Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...) > DJI Multirotor Forum(A2/WKM)
DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM)
Old 05-16-2014, 02:12 PM   #1 (permalink)
Default Phantom 2 Vision+ - Drifting
On the first flight of my P2+ when moving it side to side / back and forth and bringing to a stop it locked in perfectly and hardly drifted.
I flew it today in a different area, went through the compass calibration and was receiving about 8 satellites but when bringing the Phantom to a halt it didn't stop immediately and drifted somewhat.
Does stabilisation work better the more satellites the Phantom sees? I would have thought 8 would be sufficient.
What's the max number of satellites the Phantom can link into?
PS - I'm in Naz mode if that is relevant.
Bazz06 is offline        Reply With Quote Quick reply to this message
Old 05-16-2014, 03:48 PM   #2 (permalink)
Since you're in NAZA mode, I've gotta ask - was your right-side switch in GPS mode (top position)? If you were in the middle position by accident, that mode disables GPS and just levels off the quad when you let off the stick.
flightengr is offline        Reply With Quote Quick reply to this message
Old 05-16-2014, 06:00 PM   #3 (permalink)
Yes. I checked that because I did wonder whether I had accidentally switched it to ATTI mode but it was in GPS.
I know that in ATTI it would continue drifting but what I was experiencing was drift and then stopping. The stop just wasn't as `urgent` as I have noticed previously.
Old 05-16-2014, 06:40 PM   #4 (permalink)
Sounds good. That eliminates the obvious.
Could wind have had anything to do with it? I've noticed that mine will drift with the wind a little bit even if I don't move around and just turn the quad around to face a different direction. The computer takes a small amount of time to adjust for the wind coming from a new direction and compensate for that.
The Phantom will declare "GPS Lock" with 6 satellites. I think the most I have seen it use is 11. Typically I see 8-10. More satellites probably don't help that much. If it's stable in a hover and will sit in one place, then you probably have plenty of satellites at work.
Old 05-18-2014, 06:14 PM   #5 (permalink)
Thanks. It could be wind.
It was a very stable day when I first flew it so maybe I had the best conditions.
I flew it again today and it appeared better. Stuck it into ATTI mode for a comparison and could noticeably see the difference.
It's very reassuring having the failsafe. A couple of times I lost sight of it and although concerned knew I could instigate failsafe if required.
It wasn't but it's a great comfort.
Something I did notice today, and I will have to explore this further, I could see the P2 about 150ft away and instigated Home Lock.
Pulling back on the right stick I noticed it go backwards but a long distance from where the Home point was registered.
Before losing sight of it I took it out of HL and brought it home myself.
It seemed as though it lost its marker.
I will have to look further into this.
Old 05-24-2014, 01:55 AM   #6 (permalink)
Did you let it complete its startup sequence. You need to wait until you are only getting one flash.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
