Old 06-25-2014, 07:37 PM   #1 (permalink)
Default Mini vbar servo brown out
For some reason, today my ESC browned out and dropped to 5v after I had it set to 7.4v.
This is a hobbywing 50a v3
It was only a few times, I thought it may be a mechanical error and had to crash land at one point.
Then It smacked into the ground after a pitch pump next flight. Bad damage, when I tested on the bench sometimes when I plug it in it reads 7.4v through vbar sometimes it reads 5.3v, i'm not sure what the problem is here?
Is this an internal BEC issue or vbar issue?
this is a gaui x3.
Gaui X3 - V-Bar
Synergy E5 Super Stretch - V bar
Kentucky
Tek18x is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 08:07 PM   #2 (permalink)
It's a BEC issue. The BEC can't react to quick changes in load
Just put a small capacitor On it. 10v 2300 should be ok.
Sent from my iPhone using RCHN
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 08:08 PM   #3 (permalink)
Sent from my iPhone using (***WARNING*** Stop Spamming Helifreak)
what do ya mean
Gaui X3 - V-Bar
Kentucky
Old 06-25-2014, 08:12 PM   #4 (permalink)
This
http://www.ebay.com/itm/271422458037
Heli's I have:
Old 06-25-2014, 08:15 PM   #5 (permalink)
Heli's I have:
Old 06-25-2014, 08:44 PM   #6 (permalink)
Default Re: Mini vbar servo brown out
FWIW, on my 450, I had to go bigger. 3300, or maybe 4700, still allowed a brownout once while hovering. I went to 10V 6800uF, and it has been ok since.
Sent using Tapatalk.
Gaui X5, iKon, Edge 100, CC BEC Pro.
Tarot 450 Pro FBL, Mini VBar, Ice Lite 50.
BL mCP X, Nano QX, FrSky Taranis, iCharger 308Duo.
RedOctobyr is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 08:50 PM   #7 (permalink)
What if I got an external BEC, the castle 10a one.
Gaui X3 - V-Bar
Kentucky
Old 06-25-2014, 09:07 PM   #8 (permalink)
You can so that. But I bet it would still happen. On 6s it doesn't put out anymore than a cc esc internal BEC.
The cap is the cheapest and easiest. It's also what the cap is meant to do. Smooth out voltage due to high amp changes.
Heli's I have:
Old 06-25-2014, 09:09 PM   #9 (permalink)
I use a 4700. And I would be happy to make one up for you and send it to you.
Heli's I have:
Old 06-26-2014, 01:11 AM   #10 (permalink)
Still at it, newb?
Seriously?.
EEngineer is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 01:15 AM   #11 (permalink)
Well dude. Since it works. I see no problem. Perhaps you might want to take a trip to the vstabi website and see the testing they did. Now unless you want to spend $150 on BEC this is the best solution.
Besides. What is a capacitor for?
Heli's I have:
Old 06-26-2014, 01:16 AM   #12 (permalink)
Originally Posted by EEngineer View Post
Still at it, newb?
Seriously?.
Down boy.... Down....
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 01:18 AM   #13 (permalink)
Still at it, newb?
Seriously?.
Ya know man. I know what works. You can sit and quote all the engineering stuff. But I know this happens to work.
I had a logo 400 browning out on the bench with a cc 100 esc. Using the internal BEC. No capacitor I could actually watch the voltage drop below 4v. Add a capacitor it stopped browning out and never dropped more than a half volt. So please explain that. I'm sorry. But I'm sick of being ridiculed and made fun of by you.
Heli's I have:
Old 06-26-2014, 06:51 AM   #14 (permalink)
I am using a Gryphon Polaris BEC, which is supposed to be decent, and still needed the capacitor. Different servos may have different requirements, of course.
Old 06-26-2014, 08:10 AM   #15 (permalink)
I run HV on all my heli's apart from the 700 F3C, for that I use the CC BEC Pro (20 amp) and a 2s lipo. I know it adds more weight but IMO the only way to get the full amps out of the BEC is via 2s, running 6s or 12s reduces the amperage output quite a bit.
Neve had any issues with the CC BEC or found the need for capacitors.
Velos 880 Neo, Logo 800 XX Vbar, T-Rex 800 Pro DFC Vbar, T-Rex 800 Trekker Vbar, T-Rex 700 Pro DFC Vbar, T-Rex 800 F3C Vbar, T-Rex 550E DFC Vbar, T-Rex 500 Pro DFC AR7200BX, T-Rex 450 Sport V2 AR7200BX, T-Rex 250 Pro AR7200BX, VController, DX9.
JohnTC02 is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 12:20 PM   #16 (permalink)
This is on a small 450 sized heli. I don't think using a second battery with a BEC is really an option here.
Heli's I have:
Old 06-26-2014, 03:53 PM   #17 (permalink)
Not that I have the same issue, but curious... do you just plug this into the mini vbar? any socket? Cap need to plug in with correct polarity?
GAUI X5, GAUI X3, GAUI 200 v2 FES, GAUI 100 FES, Blade 130x
fretman is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 04:26 PM   #18 (permalink)
Polarity does matter with the capacitor, yes. The "-" lead should be marked.
I did not have any ports free, so I could not plug it into the Mini VBar directly.
You can use a Y-cable off the VBar, with the capacitor on one port, and another device on the other.
If buying a cap to make it yourself, you can also use a servo extension cable, and solder the capacitor's leads directly onto the middle of the extension.
If you're using a receiver, and it has spare ports, you could plug it in there.
Old 06-26-2014, 04:37 PM   #19 (permalink)
Where it's grey. That's the neg side.
Heli's I have:
Old 06-26-2014, 04:39 PM   #20 (permalink)
Oh sorry I didn't realise, apologies.
