Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Like Tree2Likes
Old 09-06-2014, 08:59 AM   #1261 (permalink)
Originally Posted by Van Scott View Post
I keep saying this , but it surprises me of the lack of awareness to the fact that reliable Rescue has been available for several years.
BD was reliable but expensive, Brain was cheaper with an inconsistent rescue.
TheSpirit appears to be reliable and affordable.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 10:32 PM   #1262 (permalink)
Need some help, since the bailout gain has to be -# of your gain setting how do i set this up for diff gyro gains in different flight modes.
I'm using a dx6.
TRON 7.0 Advance / XL Power Specter NME WC 700 / SAB RAW 700N / SAB RAW 580N / XL Power Nimbus 650 / Goosky S1 & S2 / VControl EVO
Mr. Rmz is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 10:49 PM   #1263 (permalink)
I'm using a dx6.
Select the lowest one. It doesn't have to be the same; a gain that works just fine is all what's needed.
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 11:18 PM   #1264 (permalink)
Thanks, That's what i was thinking.
Old 09-07-2014, 01:01 PM   #1265 (permalink)
Ok time to go fly it.... finally.....
Old 09-07-2014, 04:09 PM   #1266 (permalink)
I flew it, was a pita so far compared to my beastx to tune but it works well... the bailout on 100% gave me a main blade strike on the tail blades... sounded like baseball bat hitting a home run. No issues just a small chip on the tip. Backed it down to 70 and it works well. :thumb up:
what's a symptom of to high of cyclic gain ?
Old 09-07-2014, 04:19 PM   #1267 (permalink)
Cyclic wobble on hard maneuvers.
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500
Jmann841 is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 05:58 PM   #1268 (permalink)
100% is a lot I have 60 and it shoots up fast but I do fly high as im a beginner, only time I'm near the ground is landing or crashing.
Im surprised your main blades can reach your tail blades? What model is it?
Apart from the setup how do you find it, any difference to the beastx?
ritchieicu is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 07:15 PM   #1269 (permalink)
I dunno yet, still gotta tweak it... I saw a video on youtube and i now know i need to adjust the cyclic gain.
I like the bail out and seems like it will get the job done. I also like the mac software.
trex 450l dominator.
Old 09-07-2014, 10:46 PM   #1270 (permalink)
Really starting to like my spirit. After moving it to be inline with the main shaft and several tweaking flights today. I am starting to really like it. Was still just doing circuits and flips today as it was fairly gusty, but hope to get a little more adventurous next weekend. Did not experience the reversed bailout that I saw last weekend, and all the logs were clean. Have noticed that the spirit app on my android phone when trying to connect after a flight will have a connection failure half of the time. If I close the app, the bluetooth module on the heli will still have a solid light, and I can't connect again till I cycle the flight pack. Still need to see if forcing a stop on the phone will clear the connection issue without the power cycle on the heli.
--citizen 19-- ama#986265, W8RMB, T-Rex 700n 700e, 600n, 550X, 550e, 500 efl pro, 450 pro.. a couple of planks and a couple of quads...I am not a rep for anyone
cyclenut is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 12:39 AM   #1271 (permalink)
This was filmed with my phone camera the wrong way so its skinny but this was the X3 with the spirit in it at the field today. A friend of mine tried it out and liked it a lot.
" frameborder="0" allowfullscreen>
Old 09-08-2014, 01:13 AM   #1272 (permalink)
One more of the Spirit in action on the X3
Old 09-08-2014, 03:10 AM   #1273 (permalink)
Does the same for me with the Vbar
Old 09-08-2014, 07:10 AM   #1274 (permalink)
Sure wish I could get one. I'm pretty sure it would have saved me about $85 yesterday.
akabud is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 08:03 AM   #1275 (permalink)
Nice flying; smooth and vivid. The Spirit does look locked in!
RealFlight 7
Old 09-08-2014, 11:34 AM   #1276 (permalink)
Wont play on my phone, shows as a broken icon
Old 09-08-2014, 11:44 AM   #1277 (permalink)
Yea, it is amazing, flies so well, especially considering that is a 450!
This was some friends flying it and really liking it as well! The was a cyclic jump on hard maneuvers, but, I went into the software and saw my elevator filter was a 0. It's recommended to be at 1 and is used to stop a cyclic jump on hard stops. Of anyone else gets it that's the parameter you need to adjust.
Old 09-08-2014, 01:51 PM   #1278 (permalink)
Jmann841: Nice videos!
cyclenut: You can turn off BT in your phone to disconnect from the module or just plug off the power from the BT module.
It seems as there is some problem in Android, but I hope we can fix it somehow.
Mr. Rmz: too high cyclic gain can cause mostly fast aileron oscillations. Elevator bounce can be compensated with elevator filter, default value is 1 but more agressive blades or too soft head dampeners can require higher values.
Spirit System - www.spirit-system.com
ZeXx86 is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 01:54 PM   #1279 (permalink)
Thanks ZeXx86, I will give that a shot. Btw I am using a fairly old phone- samsung repp running android 2.3
Old 09-08-2014, 02:34 PM   #1280 (permalink)
May be one of my tuning issues, Mine gave me a default of 0 on elevator filter.
