No throttle? How to arm the 200QX on the Taranis. - HeliFreak
Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 200QX
200QX Blade 200QX Helicopters Information and Help
Old 07-09-2014, 11:34 AM   #1 (permalink)
Default No throttle? How to arm the 200QX on the Taranis.
First, I have the Taranis with a homemade dx5e dsm2/dsmx radio module, that's another story. But what it means is that, the 'radio programming' instructions that come with all the Blades (HH) need to be translated.
For the 200QX, the basic info is:
CH1 - Throttle
CH2 - Aileron (Reversed)
CH3 - Elevator
CH4 - Rudder (Reversed)
CH5 - Stability/Agility Mode (Reversed/Complicated?)
CH6 - Camera
And that's how I set it up, but then I spent two days not being able to get the motors armed with no idea why. I stopped at the LHS, and they didn't have a clue. I ended up figuring it out there at the store after reading a lot of posts about throttle and trim settings.
The 200QX flight controller wants to see exactly zero throttle, and specific channel values to arm. Apparently either zero throttle and full left rudder followed by full right rudder, or both sticks at 'inside bottom corners' (A picture in the manual would have been a nice addition, considering they give us Throttle Up pictures).
Now here's the thing.
OpenTX on the Taranis, by default, uses 1000ms to 2000ms channels with 1500ms centers.
DSM2/DSMX protocols use 1100ms to 1900ms channels with 1500ms centers. Now, it's possible to 'overdrive' the channels by putting your rates up to 125%, which gets you to 1000ms - 2000ms.
I'm sending out 1000ms at zero throttle, moving the sticks back and forth following their 'arming' procedure, and getting nothing.
So the simple solution is to limit each channel down to 1100-1900ms, which is very easy on OpenTX and works perfectly, the motors start right up, but then you have no way to cut the throttle and kill the motors, since the throttle channel is limited to 1100ms on the low end.
I ended up configuring the throttle channel to range from 1000-1900ms, with a 20% offset, which lets it sit at 1100ms with zero throttle, but allows the throttle cut switch to be used to disable the motors again. Now, with the other channels all limited to the DSM 1100-1900ms range, it arms perfectly.
That leaves us with the more advanced configuration:
CH1 - Throttle 1000-1900 w/ 20% offset on Throttle Input
CH2 - Aileron - 1100-1900 Reversed
CH3 - Elevator
CH4 - Rudder - 1100-1900 Reversed
1900 - Low Rate Stability
1500 - High Rate Stability
1100 - Agility Mode
CH6 - Camera (I have no clue on this one)
ModulusX is offline        Reply With Quote Quick reply to this message
Old 07-10-2014, 12:34 PM   #2 (permalink)
I'm in the process of converting to a Taranis also.
On my DX18 the throttle cut drives the throttle to -130%. On your Taranis instead of limiting the throttle channel endpoints maybe you should do the equivalent of dual rates to limit the throttle, that way your cut switch could still go below the Spektrum -100% mark but the sticks would be limited to +/- 100%.
I don't have a DSM/DSMX module and just got a Taranis last week so I can only tell you what happens in Spektrum terms and guess at the Taranis.
dfruehwald is offline        Reply With Quote Quick reply to this message
Old 07-10-2014, 04:23 PM   #3 (permalink)
Sorry if my post was confusing, I do have it working perfectly, my post was just to help out others that might struggle with arming the motors..
OpenTX is far more configurable, instead of dual rates, its nearly infinite. Easily more than most could remember while flying.
It has 6 three-position switches, each of them could be used to modify the rates on any combination of sticks/channels/variables, and you can stack them, so if Switch A is in position 1, Switch 2 might do something completely different than when Switch A is in position 2.
I was easily able to set up 'stagility' so that one of my three position switches has the following modes:
1. Low Rate Stability
2. High Rate Stability
3. Agility mode when the absolute value of the right stick is greater than 75%, High Rate Stability the rest of the time. (I know its cheating...)
This quad does some fast flips!
Old 07-10-2014, 09:05 PM   #4 (permalink)
I wouldn't mind seeing the programming for that. Sounds like how the 200QX is setup and I like that setup. Smart Mode just boggles my mind but I can see why it would appeal to a newbie. I think they made better decisions on the 200QX setup. My thinking for the 350QX is AP, Stagility, Agility. I have not tried the Stagility trick but might try it on the 200QX if it goes well on the 350QX.
Old 07-15-2014, 11:20 AM   #5 (permalink)
I added some screenshots for most of the setup of the Taranis to do Stagility.
They're posted here.
Old 08-19-2014, 09:48 PM   #6 (permalink)
Default My 200QX settings for 2.0.8
I have some settings for OpenTX 2.0.8 for the 200QX.
I took a slightly different approach than you did and mine still has 100% (125%) on Aileron, Elevaor and Rudder. In Agility it is one angry little bee
I also setup a Stagility with Blue (High rates) up to 15% Aileron/Elevator and outside that its Red (Agility) mode. I'll probably have to tone mine down a bit for more than test flights ;-)
Let me know if you want me to post screen shots or the epee file (if I can figure out how). I put it in the 200QX and Taranis RCG threads also.
Old 08-19-2014, 11:24 PM   #7 (permalink)
Here is my taranis setup
MCPX BL, 130X, 180cfx, 300x,300cfx, Compass Warp 360, ZMR250 FPV, EMax 250FPV, Morphite FPV,Taranis
linklemming is online now        Reply With Quote Quick reply to this message
Old 08-24-2014, 04:58 PM   #8 (permalink)
I am brand new to the Taranis platform and have one on the way.
I am going to pick up a BNF 200qx at a lhs for my first quad experience.
Am I going to need anything else or will the taranis bind to the reciever as is?
Subscribing to thread for future reference. Im sure I will need it.
Sent from my SGH-M919 using Tapatalk
RustySocket is offline        Reply With Quote Quick reply to this message
Old 08-26-2014, 09:23 AM   #9 (permalink)
You will need either an Orange module for the bay at the back, or you'll need to make your own Spektrum module conversion from a DX4e transmitter. The protocol built into the Taranis will not talk to Spektrum receivers.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 08-26-2014, 11:09 AM   #10 (permalink)
Thanks for the reply. Got a orange on the way
Old 08-31-2014, 03:04 PM   #11 (permalink)
Default Motors won't spin after binding please help
I have my dx6 binding to my 200qx but the motors will not start when i give it throttle. Not sure if this is the right forum but I would appreciate any help.
Jwatty is offline        Reply With Quote Quick reply to this message
Old 08-31-2014, 04:12 PM   #12 (permalink)
You need to arm the motors. Refer to the manual on how to do that.
I had the exact same question when I got my 200. Helps of you read the manual as I was told by a few friends. [emoji6]
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
DX9, AMA# 966513.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 08-31-2014, 05:33 PM   #13 (permalink)
I could not figure it out when I first got mine either....I read the instructions also. There is nothing that tells you that you need to adjust your throttle trim (UP in my case) a few click until you get the arming tone when you move the throttle all the way down.
Also, they don't mention that you can arm the motors by simply moving the left stick the to bottom and moving it from side to side while down.
the instructions are lacking for sure.
wsntme is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 05:15 AM   #14 (permalink)
Hi All,
I have setup my Tranis Plus but for some reason my throttle is not reading .... I am using mode 1 and have assigned it to channel 1 but when I load the model config and look at the menu that shows you the stick percentage I get nothing on channel 1 all other are fine ... what am I missing ?
yogi
yogi_ is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 01:23 PM   #15 (permalink)
I'll upload my EEPROM later tonight so you can take a look at it
Protos Max 800 | Goblin 500 | Gaui X3 | Goblin 280 | Oxy 2
MXP 150 | CM Stigg
FrSky Horus | Spirit FBL | CC and HW ESCs
MyRCode is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 06:13 PM   #16 (permalink)
Here's my EEPROM....take a look at the 200QX model.
MXP 150 | CM Stigg
Old 10-20-2014, 12:58 AM   #17 (permalink)
Thanks I will have a look tonight when I get home.
yogi
Old 10-20-2014, 04:11 AM   #18 (permalink)
When I try to download the file it's listed as a .PHP file and not recognised as a valid file. Is there issues with newbies downloading files from this forum ?
yogi
Old 10-20-2014, 04:21 AM   #19 (permalink)
Originally Posted by yogi_ View Post
Hi All,
yogi
I'm not using a Tranis, but am using a 9XR with er9X firmware (open source). Mine is in Mode 2 (throttle on left stick) and here is the mix I use and it works perfectly on my 200QX. The channels must be as configured for the 200QX (or 350QX) to recognize the controller.
CH1 AIL
CH2 ELE
CH3 THR (also program in the "Throttle Cut" safety switch if you want to)
CH4 RUD
CH5 3 position switch
CH6 RTH (used on 350QX)
04fxdwgi is offline        Reply With Quote Quick reply to this message
Old 10-20-2014, 08:06 PM   #20 (permalink)
yogi
PM me your e-mail address and I'll send it to you directly.
MXP 150 | CM Stigg
Insurance
Human Verification
