Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 11-04-2014, 05:58 PM   #41 (permalink)
Originally Posted by benedikt View Post
I find "safe" mode a much more intuitive mode than "acro" or "expert".
It just needs more than 40 deg bank angle. 70-90 deg is good.
The MultiWii mode "horizon" is the perfect hybrid. Self-leveling at center stick, and a smooth ramp towards "expert" at full stick deflection.
Have you tried stagility mode? From what I understand it is just what you are looking for - high bank angles of the agility mode with the Safe mode when near hover. https://www.helifreak.com/showthread.php?t=597395
I fly the 180QX aggressively in agility mode and am keeping a hopeful eye on this thread for next season. I have an essential tremor in my hands that makes solid soldering impossible.
Tom
Having a Blast with the Blade 180QX (2 min 8 sec)
TomQ is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 03:23 PM   #42 (permalink)
Alright, various sample plugs are on order.
I expect them in about 2 weeks.
Meanwhile, I put quite a few packs through the 180.
I like it! Zippy little bugger
What I dont like so much: the SAFE mode is quite limiting. The maximum inclination angle isnt enough to fly hard maneuvers. Also, I see it wobble when cranking the sticks hard enough.
The latter might get better when replacing the motors, but the SAFE mode wont.
I think I will end up putting an AlienFC into it and fly it in horizon mode.
Should fly a bit like this then:
Latrax Alias maximised - The Hacklias V2 on Vimeo
But since it weight almost 20g less than the Alias, I expect more
Have you had a chance to put the AlienFC in the 180QX yet?
Jazztaz is offline        Reply With Quote Quick reply to this message
Old 04-16-2015, 01:18 PM   #43 (permalink)
CL-0820-17 "Dark Edition" in the 180qx are amazing coupled with higher C rated batteries.
Micro Motor Warehouse is a top notch company with great customer support. High fives, Benedikt!
Binski is offline        Reply With Quote Quick reply to this message
Old 04-16-2015, 04:37 PM   #44 (permalink)
Cheers, Binski!
And yes, I have put the Alien on a 180 in the meantime
AlienQX FPV - Like you stole it! (2 min 55 sec)
chief scientist @ micro-motor-warehouse.com
benedikt is offline        Reply With Quote Quick reply to this message
Old 04-27-2015, 07:25 AM   #45 (permalink)
will these be back available on your website soon? i'm really looking forward to trying them in my 180qx
TomFreeman is offline        Reply With Quote Quick reply to this message
Old 04-27-2015, 04:46 PM   #46 (permalink)
Yes, we will make more. But I will drop the coil speed to 15.000Kv. Insane power caused too much trouble with the 180.
If you can solder, you can grab some of our Alias motors (0820-15-11T) and wire them up yourself.
New motors with suitable plugs will take a few weeks!
Old 06-26-2015, 04:02 PM   #47 (permalink)
Hi. This may sound a noob question but my motors arrived and I've tried to fit them but with the adapter on the plugs I can't get the casing back on to hold the motor down. Do I need to dremel the hole bigger on the side or am I doing something wrong?
Old 06-26-2015, 05:01 PM   #48 (permalink)
They fit right in, like the stockers. I assume you are so in something wrong, but I'm at a loss what that could be. You got a few pics?
Old 06-26-2015, 07:54 PM   #49 (permalink)
Out of curiosity, why did the -17 motors cause trouble with the 180qx? I just got one secondhand and am thinking about getting some upgraded motors. And stagility mode on the 180 is exactly as you described horizon mode on the other controller.
eKretz is offline        Reply With Quote Quick reply to this message
Old 06-27-2015, 05:20 PM   #50 (permalink)
Just couldn't get the adapters to fit in and the plastic covers to click over to hold the motors down. An excuse to use my new dremel anyway and now it flies great. Thanks Benedikt
Old 07-02-2015, 04:10 PM   #51 (permalink)
Originally Posted by Bigsmitty View Post
Good to know, thanks for the info. I'll get them when they are in stock in the states again.
Originally Posted by MacBookProAR View Post
The motors without pinions are available. Can you not pull the stock ones and put them on these? (forgive my stupidity)
The pinions are brass and a little more difficult to pull. I believe that Benedikt (Micro Motor Warehouse) will sell you a set of nylon/plastic pinions separate from the motors.
I actually have a set of slightly used 0820-17 "dark series" motors that I am going to throw on my MQX. This thread makes me excited to get them on there.
EDIT: Crap, I didn't realize how old this thread was...
adamky is offline        Reply With Quote Quick reply to this message
Old 07-02-2015, 05:56 PM   #52 (permalink)
Happens!
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 07-02-2015, 07:21 PM   #53 (permalink)
thanks for the bump!
Old 07-02-2015, 09:37 PM   #54 (permalink)
Benedikt... Could I get this answered?
Old 07-02-2015, 09:41 PM   #55 (permalink)
Sorry, missed that
The FC on some 180s randomly shuts down when you punch the throttle with the -17s. Something on the FC doesnt seem to be able to deal with the higher current. We suspected the battery connector. Changing that (resoldering thicker wires and new connector straight off the board) helped in some but not all instances.
Old 07-03-2015, 12:04 AM   #56 (permalink)
Gotcha, vielen dank!
Old 07-03-2015, 03:04 AM   #57 (permalink)
BTW, what is the full load amperage of the -17 motors? Maybe they are exceeding the C rating of the stock batteries? Sent stock 180 batt is 500mAH with an alleged 25C rating, where the LaTrax Alias runs a 650mAH with a alleged 20C rating.
The thing is, I've heard from more than one guy that the stock eFlite batteries are rated a little optimistically in terms of discharge rate.
Old 07-04-2015, 05:40 PM   #58 (permalink)
The -17s top out at around 3A. So 12A in total. That brings most 1S micro cells to the limit, but I have run the same motor/battery combo on various FCs, and only the 180QX FC had these issues. I have the feeling the FC does not have a problem with voltage sag but rather with the current throughput. So a better battery makes it worse. Less demanding motors were the only solution to the black box problem I could come up with..
Old 07-05-2015, 02:01 AM   #59 (permalink)
Ah, I see. That is pretty solid evidence. Perhaps the FC's choke point is in the transistors and they could be paralleled or outfitted with a higher spec replacement. Any way you look at it though, that's far beyond the scope of a beginner.
Old 07-06-2015, 02:51 AM   #60 (permalink)
Sorry, missed that
This is similar to what I experienced running a Nano FPV FC on my Micro-H frame with Parrot Rolling spider props. Even with upgraded 6A FETs, it would shut down after less than a minute of hovering in place. The FETs themselves were fine, so something else on the board was clearly having issues.
