Titan X50 Thunder Tiger Titan X50 Helicopters |
#41 (permalink) |
![]() Pick up any of the shims we've listed, you'll like it.
#42 (permalink) |
![]() Hey guys,
One thing I found that helped my various fbl head with end slop, was to just file the spindle down a fraction which tightens everything up nicely without using shims etc. Really easy, just a little at a time until the slop is gone ![]() |
#44 (permalink) |
![]() Novarossi pipe...is that a Rex 57 too?
= R ![]() |
#46 (permalink) |
![]() Had some issues with vibration on my skookum.
Made this and seemed to make a huge difference, until 2 mins into the flight when the lower plastic bearing block failed and I crashed. Luckily the damage is minimal. |
#47 (permalink) | |
![]() Join Date: May 2006
![]() Quote:
Thanks |
#48 (permalink) |
![]() Majorlemond,
I'd concur. Replace the plastic bearing blocks with metal. The metal ones are nice. By shimming the head, I believe Joe was talking of shimming out the feathering spindle end-to-end play. I did this too. Your carbon plate looks nice. Is it resting against the elevator servo, or is there some clearance?
= R ![]() |
#49 (permalink) |
![]() Thanks guys. It is actually a 3mm carbon plate attached
With some aluminium right angle stock and bolts. The plate probably has About 3/4 of an inch clearance from the servo. I just bought a bunch of parts from Fast Lad and the first things On the list were metal bearing blocks after hearing about multiple failures And seeing mine fall out of the sky. Seriously though this is one awesome Flying heli. I just need to stock up on parts before they disappear. |
#50 (permalink) |
![]() Easily my favorite heli. Goes like stink with the YS 60sr fitted. Running the Hatori SAB-1 and have the sleeve ports in the YS relieved and polished a bit. Signifcantly improved the performance and tuning. Even looks as if parts will be back for summer in North America, so I can fly it hard and not worry.
= R ![]() |
#51 (permalink) |
![]() Well mine cranks with a ys56sr and a Novrossi pipe so I could only imagine the power with a ys60! I hear the redline 56 is pretty good too when tuned right.
I forgot to mention I managed to crack both frames in the crash, However I think I will repair them initially, with some 2mm carbon doublers, bolts and epoxy. They both cracked in the same position at the front where TT has milled the cutout for an on/off switch. ![]() |
#52 (permalink) |
![]() And who uses an on/off switch anway
= R ![]() |
#53 (permalink) |
![]() i do lol i use a rocker switch in that spot. ill show ya next time i see ya
Mikado 550sx, TT X50N, Align 470L |
#54 (permalink) |
![]() Exactly. I bet if that area was not machined out that possibly the frames would have not cracked where they did.
Anywho the repair came out better than expected. Pretty happy with it. ![]() https://www.helifreak.com/showthread...64#post6365364 |
#55 (permalink) |
![]() It would be stronger with John's switch installed, LOL!
= R ![]() |
#56 (permalink) | |
![]() Quote:
Trex 250 Plus, Trex 550 Pro DFC, Trex 500L, Trex 450L, Blade 180 CFX. |
#57 (permalink) |
![]() What speed sensor are you using for the AR7200? I was going to use the spektrum crank case mount one, but looks a little shady working with my 53.
TT Titan X50F w/ TT .53 and AR7200BX ALN 450 PRO DFC Scorp -8, 50 LITE and DS95s AR7200BX ALN 450 PRO DFC, all stock "Nite-Flyer" w/AR7200BX ALN 500 EFL, Goblin 380 w/AR7300BX and Spektrum DX-9 |
