Old 08-12-2017, 06:37 AM   #421 (permalink)
It's sensitive to static
Skukoom 540 and static electricity (1 min 21 sec)
Goblin 570, HW platinum 100A HV v3, 700mx 530kv, 26t pinion (g630), Align bl815h cyclic, Xpert SI-2202T-HV tail, SK540 , 12s 3300mah, ~ 4 kg
Gaui x3, tarot 450mx 1700kv, SK540
Futaba T8J
miron is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 02:14 AM   #422 (permalink)
I can't calibrate sticks. It tells me that I need to from 65-135% travel. I have 90-100%.But it's failed.
Futaba T8J
Old 08-13-2017, 09:18 AM   #423 (permalink)
https://youtu.be/X3FLGTCUDrc
What are you trying to say by that?
Or in other word - why are you surprised?
Most if not all FBL are sensitive to static which might show in various forms between erratic behavior to a full in air reset.
If you are flying a logo ( or any belt driven heli) without anti static you are taking your own risk: it might work OK In some conditions but have one dry day and it will reset.
X7 | Scorpion 4525 Ultimate | scorpion 160HV ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | Skookum Robotics Support Pilot | SK540 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 09:39 AM   #424 (permalink)
I knew about that, but I never had it on my belt helis. 550 logo has different belt, maybe it works without inducing static electricity.
I didn't heard about full in air reset of because of c static electricity. I heard about.
I don't understand why there are no logs some times
Futaba T8J
Old 08-13-2017, 04:30 PM   #425 (permalink)
Logo is not different in the belt - it is different in the frame:
Most helis have carbon frame which is conductive and gets the charged belt discharged via the frame.
Logo has a plastic frame - non conductive...
Logs might not be saved because of a soft reset: either electrical V drops or maybe static if you don't have the anti static on
Old 01-19-2018, 09:55 AM   #426 (permalink)
Hi
I can't reset logs on my 540. I get the same file every time after flight. Reset log center and format flash drive not working.
Futaba T8J
Old 01-20-2018, 10:33 AM   #427 (permalink)
I don't know how, but I clean logs and reset.
I have RxA link lost error. I had hard crash of my logo due to control failure. Frame was totaly destroyed, I lost my fbl.
I get fbl from my gaui x3 and set to logo. Now I have RxA link lost error to. I use futaba sbus, wires are new. I touched wires, power up motor, there is no errors on ground.
First error at 4:33, flight started about 2:00
Futaba T8J
Old 01-20-2018, 10:36 AM   #428 (permalink)
Gaui x3 is with 720 now, connected as traditional reciever, no errors in logs.
Futaba T8J
Old 05-06-2018, 06:37 AM   #429 (permalink)
UPDATE: I finally was able to install the updated firmware. I kept trying anything I thought would work, and at one point I had my options open in the software menu. It's been a long day, and I might be a point or two off, but I believe the current version is 4.07. It flatout would not update to this version.
I kept seeing a few windows opening up, then I decided to go to Skookums website. I downloaded either 4.40 or 4.50 and all looked good. I still had no communications with my JR radio. Then after playing around, I tried 4.70 again and it finally updated the 720. It works like all my other ones, I set everything up including the Castle, then I tried a 2 or 3 inch short 5 minute hover. GPS is calibrated, but I will check the functions later.
I believe I saw almost every warning message thats in the 720, and at one point it stated my GPS memory was full!
I was just glad to get the gyro going and was a little tired and sore as I started this project last night. I was satisfied with everything, so now I am charging the batteries, going to rest a little, then I might try a test flight later this evening, or definetly tomorrow.
After I rest up, I am going to write down everything I remember about this experience. I heard many horror stories with several people sending theirs in to Skookum for repairs. I was determined I was going to get something done and was just about to put another 720 on the Heli so I could finish it up!
I just hope nobody ask exactly what I did, but my memory may be a little better later on today! LOL, finally!
Dennis
__________________________________________________ ______
Black 720 w/GPS 1
I know I have read somewhere about my current problem with my 720. I read this entire thread, and some post touched my issue.
My Issue: I have not used this 720 recently. Earlier today, I was installing this 720 on a new Heli.
When the Skookum software shows up, it states my Firmware is out of date, and do you want to update it now. Note: I have several 720's, all others are OK. I have setup all of them with just a little tweaking required.
But this one is showing the firmware version 3.43 , and please update. I know the current version is 4.??
I have tried everything to update the firmware, it states there are too many files in the root directory on your gyro's flash drive. Also states to move them or delete the "first".
Using Win 7, the laptop recognizes the 720 and GPS, the GPS locks in. Looking at the properties, it shows the gyro is 98% unused.
I tried 2 other 720's I have and they work perfectly on my laptop.
I have run out of options trying to update the firmware. Almost all of the menu commands are grayed out.
Suggestions, or how to solve this issue?
Thanks in advance for your help.
Last edited by TRex700MRX; 05-06-2018 at 02:53 PM.. Reason: I finally got it to update!
TRex700MRX is offline        Reply With Quote Quick reply to this message
Old 07-12-2018, 08:41 AM   #430 (permalink)
Hi
I have problem with motor cut-off during flight. I tried SK gov and HW ESC gov. ESC gov after cut-off do not spool up. I have to logs with SK gov. I don't know how to change tail banks , because I did't setup this. Also I haven't touched any switches in flight. It is realy strange. Futaba T8J S-FHSS sbus. Sometime there are no cut-offs, I have about 1-2 cuts in one flight of 3 flights
Futaba T8J
Old 07-12-2018, 03:24 PM   #431 (permalink)
Hi
Its hard to say exactly but it sounds like a motor problem. try another if you have.
Old 07-12-2018, 03:38 PM   #432 (permalink)
Done. KDE 600xf 530kv replaced by 700mx 530kv
Futaba T8J
Old 07-12-2018, 03:41 PM   #433 (permalink)
test
Old 07-12-2018, 03:47 PM   #434 (permalink)
Originally Posted by omerco View Post
test
I have 20 flights with 700mx after KDE
Futaba T8J
Old 07-12-2018, 03:50 PM   #435 (permalink)
not following:
did you have the problem with both motors?
Old 07-12-2018, 04:00 PM   #436 (permalink)
not following:
yup
Futaba T8J
Old 07-12-2018, 05:01 PM   #437 (permalink)
yup
My best guess is itís either the esc or you have a short to the frame somewhere.
Have another esc?
Old 07-13-2018, 04:10 AM   #438 (permalink)
My best guess is it’s either the esc or you have a short to the frame somewhere.
Have another esc?
I can ask my friends to find not used ESC
But I can't understand how tail bank is switching in flight. No one of my switches can change it. It changes depends on tail gain. I can change bank by changing gyro channel revers only
Futaba T8J
Old 07-13-2018, 05:54 AM   #439 (permalink)
I turned up radio and didn't touch it
I think that it's time,to change transmitter...
Futaba T8J
Old 07-13-2018, 07:25 AM   #440 (permalink)
That’s the logic of tail banks: from center pulse to one side it’s one bank and from center to the other is the second, while the number sets the gain. Most fbl act so.
It also sound like your gain is not set correctly on the tx
Human Verification
