Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 06-19-2014, 05:36 PM   #1 (permalink)
Default CL-0820-15 Micro Motor Warehouse upgrade
I love flying the 180QX and recently it has been sluggish so I was going to have to order some new motors because I replaced the blades and it didn't make much difference at all. I was barely able to get more than a hover. So I went looking for a little more power. I could not find anything except the stock motors. I knew how those flew and I stumbled across the Micro Motor Warehouse. I saw that they were good to go in the Alias, so I took a chance and I ordered the CL-0820-15 motors from Micro Motor Warehouse with the pinion gear on it to see if I could get some more "umph" from the 180QX. I had to do some take the old connectors off the used motors and solder them to the new motors and in the end I am so happy I can't stand it. It is really like a rocket ship compared to even how it was new. It is such a joy to fly around. It has easily double the payload. Using my crude methods. I strapped the stock camera (we know how everyone feels about that one) and the 808 #16 camera (both at the same time) to the frame and it flew better than stock. Highly recommended upgrade.
Jazztaz is offline        Reply With Quote Quick reply to this message
Old 06-21-2014, 08:07 AM   #2 (permalink)
Thanks for the information!
"Nothing is as constant as changes"
DX9, DX6i, Blade Nano CP X, ZYX "Blade" 130X, Blade 180 CFX, Blade 230S, Blade 300X, Blade 450 3D (about 2 b FBL; have the parts, not the time), Blade 180QX, Blade 230S V2, Convergence, Mini Convergence.
Neunerball is offline        Reply With Quote Quick reply to this message
Old 06-21-2014, 02:33 PM   #3 (permalink)
Finally! Someone tried it! Did you get the 9T or the 11T pinion?
NANOQX 180QX 200QX 350QX NANO CPX UMXBEAST3D CHAMP DX6 CARBON CUB SS AS3XTRA SPACEWALKER Inverza280 Stinson Reliant
Bigsmitty is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 10:50 AM   #4 (permalink)
I used the 11T pinions that came with it. They just drop right in. They are the plastic ones and it does make the 180 QX a lot quieter.
Old 06-23-2014, 06:41 PM   #5 (permalink)
Good to know, thanks for the info. I'll get them when they are in stock in the states again.
Old 06-25-2014, 07:55 PM   #6 (permalink)
The motors without pinions are available. Can you not pull the stock ones and put them on these? (forgive my stupidity)
MacBookProAR is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 08:47 PM   #7 (permalink)
Not sure if the shaft size is the same. I'll look into it and get back.
Old 06-26-2014, 02:43 PM   #8 (permalink)
These just became available too. Same size, but faster apparently? I have ordered them and see if they work I guess.
http://micro-motor-warehouse.com/col...cts/cl-0820-17
Old 06-26-2014, 07:42 PM   #9 (permalink)
Turning little toys into rocket ships - one at a time.
Thanks for pointing me to this thread, smitty!
chief scientist @ micro-motor-warehouse.com
benedikt is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 01:21 PM   #10 (permalink)
Question
Just stumbled upon this VERY interesting thread....
I have a 180 QX and a Mobius cam... obviously I can't lift it using stock motors
Would the CL-0820-15 motors help me lift it?
No plans to do any acrobatics, just want a nice stable hover while filming (5 minutes flight time would be more than enough)
First post is mentioning lifting the stock cam + 808#16 = 16gr + 17gr = 33 grams.
Mobius has 39 grams. Is there any hope?
m3nt0s4n is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 01:33 PM   #11 (permalink)
Question
Just found this VERY interesting thread!
I have a 180 QX and a Mobius cam. Obviously I can't lift it (more than few seconds....).
First post mentions lifting using those motors 1 stock cam + 808#16, that's 16 + 17 = 33 grams. The Mobius has 39 grams....
Do you think they'll work lifting the Mobius just for calm hovering for few minutes? (no acrobatics planned )
Thanks!
Old 09-06-2014, 06:50 PM   #12 (permalink)
I have seen people flying a Mobius with an Alias. Which is so similar from the setup to the 180 that I think you should be fine. You could also remove the cam housing and the battery, and connect the cam to the flight pack over a voltage regulator (primarily to filter out the motor/ESC noise). This should get the penalty down to around 20g.
Old 09-07-2014, 11:28 AM   #13 (permalink)
Question
Thanks a lot for your quick answer.
Do you by any chance know what's the name of the connector used for motors on the 180 QX?
It's a 2 pin connector but I can't find it in any catalogue. Would like to simply disconnect the stock motors and connect the mmw ones (after replacing their connectors with the 2 pin one).
Old 09-09-2014, 04:49 AM   #14 (permalink)
Sorry, I don't know what plug that is.
Maybe you find it here: http://www.rc-connectors.com/
They don't have a 180 listed, but maybe one of the other Blade model is using the same plug.
Old 09-10-2014, 02:18 PM   #15 (permalink)
I got the motors (VERY fast delivery, btw) and now I am preparing to mount them.
Having a Blade 180 I know that I have to mount:
* MMW blue/red motors instead of the Blade black/white ones
* MMW black/white motors instead of the Blade blue/red ones
Not having connectors I am facing a (simple) problem: how do I solder the wires?
Is the mapping below the right one?
MMW Blade
Blue (-) => Black (-)
Red(+) => White (+)
Black(-) => Blue (-)
White(+) => Red(+)
Thanks and sorry for the noob question
Old 09-10-2014, 04:20 PM   #16 (permalink)
I couldn't wait for my previous message to be approved so I cut the old motors wiring and soldered the new motors Did a quick test in my room and it seems the Blade is "still" able to fly
Looking forward to testing it outside tomorrow First impression is that the sound changed a bit (could be placebo) and now it has a "sportier" note
If it is able to lift the Mobius now and fly 4-5 minutes with it I guess I'll immediately order another motors set as a "spare"
Old 09-12-2014, 05:00 AM   #17 (permalink)
Wired correctly - should work nicely!
Have fun, let us know how it works
Old 09-12-2014, 03:18 PM   #18 (permalink)
Let us see some pics of these motors!! Please!
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 09-12-2014, 06:24 PM   #19 (permalink)
http://micro-motor-warehouse.com/col...cl-0820-17-11t
http://micro-motor-warehouse.com/col...cl-0820-15-11t
Dwayne
DX8, DX6i, 200QX, 180QX FPV , Nano QX x2, ProtoX x 2, Cheerson CX-10 x3, Blade SR, MCX2, mSR, mCPX v2, Nano CP X BL
Dubbin1 is offline        Reply With Quote Quick reply to this message
Old 09-12-2014, 08:09 PM   #20 (permalink)
I mean wired and installed on your bird!!!!
