Go Back   HeliFreak > R/C Electronics Support > Spartan RC > Spartan Vortex
Spartan Vortex Spartan RC - Vortex VX1 Factory Support Forum
Old 03-26-2016, 11:58 AM   #1 (permalink)
Default Hobbywing 100 V3 and Jeti DS-14 plus VX1n
I spent a few hours today with the setup of my Goblin 380 with my new DS-14.
Everything worked flawless with my futaba before. Just a new receiver and a new TX.
Everything setup, throttle calibrated on the hobbywing. BUT then nothing moves.
Throttle up, down ... Nothing...
Has anyone the same or a similar setup?
Same issues maybe?
Vortex vx1n v 4.52
Jeti Rex 6, beta v from Angelos
Hobbywing Esc in Heli mode
Oliver
hydro-heli is offline        Reply With Quote Quick reply to this message
Old 03-26-2016, 12:26 PM   #2 (permalink)
There is a very useful guide in the thread below post #1 that should help you out.
https://www.helifreak.com/showthread.php?t=733744
T-Rex 700 Dominator vx1e, Goblin 570 vx1e, T-Rex 600N DFC vx1e, Jeti Ds-14
NSFlyer12 is offline        Reply With Quote Quick reply to this message
Old 03-26-2016, 12:56 PM   #3 (permalink)
Could be throttle channel output from the Jeti. With the model off, open the menu on your Jeti and then I think button 2 is the servo monitor which shows you the actual output of the channels. Are you seeing the throttle react as you expect?
The next thought is mapping of channels on the Vortex. These should change automatically as you select the protocol, but check that the channels on the Vortex match the Jeti.
Finally, what protocol and wiring are you using? The Vortex won't initialize unless it sees a throttle signal, a few people have gotten caught out by that.
Electronics: Spartan Vortex, MSH Brain, Jeti DS-14
Sims: RealFlight & AccuRC
Other: Team rep for Lynx/Oxy, working on NightWave Systems
myxiplx is online now        Reply With Quote Quick reply to this message
Old 03-26-2016, 01:16 PM   #4 (permalink)
Hi
I used the guide from myxiplx to set up my Jeti from scratch.
I was suprised that the channels were completely different in the vortex. I rearranged the channels that they match the vortex needs.
Every channel is appropriately adjusted...
I'm using the EX Bus connection to the REX receiver.
Oliver
P.S. The guide to setup the Jeti TX is just awesome!!!!
Old 03-26-2016, 02:15 PM   #5 (permalink)
Can I check what is and isn't working. Do you have the Jeti integration working so you can program the Vortex from the Jeti? Do the servos work?
Old 03-26-2016, 02:16 PM   #6 (permalink)
Originally Posted by hydro-heli View Post
Hi
Oliver
Old 03-26-2016, 02:44 PM   #7 (permalink)
Everything is working besides the ESC... :-(
The whole vortex and Jeti setup is done and working.
Old 03-26-2016, 06:03 PM   #8 (permalink)
Do you have the governor enabled on the Vortex? If so, have you tried with it disabled?
If you haven't already, it might be best to disengage the pinion or remove the blades if you're having to troubleshoot this.
Old 03-26-2016, 06:08 PM   #9 (permalink)
The only other thing that comes to mind is the throttle signal being reversed somehow. Does the ESC even initialise?
Old 03-27-2016, 12:13 AM   #10 (permalink)
Governor set to inhibit, throttle servo setting to 1520 us.
The ESC does all the beeps and arms, but beside a constant sound when raising throttle, nothing happens...the motor isn't spinning up...
Old 03-27-2016, 01:22 AM   #11 (permalink)
Have you checked the connections on the throttle lead?
Old 03-27-2016, 01:42 AM   #12 (permalink)
Yes, I programmed the BEC voltage from 5 to 8.4 V with the TX and it worked...
Old 03-27-2016, 02:09 AM   #13 (permalink)
I wonder if your low throttle position may not be low enough for the ESC to arm.
Old 03-27-2016, 02:39 AM   #14 (permalink)
The ESC arms, at least what I understand from the beeps...
I took another REX6, just connected the throttle wire directly to thr RX, so bypass thr vortex. Same behaviour!
See my short video attached how the ESC beeps and behaves.
https://vimeo.com/160501695
Old 03-27-2016, 03:40 AM   #15 (permalink)
Is that screech coming from your ESC? If so I suspect you may have a timing issue there. Have you checked your motor specs and set your PWM and timings in the ESC?
Old 03-27-2016, 04:09 AM   #16 (permalink)
Yes it's the motor.
I juggled arround and tried now some other than the default settings, but still no movement.
Still weird, that on my futaba config all worked with the default settings.
Maybe I'll try another mode like the plane mode, to see if this works...
Old 03-27-2016, 08:05 AM   #17 (permalink)
Obvious, but motor turns by hand, no spare screws inside there, for example.
Soldering good. It's possible to beep well even with one phase down.
Try another motor, if you have one.
Can you run it from another quick and dirty set-up of Rx and ESC only on the bench. A quick thrown togther set-up from any old junk you have spare.
Sorry, I just see it all worked with Futaba, but can't hurt to do some quick re-checks.
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE ÁB, FBL Trex450Pro ÁB,
sutty is offline        Reply With Quote Quick reply to this message
Old 03-27-2016, 08:40 AM   #18 (permalink)
Are you seeing 0-100% in transmitter live throttle menu in vortex setup , assuming you have linear throttle curve?
Forza450EX, trex500, MOSTRO700, PROTOS MaxV2.
helibadger is offline        Reply With Quote Quick reply to this message
Old 03-27-2016, 09:44 AM   #19 (permalink)
Thanks sutty, I'll check with a new motor, or I go with a spare castle esc, to check the motor.
I can turn it by hand, no problem.
The live throttle shows perfect 0-100%.
Could it be, that i screwed a motor phase by supplying the vortex through a 2S lipo with connected BEC output from the ESC?
Old 03-27-2016, 10:10 AM   #20 (permalink)
If you had the ESC BEC connected, and you supplied the Vortex with 2S, then yes, that can damage an ESC. How exactly that would show up I'm not altogether sure.
The tests are worth it though. I always like to test things independently, in very simple set-ups, so that I know that I'm not chasing my tail. Then when I bring it all back together I know they were all working separately moments before, and it must come down to how I am setting it up.
Regards, Sutty
