protos 500 on 3s - HeliFreak
Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Old 06-16-2014, 01:36 PM   #1 (permalink)
Default protos 500 on 3s
Hey guys im wondering if i could run 3s on the older motor/esc that came with the kit....the heli is flybarred and running a spartan ds760 with a jr 3400g....i don't think running it will be an issue...just what size battery can i use...i haven't maidened it yet as i still need a jr tail servo arm, but everything else is setup and ready to go
So what batt size can i use to get decent flight times on 3s?
"I fly because it releases my mind from the tyranny of petty things."
Jay Helifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 02:57 PM   #2 (permalink)
Do you have some 3s 450 batts you could throw on and try it? Two 3s 2200mah in parallel would be a decent starting point. Together they should have enough weight to get CoG decent while still being lighter than a 6s 2600 pack.
Protos Max Leggero 700, Logo 550sx, Blade 230s
DX9, Devo 8s w/ Deviation
flint723 is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 03:37 PM   #3 (permalink)
Yup, i was using one for the bench test....how long flight times on two 3s 2200s?
I know of the gaui x3...which runs 6s 1300 or 3s 2200 depending on motor can still run a 3s 1300 for LHS.....thats half the voltage but no change in mah.....so a 3s 3000 should be enough right? I'll still be running 3s 4400 (2 batts) unless its too heavy for the low head speed and needs lighter batts
Oh, is it bad that im running 6s 3000 right now? Will they be too heavy or does it not matter that much for 3d
Old 06-16-2014, 04:09 PM   #4 (permalink)
I'd just be speculating on flight time but I would guess at least 7-8 min. You could just fly 5, land, and check voltage.
Just have to fly it and see if the 3s 4400 is too heavy or not. I know of a guy on here that flies a single 2200 3s on his Protos but he also has it built ultra light (1.1kg with 3s 2200). He gets like 6 min too. Tail hold gets iffy at these lower head speeds if the heli is too heavy.
Protos 500 Extrem 6S Setup on 3S Low Rpm Flying (6 min 32 sec)
Many people use 6s 3000 and some even 3300. It just depends if you like your helis to feel lighter or heavier in the air.
Old 06-19-2014, 01:23 PM   #5 (permalink)
Just wanted to let everyone know
Flew LHS on a 3s 2200mah which is half the voltage and less mah but still managed to pull off 4 min of hovering and only brought it down to 3.85v per cell
Thats way less amp hours than my 6s 3000 which should get around 4:30 to same voltage but i think the low head speed makes a huge difference, you can barely hear it and its so soft
Just boring hovering
[ame]http://youtu.be/AH31nQD9ULE[/ame]
Old 06-25-2014, 09:24 AM   #6 (permalink)
So is that 3S on the 4S motor? Or 3S on the 6S motor?
I flew my newer Protos with 4S5000 on the 6S motor, and got 17 minutes of flight time.
-Rob
Managing Director
NOVAerial Robotics Inc.
R_Lefebvre is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 12:41 AM   #7 (permalink)
Both 3s (tested) and 4s (not tested due to crash) on a 6s motor
Old 07-20-2014, 09:29 AM   #8 (permalink)
How are you getting your ESC to initiate at the low cell count?
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 07-20-2014, 10:45 AM   #9 (permalink)
I didnt change anything, just plugged in 3s and it worked, its the align 60a esc.....only got 2 flights before the tail blade ejected and destroyed the tail so more soon
Old 07-20-2014, 01:41 PM   #10 (permalink)
Do you have your ESC set to auto detect? That must be the difference.
Old 07-20-2014, 01:50 PM   #11 (permalink)
Probably, I've never used the esc before (got it used) and it worked fine with no heating issues so i called it a day
Old 07-20-2014, 10:39 PM   #12 (permalink)
Yeah, I have a couple of 6 cell packs that i made from two three cell 2650 mah batteries so i tried to run the Protos on just one of them and it won't let the motor start. I think that I have to change the setting in the ESC to let it auto select the battery but I have a different ESC that I want to install so I think that I'll just wait until I get it installed to try it again.
I don't know how well it will fly like that as the head speed will only be around 13-1400 rpm.
Old 07-21-2014, 06:23 AM   #13 (permalink)
I was quite surprised since a 3s 2200 still had a decent flight time.....anyways on my way home hopefully I'll get her fixed and flying soon although the x3 takes priority
Old 02-19-2017, 08:29 AM   #14 (permalink)
This is still an interesting subject if anyone is still flying these. I flew my six cell P500 many times on a 3 cell 2200 but it is just enough to get off of the ground. I have since bought a four cell battery and it is great fun flying with that. It makes for a nice break from the six cell madness!
Old 02-20-2017, 04:49 PM   #15 (permalink)
HAV
Agreed, I fly my 500 on 4s using 2800-4000 mah packs. 3s is doable but 4s is the LHS sweetspot. So relaxing, quiet and smooth. Still my favorite heli.... HAV
MSH Protos Max V2, SK-540, 6s, Align 800s, 900-1100HS
MSH Protos 500, SK-540, 4s, Halo 450s, 1400-1800HS
MSH Protos 500, SK-540, 4s, Zeal 480s, 1400-1700 HS
HAV is online now        Reply With Quote Quick reply to this message
Old 10-15-2017, 04:33 AM   #16 (permalink)
Cool. I need to try this.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 10-17-2017, 07:51 PM   #17 (permalink)
Still loving this thing on four cells!
Human Verification
