Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 200SRX
200SRX Blade 200SRX Helicopters Information and Help
Like Tree1Likes
Old 08-02-2014, 06:29 AM   #21 (permalink)
This may be the best write-up ever! Many Thanks
Bill_Van is offline        Reply With Quote Quick reply to this message
Old 08-02-2014, 07:05 AM   #22 (permalink)
Originally Posted by Varooom View Post
Junkman, excellent! Very helpfull
Thank you.
Thank you gents. Glad to be of assistance.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 06:00 PM   #23 (permalink)
Thanks for the great guide! Maybe I missed it, but is there a trick for removing the bearings from the main shaft? I can't seem to slide the bottom one off short of a tremendous amount of force and I don't want to break it.
adamnyholt is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 06:03 PM   #24 (permalink)
I haven't had to change mine at this point. Do you have the shaft completely removed?
Old 08-04-2014, 06:12 PM   #25 (permalink)
No, i was hoping to just slide it out without taking apart the frame (which I would have to do to pull the shaft out with bearings attached).
Old 08-04-2014, 06:18 PM   #26 (permalink)
You need to understand how the bearings sit in the chassis. I think that is why you are having a problem. See the lips?
Old 08-04-2014, 06:21 PM   #27 (permalink)
Got it. It just took what my dad calls the BFI approach. Brute Force and Ignorance. I slipped a pair of tweezers over the shaft, beneath the bearing, and pulled hard. Came off and didn't damage the bearing.
Old 08-04-2014, 06:22 PM   #28 (permalink)
There might be a burr on the hole for the screw to secure the main gear. I've had mine out a couple of times and there was a little resistance but it did come out.
Once you get it off, the lower bearing will probably fall out of it's seat. Make sure you get it back in and fully seated on reassembly. Good Luck!
Old 08-05-2014, 10:30 AM   #29 (permalink)
Default Parts Replacement and "How To's" for the Blade 200 SRX
When replacing the swash and head with aluminum parts should I grease them? With what?
Old 08-05-2014, 06:46 PM   #30 (permalink)
Excellent tutorial Junkman2008. Thanks for taking the time.
Volsfan1 is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 02:52 AM   #31 (permalink)
Hi Junkman,
I keep saying well done because you have really put amazing amount of effort in,I do not know to much about forums but is there some way you can make sure we do not loose all the work that you have done .
Regards
John
janerol is offline        Reply With Quote Quick reply to this message
Old 08-07-2014, 12:11 AM   #32 (permalink)
Awesome man! Thanks so much.. printing in off now! Can you make a PDF of this for field use on the phone?
I had my rear tail motor plugged in backwards.... retard I know
Newbie with a Blade 200SRX RTF. Ask me about Dash Cams!
monkey2274 is offline        Reply With Quote Quick reply to this message
Old 08-07-2014, 03:18 AM   #33 (permalink)
Talking Problem out of the box
Great article and very useful will bookmark it.
Problems straight out of the box are not uncommon with the 200 SRX, mine wanted to tip heavily to the right and backwards when I got mine, and as stated earlier there is no point trying to level the swash plate until the heli has gone through its start up dance.
Thanks again for the repair manual
coolbird is offline        Reply With Quote Quick reply to this message
Old 08-07-2014, 04:30 PM   #34 (permalink)
Thanks Junkman for the very helpful detail - I am replacing my boom and didn't notice any reference to how far into or through the boom mount bracket the boom should go. I don't know if this is critical but I would like to know. Thanks again.
tulebender is offline        Reply With Quote Quick reply to this message
Old 08-07-2014, 06:08 PM   #35 (permalink)
The base of the boom has a slot, and there is a corresponding nub in the frame. When the boom is inserted correctly, it cannot go in any farther, nor can it rotate.
vmax911 is offline        Reply With Quote Quick reply to this message
Old 08-07-2014, 07:15 PM   #36 (permalink)
Thanks Vmax, I don't know how I missed that. It seems to fly okay but I'm going to dig in and make it correct. I can't believe what an excellent job Junkman did on his photos and written detail.
Old 08-07-2014, 11:00 PM   #37 (permalink)
The pleasure is mine sir.
Originally Posted by janerol View Post
Hi Junkman,
Regards
John
Well John, if the moderators make this thread a "sticky", it will always be on the first page and at the top of the 200SRX forum whenever you visit this area. If enough people request it, then maybe a moderator will deem it worthy. Just shoot any of them a request.
Let me see what I can do about a PDF document. It would be a decent size with all those pictures. One thing to note is that I am constantly updating my initial post with more and more information and pictures. If you have printed it off, make sure that you have the latest edition.
Vmax911 is correct. See the pictures below. I will update my initial thread to include this information.
Thanks again for the kudos gents.
Old 08-08-2014, 07:05 PM   #38 (permalink)
Default Another How To from HH
Junkman,
Might want to add this to the set of tools.
http://www.horizonhobby.com/pdf/BLH2...etup_Guide.pdf
Old 08-09-2014, 08:22 PM   #39 (permalink)
Is this posted on their website? Where did you get this?
Old 08-09-2014, 08:50 PM   #40 (permalink)
It is posted on the HH web site. A little more advanced but good info to have in setting up a new build or re-build.
