Go Back   HeliFreak > R/C Electronics Support > Gryphon Electronics
Gryphon Electronics Gryphon Electronics Factory Support Forum
Old 06-04-2014, 11:23 AM   #1 (permalink)
Default Do I need to use a switch for the gryphon quaser?
I'm running the gryphon quaser in 6s on my 12s system. I'm new to big helis and this is my first big build and I don't want to fry anything. I have a yge 90hv esc, and savox hv servos that I'm going to be running at 7.4v and an ikon flybarless unit. My question is. Do I need a switch to use this bec? I have not programmed anything yet because I am not 100% sure that I will not fry anything.
kane601 is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 01:52 PM   #2 (permalink)
No you don't :-)
Just solder power wires direct into battery plugs, and it will power up instantly :-)
I do this on all my helicopters. And it works great. :-)
RasmusDK is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 02:00 PM   #3 (permalink)
Ok cool thanks. Do you know anything about the yge 90hv? I saw a video stating that they recommend programming with a 6s battery instead of a 12s. If you do know, how safe is programming it with a 12s pack seeing as I already wired it up to the bec and have two connectors on it for the 12s system?
Old 06-04-2014, 02:46 PM   #4 (permalink)
You can use 12s for setup. But remove pinion, or blades first.
I've personally always set my lvc, low voltage cut to 10volt, then I can use a 3s lipo for setup.
This way motor doesn't have power to hurt anything.
But again, if you will use higher voltage, remove pinion, blades, or one of the 3 motor wires.
Safety first :-)
Old 06-04-2014, 04:32 PM   #5 (permalink)
Ok thanks, will be doing this a little later tonight
Old 06-06-2014, 09:30 PM   #6 (permalink)
Worked fine, no issues at all.
