Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
08-02-2015, 01:58 PM | #1 (permalink) |
swash plate geometry
OK so here is my situation...
I am building a larger scale helicopter and will be using Vario hanging mechanic (offshoot of their Skyfox model) to propell the helicopter. The setup has four servos for swash... I will be using SK720 blue controller ... and currently my mechanic setup has two options. I can fit short or long ball links to the swash plate... BUT only to the sides... front and aft have to be short to work as needed. So if I put long ball links the push rods would be vertical... BUT the swash would form an elliptical shape instead of a circle. My question is... would this be a problem for the FBL controller? |
08-03-2015, 09:09 AM | #2 (permalink) |
It is probably better if you use the same for all 4 - otherwise you will have different resolution between aileron and elevator, effecting the gains and behavior for sure. if you choose on doing that you should try and compensate by taking the ball on the horn out so you maybe have similar travels for both cyclic axis.
I'm not sure about the mechanical conflicts. I can't think of any but there might be in some mixing options (I.E. elevator + cyclic + collective)
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
08-04-2015, 11:01 AM | #3 (permalink) |
I would not use 2 different length balls.
Hello binding, servo stalling, heat creating, servo failure... All in the near future. That elipse will cause you trouble. |
08-04-2015, 03:14 PM | #4 (permalink) |
ן don’t think there will be any binding, but I agree the elipse is trouble.
08-04-2015, 07:44 PM | #5 (permalink) |
Okay... Maybe a bit overboard. But 4 servo swashplates sucks for the reason that they have to be setup right to avoid and binding. Adding the elipse doesn't help anything.
08-04-2015, 10:12 PM | #6 (permalink) |
It wont be an issue if you set this up correctly. Aka make sure the servo travel values are correct between the two by changing the long/short throws to a level swash by changing servo end points. On center, top, then bottom.
If it can be done wrong, I will find a way to excel at it. |
08-05-2015, 01:20 AM | #7 (permalink) |
guys thank you for the inputs...
I was contemplating this issue for a few nights... read a few posts and a few manuals... and decided not to play with fancy setups. I will leave all the ball links the same and try to minimize the angle of the side links... I believe this would be best... gh |
