Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Like Tree10Likes
Old 03-11-2016, 10:10 PM   #21 (permalink)
Originally Posted by Snowflake6515 View Post
If you have correct stick and diagnostic bar movement with Tx channels set to normal (i.e., not reversed), and the servos are connected per the diagram in the Wizard setup page, then the only other factors are: (1) selecting the correct Pro mounting orientation and (2) Wizard Ch1-4 possible reversing.
For example,the visual image shows the Pro mounted with the pins to the front and there is a label "Horizontal (180)" or something similar. The Wizard seems to default to "Horizontal". That would lead to incorrect collective, roll, or pitch operation. That, in turn might lead to reversing things in the Tx and getting into a deeper hole. So, be sure that you selected the correct image...
If the collective, roll, and pitch all respond correctly, then stabilization direction can be verified, or set by possibly reversing CH1-3 with the rudder compensation direction controlled by CH4.
With R2.0, a lot of guesswork was removed and I found that being meticulous in following the Wizard worked.
Michael
Thanks for the reply Michael! I'll go back over it and check it out. I have Version 2.0 on it, and I seem to remember there was something about channel 1 and 3 plugs may need to be reversed or something also.
Thank you again, oh I took a pic of it here it is...https://drive.google.com/open?id=0B1...0ZOdXdkVWhiSlU
Rodney
Blade: Nano QX, SR, 230s, 400 3D
Walkera: V120D02s
Align: 450L Dominator, 450 Pro DFC,
500 Pro DFC
nighttrain06 is offline        Reply With Quote Quick reply to this message
Old 03-12-2016, 01:03 PM   #22 (permalink)
Hello Spirit Gods! I am at wits end here with my Spirit Pro!!!!!
I cannot get it to bind no matter what!
I originally when I received it the other day had it bound set up, but realized I had an issue with servo compensation going the wrong way when the heli was tilted. My unit sits on back top with pins toward the tail. I had the unit configured to just horizontal, and not I assume horizontal 180 as it was supposed to be. So I did a factory reset, so I could just start all over. There the problem started with trying to bind the unit.
It shows version 2.0 when trying to bind it the sat (plugged into the correct port for DMX sat flickers rapidly, the status light is on solid, but when attempting to bind the unit light stays solid, sat light goes out and stays out through the bind. Any help here?????? I am getting pretty pissed! Lol
Walkera: V120D02s
500 Pro DFC
Old 03-12-2016, 01:58 PM   #23 (permalink)
What do you mean by that?
Sure you selected your Receiver type, SAVED, rebooted with bind plyg?
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 03-12-2016, 02:57 PM   #24 (permalink)
Yup I did about 50 times! I am beginning to wonder if for some reason it is either not recognizing the SAT or the program itself won't let it.
Walkera: V120D02s
500 Pro DFC
Old 03-12-2016, 05:25 PM   #25 (permalink)
I think I need help with the actual program!
I think the issue with my non binding unit is somehow it is not recognizing that this is a Spirit Pro and instead a regular Spirit....
Name:	Spirit issues.jpg
Walkera: V120D02s
500 Pro DFC
Old 03-12-2016, 05:33 PM   #26 (permalink)
I would delete the program and re-download and install then select proper unit.
Compass Chronos & 6HV,6HVu,Mcpx BL,CFX180
DS-16!!,Phoenix 5
Team Flybar & "Less" now
LubeMan1 is offline        Reply With Quote Quick reply to this message
Old 03-12-2016, 06:56 PM   #27 (permalink)
Yes I did that also! I'm wondering if there is a little piece of the program somewhere that was not uninstalled and causing issues or something.
I've got something cocked around here, because it bound right up initially!
Walkera: V120D02s
500 Pro DFC
Old 03-12-2016, 08:59 PM   #28 (permalink)
So are you having problem binding you TX to your Sat? or are you having a problem getting your PC to connect to the Spirit with the software?
DS-16!!,Phoenix 5
Old 03-12-2016, 09:40 PM   #29 (permalink)
Binding to the sat.....I already had it bound to it, but did a reset, because in setup I had the wrong oriantation set for the mount of the unit. After that no bind city! :-(
Walkera: V120D02s
500 Pro DFC
Old 03-13-2016, 12:23 AM   #30 (permalink)
I wonder why you did a reset instead of just changing the orientation setting
Anyway, what about trying what suggested in the second post here:
http://www.spirit-system.com/phpBB3/...hp?f=20&t=1088
Old 03-13-2016, 12:39 AM   #31 (permalink)
Habit from the BeastX setups, i always just did factory resets on em when doing a new model....even though this was the same model I just reset it. I would have went all the way through the setup again anyway.
I didn't see that, but my problem with it is the sat is flashing as soon as the radio goes into bind, the light goes out and doesn't come back on. I have read this and that tried this and that to no avail. It's still doing the same thing!
Walkera: V120D02s
500 Pro DFC
Old 03-13-2016, 09:28 AM   #32 (permalink)
Default Can we keep this topic for the setup guide only?
It would be great if new questions got their own thread, rather than everyone piling on this sticky thread RCGroups-style.
Heli-X, Gaui X3 & Gaui X5 w/ Spirit FBLs, Quads with BetaFlight, Various FPV Fixed Wing w/ ET Vector FC, FrSky QX7S w/ OpenTX, FMA DPL 8x2
kirby_ is offline        Reply With Quote Quick reply to this message
Old 03-13-2016, 09:54 AM   #33 (permalink)
Yes your correct! Sorry, in the middle of searching for answers to this problem that's still unresolved I still have a unit that will not bind. I apologize. After jacking with this thing for 2 days I wasn't paying attention...where I posted it. Thank you for your guidance at least of where I should have posted this. I hate when people do that too.
Walkera: V120D02s
500 Pro DFC
Old 03-17-2016, 08:42 AM   #34 (permalink)
What are you having trouble with specifically?
All good on the cable connections,and I think I followed the dx9 setup ok,,so I`ll finish and give it a try on the bench with the blades off
bill rob is offline        Reply With Quote Quick reply to this message
Old 03-17-2016, 08:54 AM   #35 (permalink)
Thanks for the DX9 set up guide,helped me loads,step by step with no parts missed,great!
Old 06-29-2016, 02:45 PM   #36 (permalink)
Did you try another sat? I had the same problem, I switched the sat out and everything bound .
Align 470LP, ALZRC 450Rigid ,ALZRC D380,Oxy2FE,Blade 230s,Blade 180cfx,XK-K110
Spazztl is offline        Reply With Quote Quick reply to this message
Old 08-30-2016, 02:07 PM   #37 (permalink)
is there a gov set up area in the user manual? i don't see it. I just want details on specs ...
Blade 300CFX, 450. Align: 450pro(3S), 500(6S), 600E(12s), 600N, 800E(12S). X-cell: Ion700(12S)
HELI_FUN is offline        Reply With Quote Quick reply to this message
Old 08-30-2016, 04:33 PM   #38 (permalink)
http://wiki.spirit-system.com/index....AD/en#GOVERNOR
DS-16!!,Phoenix 5
Old 08-30-2016, 04:58 PM   #39 (permalink)
Thank you sir
Old 10-26-2016, 05:40 PM   #40 (permalink)
Great tip
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
