Titan X50 Thunder Tiger Titan X50 Helicopters |
#1 (permalink) |
![]() I have a X50 with YS 60 and silver line vbar. I can't get my vibration down. I have tried all kinds of tape and vipe tie with fuel line on it. I can get my vibration down by putting a lot of tape. The problem with that is the sensor is not purfactly flat and then it will not roll good. Also the Heli looks perfectly smooth in the air.
#2 (permalink) |
![]() I have my Ar7200bx mounted on the tray right above the battery. One layer of 3m grey tape with no straps.
Trex 250 Plus, Trex 550 Pro DFC, Trex 500L, Trex 450L, Blade 180 CFX. |
#3 (permalink) |
![]() Join Date: May 2006
![]() I put a main shaft with bearings in it still no good. The vibrations are coming from my engine. I think this is the normal amount of vibration from the YS 60. Im going to pull the engine and check fan runout. Other than that what can I do to lower engine vibration.
#4 (permalink) | ||
![]() Here you can see the mounting position of the silverline sensor.
![]() Titan X50N FBL - YS60SR - VBar Silverline = NO PROBLEM ![]()
#5 (permalink) |
![]() Thanks sky I had mine there but was getting exstrem vibration levels. I can't tell in the picture what it is mounted on?
Can you tell me what vibration levels are in your log? When I do stationery flips or rolls I get some unwanted servo movement if I put 10 layers of tape vibration levels go down and it stops but then the sensor dose not sit flat. |
#6 (permalink) |
![]() The vibration level is mostly >Raised Vibration Level<.
Sometimes >High Vibration Level< and >Extreme Vibration Level<. I use the normal VBar tape for the sensor. |
#7 (permalink) |
![]() I had my sensor there with 3M tape and metal plate 8 layers of tape to get it to raise the vibration level. So I Gus's I have something going on. What headI put a main shaft with bearings in it still no good. The vibrations are coming from my engine. I think this is the normal amount of vibration from the YS 60. Im going to pull the engine and check fan runout. Other than that what can I do to lower engine vibration. speed are you running. Thanks for the help so far and nice flying
#8 (permalink) |
![]() Up on the top most flat plate. Two layers 3M tape and no issues.
"You need more rockets. Everything is better with rockets" Mike Dipalo--Synergy RC, MKS Electronics |
#9 (permalink) |
![]() thanks guys I think I might have found my problem. I got a lot of runout on my fan .007. also I have .002 on the threaded part of the crank. if I put it on the smooth part of the crank I have 0 runout. I guess im going to order a new crank and fan.
sky did you have to open the hole for the crank to get your fan on. I had to thread on my fan. is that normal? I thinking my be I should open up the hole in the fan a little with a drill so I can just push the fan on the crank instead of threading it on. |
#10 (permalink) |
![]() Joecass2 i have no changing on the fan. All parts out of the box.
Yes, the thread on the fan is normal. |
#11 (permalink) |
![]() Joe - I always get some raised vibration levels, but it never interferes with my flying. I think the fan is a good culprit, though. I don't know this to be fact, but I always suspect I get the vibrations simply from high loads in flight. It flies great, so I stopped worrying about the vibrations.
I've always thought the threaded hub is a poor design. It works, but not as well as others which clamp to the journal area between the crank threads and front bearing on the engine. I also suspect thread lock can be an assignable cause for runout too. I will check mine for runout and report back just for reference. Hahah! I remove my motor after most every outing...as I am pushing my RL53 to the limit.
= R ![]() |
#12 (permalink) |
![]() Thanks guys I know that some vibration logs are ok but I was getting extreme vibrations that was making my servos move a little bit when doing flips and rolls. This was making it hard to keep them in one spot. I was fighting the Heli to keep them in one spot.
Thanks for all the help guys. I hope this fixes it |
#13 (permalink) |
![]() Just a comment, Joe...One thing you might want to do with that fan installation is to clean the crank threads with alcohol or acetone and use your Dremel to clean them thoroughly. Then, when the new fan arrives, after cleaning with alcohol, use a wicking type compound on the crank nut and hub threads instead of blue or red threadlock. I've been using Vibratite 150 and it's much thinner and very secure. It's medium strength so it's removable, but shouldn't contribute to any runout in the assembly. It should also hold up to cranking the engine. Twice my hub backed off when cranking the YS! It's a pain to correct it since the engine has to come out, and the aluminum frame braces which attach to the lower bearing block will be bent if it happens.
Here's a link to the Vibratite. I've found it to be far superior to using regular blue for all static connections. If there's a small bearing adjacent, I won't use it so it can't wick into the bearing (for example, swash lever bolts...) LINK
= R ![]() |
#14 (permalink) |
![]() It is a mystery to me why Thunder Tiger cut the frames with a slant at the back on the nitro. On the electric version the frame is straight and you get a gyro tray to go at the back.
I have a v-bar silver line with the sensor mounted like most on the small top tray at the front. I have not looked at the log but with the model in a sustained hover the model sits still so I will take that as an indication that vibration is not so high to upset the sensor. |
#15 (permalink) |
![]() The new plastic fan was .005 so I ordered a metal one it has hardly any runout. I should get to fly it tomorrow. Thanks for the advice Rob43
#16 (permalink) |
![]() I got to fly it today and it got better but im still getting servo movement only when doing rolls. you can see the cyclic move on it's own.
im at high vibration level when hovering. anything else I can do? thanks for all the input guys |
#17 (permalink) |
![]() Maybe try mounting the sensor on PU gel? I've read accounts where this is a good way to get at those pesky vibrations. LINK
= R ![]() |
#18 (permalink) |
![]() is that the same as the align gel? I tried the align gel it make it worst.
http://www.amain.com/product_info.ph...FQIT7AodpjYALg |
#19 (permalink) |
![]() Yeah, that is the stuff. Sorry it didn't happen for you. It is quite necessary for the gel to be as compressed when in flight. So, many run the Milton Mod, where a zip tie, with a piece of fuel tube is strapped over the sensor so it's very tight. The fuel tube and PU gel both attenuate vibes from reaching the sensor. I am honestly simply running Scotch 4010 under my X50 sensor. It's very good stuff. Clear, soft, and very sticky. Yet, it rolls off easily when removing.
= R ![]() |
#20 (permalink) |
![]() I mounted the sensor on my X50 on the upper little shelf using an automotive type tape. It is thin and it holds the sensor like it is glued on. It cannot move.
I just checked the event log and it appears that in flight the model is flying with raised vibration level only. There is a max vibration figure shown on the opening screen of the software and that shows 313. |
