink)
My brand new 1 week old Vision + just started doing this yesterday afternoon. Same symptoms that quite a few are experiencing. I got it right as 3.06 update came out and I went ahead and did mine during initial setup and calibration. I also have the newest version of the Vision app. I was finally able to get it to work again last night, but at this point who knows how long that will last. I'm going to contact the vendor to see about swapping it out. Guess we'll see how that goes.
Webbinator
Blade 350QX V2 / 180QX / NanoQX / 120SR / MCPX V2 / DX6i
Webbinator is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 09:12 AM   #55 (permalink)
What preview video size settings do you have in your phone?
Chris D. Bergen
Old 08-06-2014, 10:50 AM   #56 (permalink)
I'm pretty sure it was on 640 x 480 30fps. I'm going to try 640 x 480 15fps this afternoon to see what that does. Or should I just use one of the 320 settings? Thanks.
Webbinator
Old 08-06-2014, 01:21 PM   #57 (permalink)
Try the lowest resolution and see if it pops up. Then go to a higher res and see if you lose it.
Chris D. Bergen
Old 08-06-2014, 06:35 PM   #58 (permalink)
Just took the Phantom out for another flight. I set the resolution down to the lowest setting and it worked normally. I never lost the signal or had the display go dark. I'm going to bump it up another notch tomorrow evening to see what it does.
Webbinator
Old 08-20-2014, 01:42 PM   #59 (permalink)
Tested
iphone 5, 5s
Dave
Tried a Android tablet this weekend with the same problem....
Must be hardware
Old 08-24-2014, 08:12 AM   #60 (permalink)
Mine just started doing this, own it now for 3 weeks, worked fine in the beginning and firmware and app was never changed since initial setup, all are on current version.
I tried on both, my Sony Xperia phone and also my Xperia tablet, I get a picture for 5 seconds and gone, no matter what resolution or frame rate I use.
If I reboot the app when the Phantom is on, the picture does not come back. If I turn the Phantom off and back on the picture is back for a couple seconds. I think it's a hardware problem on the Phantom, but I'm not sure why it showed up all of a sudden.
Klausflorida is offline        Reply With Quote Quick reply to this message
