Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 07-04-2014, 08:37 PM   #21 (permalink)
thanks guys
I got high vibration when hoving. the fan help a lot I was able to move the sensor on the little shelf up front with sensor tape, metal plate, tape, tape,
if I can get it down to raised vibration only I would not have the heli make little servos twitches when doing rolls.
guys how else can I get my vibs down just a little more?
joecass2 is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 12:53 AM   #22 (permalink)
Joe - I've never heard someone claim their servos twitch in rolls before. How do you know it's doing this?
I know one thing about this heli, at least in my case, there was alot of slop in the spindle and dampers. The grips had a bunch of play as the grip bearing fit is on the loose side. So, I installed some 7mm id x 0.2mm shims. A pair (total 0.4mm for each end) was installed to tighten up the play a bit. Mine is dead steady flying. No the least bit twitchy. My concern was this would let the spindle float too much which would allow for some vibration since this could cause some unbalance to occur even with perfect blades.
I found the shims at Stormer Racing: LINK
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 07-05-2014, 01:54 PM   #23 (permalink)
How quickly I forget things. I also had the play in the head and had to fit the extra shims like you Rob. Without those I can imagine there is going to be an unwanted vibration.
I don't think it is the fit of the bearings I believe it to be the feathering spindle is about 1mm too long.
I purchased some washers/shims made for a JR model. They cost stupid money for what they are but it did the trick to remove the end float.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 04:21 PM   #24 (permalink)
Indeed, I tried to get the JR spacers unsuccessfully. Then I found 7mm spacers by doing a Google search. I bought 0.1mm, 0.2mm, and 0.3mm so I could handle any combination needed.
= Rb43 =
Old 07-05-2014, 10:20 PM   #25 (permalink)
I blame the dampers not being thick enough. Throw old Raptor dampers in there and there is no slop, because they stick out further.
Don S is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 11:55 PM   #26 (permalink)
thanks guys im going to have to try that. I leaned out my mid needle by one click because of the hot weather and my vib. level dropped some. I can now see some raised vib. level in the log at times. heli was flying really good. I think im going to go in one more click on the mid needle.
I tied leaning the mid needle with the old fan and it did not have much effect on vib. level.
I also am going to order shims the next time I needed something.
Old 07-06-2014, 08:49 AM   #27 (permalink)
That's good to know, Don. Are they also the progressive damping design, with a pair of dampers with different durometer? I really like how this flies.
= Rb43 =
Old 07-06-2014, 09:00 AM   #28 (permalink)
The old style aren't progressive. I use the old dampers on my Jet Ranger (you also need old Raptor spindle and bearings). I just shim my X50 head as needed.
Old 07-06-2014, 11:00 AM   #29 (permalink)
Thunder Tiger realised their mistake with the original spindle for the X50 as I am pretty sure I saw an update one available.
The reason the original Raptor spindle works is probably because it is that 1mm shorter and the correct length.
joecass, If you have end float in the main blade grips then you need to fix it asap and not wait as it will cause a slight imbalance to the main blades that could be enough to cause your vibration issues.
Old 07-06-2014, 01:50 PM   #30 (permalink)
+1. Coming from only Compass for a while, I was astonished how sloppy the fit up was. The diametral fit isn't very tight either for that matter. But hey, it flies incredibly.
= Rb43 =
Old 07-06-2014, 10:56 PM   #31 (permalink)
I didn't see any length difference old vs. new spindle (X50). The only reason for the change was because the old style could fracture at the step. That's what we were told at least.
The old Raptor setup works because the Raptor dampers stick out further from the head, removing the slop. I think all 3 spindles are the same length, but it's been a while since I had my hands on all three at the same time.
Old 07-07-2014, 12:18 AM   #32 (permalink)
I cant find the shims and it looks like the updated spindle shaft id PV1441 but not out yet.
Old 07-07-2014, 02:05 PM   #33 (permalink)
Here is the JR part I used
http://www.fast-lad.co.uk/store/prod...oducts_id=2517
Here is where you can source the Thunder Tiger parts
http://www.modelhelicopters.co.uk/he....html?___SID=U
If the reason for the change was because the stepped shaft sheared off then I will not wait for it to happen and purchase the new part. I didn't know that had happened, thank you.
Old 07-07-2014, 02:14 PM   #34 (permalink)
That was the reason given by the reps. I think it's in a thread on the other site.
Old 07-07-2014, 02:27 PM   #35 (permalink)
Thanks Don.
I wonder if it happened to someone who hadn't got rid of the end float and so with grip movement it hammered on the thrust bearing until the shaft broke?
I also wonder if a longer bolt would of held it all together?
Either way I have just placed my order with Midland Helicopters for the parts.
Old 07-07-2014, 09:24 PM   #36 (permalink)
Joe - the shims are available from Stormer Racing Hobbies from X-Ray Racing. Links below:
7x.2mm
7x.3mm
7x.5mm
= Rb43 =
Old 07-08-2014, 06:57 AM   #37 (permalink)
Thanks rob for all your help. They are out of stock right now. Should I order them from uk or wait for them to come back in stock?
Old 07-08-2014, 01:05 PM   #38 (permalink)
How impatient are you?
= Rb43 =
Old 07-08-2014, 03:33 PM   #39 (permalink)
I use these between the head and black damper. You could have these in 2 days or less.
http://www.mcmaster.com/#91437a248/=qwbznk
Old 07-11-2014, 12:58 PM   #40 (permalink)
My new feathering spindle and thrust bearings arrived.
The inner part of the thrust bearing is a very tight fit to get in the grips.
With just the parts supplied there is the annoying end float. I fitted the JR washers in place of the TT ones that go between the dampers and grips and the end float is gone but I can feel that I have pre loaded it a bit as the grips will not fall under there own weight.
