Old 08-01-2014, 03:27 AM   #1 (permalink)
Default VBar Control, calibrating Castle ESC
I've got a Castle Talon 90. I'm using the ESC governor, not the VBar governor.
The traditional way to calibrate to the ESC is to start w/ the throttle endpoints near the middle and then creep the lower limit down until the ESC arms. That's "-100%" on the ESC. On the high side, some advice is to just flip the value you have on the low side, or you can repeat the process on the high side. I can't really remember.
So on the VBar Control, there's a Governor set up option. It has High Limit (default 100) and Low Limit, default 100. I'm guessing this is where you do that business... set these to about 50, fire up the ESC, and then inch them out until the ESC arms. Make sense?
Then when you go to the Gov menu, and set a throttle percentage for you three flight modes, you can select any of the three ESC governor settings.
Now, what I don't know about is the ESC Wizard, which has the "Other ESC" choice.
I haven't backed my pinion off yet (pain in the butt on Logo 550SX) so I didn't just experiment. I was wondering if I could get the lowdown here or a pointer to a thread/page on it before I made a night of it.
Thanks.
Jim
PRTOS 500 Plastic, Logo 550SX/600SX, PRTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 08-01-2014, 10:43 AM   #2 (permalink)
Sticking my neck out here, My vcontrol is still in the mail
Are you sure that section of vcontrol isn't for setting up vbars native governor? That section sounds like the governor setup in the vbar computer setup app for 5.3.4 pro... Except in vcontrol not on the computer
I don't know why they would have a set up section in vcontrol for setting up a castle ESC governor, all of the various ESCs have different setup procedures, unlikely that vcontrol supports the setup of ANY of hem.them
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 08-01-2014, 05:54 PM   #3 (permalink)
Wow, I'll be the first to use a Castle gov with VBC?
SWEET. I'll be sure to video the fire.
Old 08-02-2014, 03:56 AM   #4 (permalink)
I posted this on the Mikado forum, and will report back if I learn anything.
I have a Castle (Talon) ESC.
For now, I will use the governor in the Castle ESC.
I think I figured out how to set the throttle endpoints to match the Castle ESC, but I'm not sure about the numbers I see.
If you have done this, please read this post and tell me what you think.
Normally, we set the Throttle endpoints to match the Castle range by following videos by MrMel and others.
- set the limits very far away from their normal values
- set the stick low, or throttle hold on.
- turn on the ESC
- move the throttle to high. ESC won't initialize because the high limit is so far off
- now move the high limit up until the ESC initializes (in program mode?)
- unplug the ESC
- set throttle stick to low, or throttle hold
- plug in, ESC will not initialize
- move the lower limit until the ESC initializes (makes music).
After that, when your VBar thinks it is putting out 100% throttle, the ESC also thinks it is 100%. Same for 0%
You can set three headspeeds in the Castle governor, and select them with throttle levels.h
On my VBar Control I tried to figure out how this should work.
I set VBar Control to "External Governor"
--- Endpoints ---
I go to + Model Setup + Governor + ESC Endpoints
There are two Limit adjustments, high and low.
They range from 40 to 100 (then can be changed to 0, but it shows 40).
I turn them both to 40
I turn off ESC
Set VBar Control into Motor Off mode -- low stick, but endpoint is set at 40 so output is way above 0.
Turn on ESC
The ESC does NOT initialize (good!)
Change the upper limit until it initializes. I got 102 or so. Add a couple of clicks.
Repeat for lower level
I got a value of about 65 for the lower limit.
65 seems like a small number, does it make sense?
So I set the endpoints at about 70 and 105
In my Spektrum DX8 I had 87% and 117%.
--- Speed Selection ---
Under + Governor I see "ESC Output".
There are three values, one for each Bank 1-2-3
The default values I saw were -20, 0, +20 (if I recall correctly)
By looking at the governor bar gauge on the main screen, I can see that +100 means "full throttle" and it only goes as far as the High Limit.
And -100 is "low throttle" and it also only reaches the Low Limit.
The bar gauge only reaches its "empty" and "full" state if the Limits are set to 100.
--- Setting up the Speed ---
In the Castle Link software, you can select 3 "Desired Head Speeds."
The first is selected at 30% throttle
The second is selected at 70% throttle
The third is selected at 100% throttle.
Those are on a scale of 0-100.
The VBar Control governor settings are from -100 to +100
I conclude that for
speed 1: VBar at -40
speed 2: VBar +40
speed 3: VBar +100
--- Conclusion ---
This all makes sense except that it doesn't seem right that the low limit setting is about 65.
--- Test Results ----
Well, with these settings I could only select the first two headspeeds in the Castle governor. The "100%" setting did not work. I set the governor value of Bank 3 to +100, and I even set the upper endpoint to the maximum. Using a tach on my bench with the blades off, and trying some different values, I am convinced I only get the first two headspeeds.
That's fine with me, though. I only want to use two headspeeds. I set #2 and #3 to the same value, and select it with a setting of +100.
I think I'm ready to fly my new VBar Control!
Old 09-26-2014, 07:07 AM   #5 (permalink)
Did you get any answers? I'm having the same problem. I want all 3 headspeeds though....
Wess Collette
VTeam
Optipower USA
WessCo is offline        Reply With Quote Quick reply to this message
Old 09-26-2014, 10:35 AM   #6 (permalink)
No, I settled for two headspeeds and went "Just go fly.."
Old 10-07-2014, 10:39 PM   #7 (permalink)
Once I calibrated my endpoints, (Edge and ICE) for the castle governor, I removed the blades (actually, I removed the blades before I even started the calibration process), and switched the motor on starting out in bank 1. I had to set an esc out value of 0 to get the CC governor to use the first desired speed. Bank 2 was 70 and bank 3 was 100.
That gives me the 3 desired headspeeds I input into the ESCs using the CC software. My basic settings were heli/governor mode/set rpm.
There will be no feedback on the actual rpm that the ESC is running, you will just have to tach it. FWIW, the ESC out values don't directly correlate to your JR/Spektrum/Futaba throttle curves. You just have to play with the numbers on the VBC to get the bank you want set.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 10-07-2014, 10:55 PM   #8 (permalink)
Cool report. I ordered hobby wing sensor and will do vb gov. Nice you figured it out, though.
Old 10-07-2014, 11:05 PM   #9 (permalink)
I am running the HW sensor on three of my helis, and the governor setup is really smooth on that method also.
I have enough sensors to do all my birds, but it is a pain to get the wires out so I can solder the leads onto two of them, but being lazy, and not doing hard 3D puts this into a rebuild/ frame split scenario.
Old 10-07-2014, 11:48 PM   #10 (permalink)
Right on.
Old 10-08-2014, 01:38 AM   #11 (permalink)
because the vbar goes from-100 to plus 100 the figures used for head speeds are -40, +40 and +100.
I have all 3 head speeds working with the above numbers.
You can set the motor to direct out for end point adjustments.
flyer2160 is offline        Reply With Quote Quick reply to this message
Old 10-08-2014, 01:47 AM   #12 (permalink)
I really don't think there needs to be a specific "one number" for the set rpm point. Even with the VBC, there is a range that will all give the same rpm, another range for rpm 2, and a third value (maybe not a range) that will give the third rpm. This is for the CC setup, not necessarily for other ESCs.
Old 10-08-2014, 03:53 AM   #13 (permalink)
Remember to first set Castle ESC in ENDPOINT for throttle type BEFORE you do the calibration. After the calibration you can go back and select throttle type to what you want.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 11-05-2015, 02:17 AM   #14 (permalink)
With the VBC and Castle's 4.22 version. there is no calibration need to be done.
Just set up the Edge or Ice assuming you are using the correct digital signal for the VBC into EXT gov - fixed end points (that's all you have available with ext gov) and do not check the auto rotation enable box in the castle link. Custom set the initial spoolup rate to 4, and then set all other parameters as you normally would, except the white wire on the Edge needs to be set to rpm out.
Now plug everything together, and go to model setup-governor and select the Castle ESC. Click ok and you are done there. Now just set up your heli parameters and use half of your magnet count into the box. Set your desired headspeeds for your banks and off you go.
