The Hurricane 550 In-flight Graph database - Page 3 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 09-01-2008, 08:32 AM   #41 (permalink)
Here is a graph from my logger setup Z30 1110 kv, 75Amp Align 14,52,19,61,500mm wood at 100% flat, 2200 Zippys, hard 3D
Name:	Hurricane 28th August flight 5 Z30 1110kv.jpg
IF AT FIRST YOU DON'T SUCCEED FLY FLY AGAIN !!!!!!
Allan
papafoster is offline        Reply With Quote Quick reply to this message
Old 09-10-2008, 01:27 PM   #42 (permalink)
Default FINALLY!
Ok, I FINALLY get to post some information, horray!
Is there anyway to edit your data, remove section of time that are just blank of obvious SPIKES of BS information skewing the overall results? I tried opening the info in Access and it wanted nothing to do with it. I imported it into Excel and it's 'there' but not translated into easily usable fields.
Setup is a Gaui H-18-H SuperPig 1100kv motor, 15, 19, 50, 61 gearing, stock Gaui gears, HobbyCity Cheapy 550 Carbon Blades, Zippy 3300 Lipos, Castle 80 ESC and CC-BEC, DS821's and a Hyperion DS20GMD on the tail. Quite windy, 10-15 mph with gusts over 20 (I know, what are you THINKING?!?), 74 degrees, a few scattered clouds. For EagleTree I have the Gaui 1100 H-18H set at 12 poles and I was running at a 10.7 gear ratio for these flights:
Session one, data anomolies skewing the chart:
Session 2, note the 30 second 50% throttle run at about 1.5-2 minutes, just on the edge of starting to lift off and hover but not quite:
Session 3, I was just getting on it for fun!
Drew816 is offline        Reply With Quote Quick reply to this message
Old 09-10-2008, 02:31 PM   #43 (permalink)
Nice!
Hey..if you ever do set it up and graph it with the Z30, 1110KV, 75A Align, 14T, 42, 20 OWB, 61, 500mm RCP's at 100% flat, with 2200mAh's in series or 3000mAh 6S brick.. I'd love to see what the graph looks like doing hard 3D. That's my setup on the one hurri and I have no idea what the chart would look like.. but I am curious
Man, my hurris are flying awesome right now all dialed in s w e e t ! I'm trying hard to push my skill level without smashin' em up heheh. I've thought about getting a logger.. but the only way I would get one would be after I have enough Li-Po's.. and I can never have enough of them
Gaui H200 V2 SE / Gaui H550, 4020-910, CF, CNC / Gaui H550, Z30 1110, plastic, CNC / RCer Dragonus Elite CF 450 / JR X9303
xodarap1 is offline        Reply With Quote Quick reply to this message
Old 09-10-2008, 04:00 PM   #44 (permalink)
So I see your head speed is around 1500 RPM. Is that accurate? Have you tached it? The Gaui HS calc says you should be over 2k RPM. What's your throttle curve? So many questions!
chrise2 is offline        Reply With Quote Quick reply to this message
Old 09-10-2008, 06:06 PM   #45 (permalink)
Man I hope your HS is wrong?? 1500?? It would fly like a pig at that low HS. Are you using the brushless sensor? I use the optical sensor & apart from some erratic jumps it does at least tell you what your "actual" HS is, not a calculated guess.
Looking at the amps you're pulling surely the HS is higher?
Cheers
Graeme
Gaui Hurricane EP 550 Pro
Z20 980kv Gaui 50A ESC GY401+S9254, DS821 (cyclics) 2 x 3S1P 3200mah Kong Power (6s),
Dimension Eng SportBec, Eagle Tree V3
Spektrum DX7 (Mode 2), Phoenix sim
Graeme67 is offline        Reply With Quote Quick reply to this message
Old 09-10-2008, 06:17 PM   #46 (permalink)
I just ran your numbers through my HS calculator & if your TC is down around 70-75% it is possible for your HS to be that low.
One thing that stands out for me is the Watts don't seem high enough for the Amps your pulling. Your hovering amps are above 35 yet Watts are down below 500??
My Z20 hovers at 18A using 380 - 400 watts. Did you have really low voltage for those flights?
BTW yes you can adjust the chart to exclude blank data & limit the range of the axis. go to the chart settings tab - lower left of screen & click the axis tab. You can set min & max for each axis.
Cheers
Graeme
Old 09-10-2008, 06:40 PM   #47 (permalink)
OK here is a log from yesterday. I'm running the Z20 980kv 14t pinion 19t OWB 42 front gear & 61 rear main gear.
All flights are using 2 x 3S 3200mah Kong Power Lipos. The pack used for the first "warm up" flight, has dropped a couple of cells & you can see the voltage doesn't hold up at all. It has 178 cycles.
The 2nd flight pack was purchased at the same time & has 185 cycles & is still going strong. Did a lot of loops, stationery flips & inverted + punch outs this flight.
THe 3rd flight pack is only 35 cycles old. Same sort of flying as the 2nd flight. Notice how there really is no substantial difference between the performance of the 2nd & 3rd pack - pretty amazing I think when you consider the 2nd pack has been cycled 150 extra times!
The 2nd & 3rd flights were in st 2 with 100% - 85% - 100% TC
Cheers
Graeme
Name:	10-9-08 Hurricane 550 Z20 980 14t 3 flights Aerobatics.jpg
Old 09-11-2008, 09:53 AM   #48 (permalink)
I can't read your most recent posting Graeme, what are on each axis?
Yeah, I'm not getting this setup at all. I just installed my Z20a-980kv motor, 15, 42, 19, 61 which should get me in the 2,057 rpm range at 8 Poles and 8.99 gear ratio but the PowerPanel is showing much higher numbers. I then download the information and I'm getting totally different values, NOT what's showing up on the display? What am I doing wrong here?
Ok, so what value do you all display to show how much power you have left in your Lipos? THAT was why I bought this display...
I've not Tach'ed the blades, I was under the impression this thing would act as a poor's mans Tach as part of it's functionality but I must be missing something here. I just need to spend the $20 and buy a Tach it appears, but is there anyway to better calibrate the Brushless Sensor that I now have? I have one wire connected (I had both connected but I thought I'd clip one to see if I got different results). I'm confused why this is an issue as all frankly...
And yes, the Wattage numbers don't make any sense to me either. I'm not getting this device, I thought this thing was going to be plug and play for at least the easy stuff and it's not all adding up here.
Thoughts?
Old 09-11-2008, 10:36 AM   #49 (permalink)
I don't have one (yet) but I remember people saying that the brushless sensor wasn't very accurate BUT if you work out what HS you really have (tach etc.) then you can re-calibrate the ET to match and your results will then be consistent
Old 09-11-2008, 10:59 AM   #50 (permalink)
Same gearing/motor as you tach'd just over 2100rpm at mid stick 0 pitch (100-95-100 TC). Would like to check it again since last time there was a little more mid stick than I realized when 'dozer read the rpm.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 09-11-2008, 12:12 PM   #51 (permalink)
https://www.helifreak.com/showthread.php?t=93108
Here's my latest thread, looks like the EagleTree worked at least; too bad the Gaui is DEAD yet again. ESC or BEC are the only things that make sense to me, thoughts?
Old 09-11-2008, 05:18 PM   #52 (permalink)
Drew, on my log the LHS has Watts (orange) & Prop RPM (Green), The RHS has Amps (Purple) & Pack Volts (Blue)
Cheers
Graeme
Old 09-22-2008, 05:43 PM   #53 (permalink)
Hi, my contribution:
Gaui Stock plastic frame Hurricane with Gaui White CF 500mm blades (not so good as the black CF ones)
Z-power Z30 1110
13Tx42Tx19Tx61T (10,37 for gear ratio)
CCPhoenix 80 Gov 75%
8s A123
Alves is offline        Reply With Quote Quick reply to this message
Old 09-28-2008, 07:08 AM   #54 (permalink)
Tjena Jocke Sweden här såg att du kör med align 600l
är det bättre drag i den ?
Jag flyger med Z Power 30 Kv 110
Skulle vilja veta skillnaden
m,v,h Jocke Sweden
dabox is offline        Reply With Quote Quick reply to this message
Old 09-28-2008, 07:40 AM   #55 (permalink)
m,v,h Jocke Sweden
WTF ? Press 1 for English !!
Blade 500x , dx8
Two retired Gaui 550 hurricanes (Sold)
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 10-02-2008, 09:18 AM   #56 (permalink)
think he said he flies a Align 600 and wants to know the difference between m,v,h for teh Z30-1100... online translators can only do so much...
Hurricane 550- mCX- DX7-
AMA# 901271-
Gaui Headspeed Calc
mysticmead is offline        Reply With Quote Quick reply to this message
Old 10-28-2008, 12:48 AM   #57 (permalink)
RJ
Gaui 550 Cruiser setup: Scorpion HK3026-1000, Thunder Tiger 550mm woodies (122g each), Align 75A ESC, TrueRC 2 X 3S1P 4000maH packs (6S total), 13T pinion, 60T front main gear, 19T OWB, 61T rear main gear, 1500 rpm headspeed, TRex 600 plastic tail blades, 5 lbs. 5 oz. ready to fly.
Flight schedule: 4 point hover over spot, full climbout, slow forward flight, backward flight, full climbout, slow forward flight, hover.
Regards,
Rick
RJ is offline        Reply With Quote Quick reply to this message
Old 10-28-2008, 01:13 AM   #58 (permalink)
Hey RJ
With the head speed that low how is she for stability?
I bet you get really long flight times with that head speed and those batteries
How do you find the TT 550 Woodies?
Any good, quality wise?
Cheers
Ben
Borneoben is offline        Reply With Quote Quick reply to this message
Old 10-28-2008, 01:14 AM   #59 (permalink)
By the way your atachment is invalid??
Dunno what that means but i cant open it.
Cheers
Ben
Old 10-28-2008, 02:54 AM   #60 (permalink)
RJ
Originally Posted by Wazzer View Post
Hey RJ
Cheers
Ben
Hi Ben,
It flys very nice and mellow at 1500 rpm. I am running longer tail blades as the tail authority decreased with the lower headspeed. I think the stability is fine, very docile. But if you are used to high headspeeds, you might not like it. It flys more like a scale heli would fly. I was just getting the mechanics set up with the stock head as I have already taken the stock head off and am fitting the Hirobo MRBIII 3 blade head for testing with the VStabi unit.
Sorry you can't see the attachment, it is a graph of the Eagle Tree log. If you PM me your email, I can try to send the jpg image. It shows an 8 minute flight using 2000 ma, so I figure I could fly 12 min. for 3000 ma and still leave some reserve from the 4000maH packs.
I took the TT 550mm woodies off of an old Concept 30 I have on the shelf. They are good quality for wood blades, but the heatshrink covering is thin and also needs to be shrunk before flying. You have to epoxy the plastic root reinforcements to the blade. I auto'd the Gaui with them fine. The driven tail does drain some energy though compared to the undriven tail Concept 30 autos. The TT woodies are heavier than the Gaui blades. They are very stable.
Regards,
Rick
Human Verification
