AccuRC Flight Sim AccuRC Flight Sim Discussion |
#1 (permalink) |
![]() Regardless of the glitches I am starting to like Accurc after some tuning. I think it would be useful to get info on the hardware people are running, what Physics FPS (PFPS) they are getting and how the sim actually feels. I know this is a geeky post but with enough info it will be easier for people to determine whether they can run the sim now, if they need a new PC or just need to upgrade components such as CPU or GPU.
The sim flies fine and the graphics quality is pretty decent. Windows 7, AMD FX 4100 @ 3.6 Ghz 12GB ram GTX 550 Ti 1GB SIM: Resolution: [email protected] Full Screen Antialiasing Level: AA8 Smoke Quality: N/A only tested electric Shadow Quality: Low Frame Skipping: No Texture Quality: High Target Framerate: 120fps VSync: Off Control System FPS: 800 Physic: Auto Enable Graphics Multithreading: Yes Results: Physics: 370 to 400 Last edited by wab223; 07-24-2014 at 10:48 AM.. Reason: title change |
#2 (permalink) |
![]() Win 7
I5.2500K Overclocked to 3.6GHZ NVIDIA GTX 760 8GB I'm getting 750 to 800 PFPS. Vsync off, 120 fps. 1080P. I wonder why you get half the performance? The i5 has 4 cores, but supports hyper threading. So it takes 8 threads. I wonder if that's the reason? Tried it on a haswell 2.6 ghz dual core. Not usable. 100 PFPS. |
#3 (permalink) |
![]() I have a Laptop
Win 7 I7 2670QM at 2.20 GHZ Processor Nvidia GEForce 525M -video card 4GB Ram My Physics fluctuates around the 350FPS Mark Sim Graphics Vsync - enabled 60FPS- selected |
#4 (permalink) |
![]() I think there are a ton of variables that affect this so I'll be a little more verbose:
Laptop: Macbook Pro Retina (Late 2013) Windows 8.1 Enterprise x64 (Bootcamp) Intel Core i7-3740QM @ 2.70GHz 16GB RAM NVIDIA GeForce GT 650M SIM: Resolution: [email protected] (1080p) Full Screen Antialiasing Level: AA8 Smoke Quality: High Shadow Quality: High Frame Skipping: No Texture Quality: High Target Framerate: 120fps VSync: Off Control System FPS: 800 Physic: Auto Enable Graphics Multithreading: Yes Results: Graphics FPS: 80 - 115 Physics: 369 - 466
Goblin 380 / Spirit FBL __________________ |
#5 (permalink) |
![]() Workstation ( home built )
i7- 2600K - 3.40GHz ( 8 cores ) NVIDIA GeForce GTX 660 16Gb DDR3 RAM Samsung 840 - SSD boot drive 3 x Dell 24" 1920x1200 monitors. Total Bithead digital preamp to self amplified M-Audio monitor speakers Resolution:1920x1200 Antialiasing Level: AA8 Smoke Quality: High Shadow Quality: High Frame Skipping: No Texture Quality: High Target Framerate: 120fps VSync: Off Control System FPS: 800 Physic: Auto Enable Graphics Multithreading: Yes Graphics FPS: ------ 121-123 Physics: --------------- 610-726
Mark |
#6 (permalink) |
![]() Everything high
120fps - vsync off Run in window (saves you 16ms latency! Compared to full screen, harder on the graphics) Nvidia gtx 650 ti boost i5 750 2.67 quad Fps 120 Pfps around 488
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro ![]() |
#7 (permalink) |
![]() Ha!
You win Mark. That is a smoking laptop!! ![]() |
#8 (permalink) |
![]() I said it was a workstation. My CoreDuo Laptop is 6 years old and doesn't have enough omph for this simulator.
Mark |
#10 (permalink) |
![]() OnTheSnap said he was getting physics @ 750-800
Mark |
#11 (permalink) |
![]() SIM:
Resolution: 1920X1080 Full Screen Antialiasing Level: AA8 Smoke Quality: High Shadow Quality: High Frame Skipping: No Texture Quality: High Target Framerate: 120fps VSync: On Physics FPS-840 Can also run at max 900 but cause FPS to drop to about 115, rock solid at 840. Graphics FPS-120+ Control system FPS-800 Automatic Physics FPS-No Enable Multi-threading-Yes Results: Physics: 840+ FPS and sim runs perfect. Computer Specs I5-2500k CPU @3.4 GHZ Not over clocked with stock settings. Ram- 16 Gbs Video Card- Zotac GTX 580 Amp edition Monitor- Asus 29 inch 3D monitor 120HZ SSD- 128 gbs HD- 1 TB Accurc also runs perfect with Nvidia 3D glasses and Asus Monitor.
Team Rc AerodyneHigh On HelisCamp Hardcore |
#12 (permalink) |
![]() I7 4790K 4ghz stock, 16 GB ram geforce 780ti, 1080p 120Hz, physics 800-900
q6600 2.7 ghz, 4gb ram, geforce 660ti, 1050, 120hz, physics 390-480. Control lag on both. Much less so with vsync unlocked.
TDR/VBar Logo 600SX 12s VBar MSH MINI PROTOS/CGY750 |
#13 (permalink) |
![]() Windows 8.1,
Core i7-3770 @ 3.4Ghz 32GB ram GeForce GTX680MX w/ 2GB GDDR5 SIM: Resolution: 2560x1440 Full Screen Antialiasing Level: AA4 Smoke Quality: High Shadow Quality: Medium Frame Skipping: No Texture Quality: High Target Framerate: 120fps VSync: Off Control System FPS: 800 Physic: Auto Enable Graphics Multithreading: Yes Results: Physics: about 500-600fps |
#14 (permalink) | |
![]() Join Date: Mar 2012
![]() Quote:
I expected I might be low down the totem on this but I am suprised in the PFPS rates you guys are getting. I do wonder if Accurc could be using intel optimised function libraries that are not working as well for AMD (conspiracy - lol!). I went out and bought a GTX 760 yesterday. The sim works even better but no suprise my PFPS only jumped up 9 points to 409. We need more AMD data or I might end up building an intel machine and that will turn out to be a very expensive sim. ![]() |
#15 (permalink) | |
![]() Quote:
#16 (permalink) |
![]() Yes, I understand the PFPS is a factor of CPU power. Never the less I was hoping my graphics card was a bottleneck and that switching the card would possibly free up CPU cycles. I was not expecting much and actually did get a small increase.
Accurc appears to be running quite nicely with this GTX760 and my FX 4100. I'l see over the next couple of days how I like it now compared to my other sims. EDIT: BTW, my chip is almost falling off the bottom of the min spec while the i5 is recommended. This is just to say I think Accurc did a good job in analysing hardware reqs. |
#17 (permalink) |
![]() Deffo on the CPU ... the Intel core series is much more efficient than AMD's of late ... makes a serious difference
#18 (permalink) |
![]() I got my Core Duo laptop to work acceptably.
I have everything turned down, but am running 1920x1080 resolution. I"m getting Video fps 85 Physics fps 360-380 I had to turn down the tail gain compared to my workstation. I can A/B it with RF better now on my big screen HD TV now.
Mark |
#19 (permalink) | |
![]() Quote:
I still have some doubts if my i5 750 will run nicely. I' m planning on doing some oc, but the modern haswell CPU perform so much better ![]()
XL Power 520, Warp 360 , Sport 360 NiTHeli T500 AP |
#20 (permalink) | |
![]() Quote:
I'm going to need some additional tax write offs this year. I may justify a high powered laptop. I'm sure I can find "some" other use for it beside as a sim. We'll see...
Mark |
