Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Scale Projects <790
Scale Projects <790 Scale Projects <790 Discussion
Like Tree46Likes
Old 04-06-2019, 09:23 PM   #541 (permalink)
HF Scale Support
There are nav lights on the horizontal tail which cover the standard degree of view.. I think those on the underside are for viewing from directly ahead of the helicopter and from directly behind. I don't know why from behind as that can be confusing for any approaching pilot but the white positioning marker and the rotating beacon on top of the tail, should make it perfectly clear to a rear approaching pilot what he is dealing with. Hope this helps.
Don
Xsiluro likes this.
Old 04-06-2019, 10:16 PM   #542 (permalink)
Thanks Don! Interesting concept...
getsuyoubi is online now        Reply With Quote Quick reply to this message
Old 04-07-2019, 02:17 AM   #543 (permalink)
Yes as Don explained idea behind half covering is exactly that those position lights are visible from the front and from rear, but not from side.
I was checking both Police Jet rangers S5-HPE and S5-HPD and both have same half lights coverings mounted.
Have a bandit day
Peter
ID:	786539   Click image for larger version
ID:	786541   Click image for larger version
SAB GOBLIN 700, Vbar,YGE 120HV,ALIGN MX750, Gryphon BEC
Scale JET RANGER III 700 size with Flasher 600 mechanics under developement,
Futaba Transmitter T14SG !
Xsiluro is offline        Reply With Quote Quick reply to this message
Old 04-07-2019, 11:54 AM   #544 (permalink)
Moving further,.. I made hatch for front triangle opening,..
That's all for now,.. Enjoy!
Peter
ID:	786573   Click image for larger version
ID:	786575   Click image for larger version
ID:	786577   Click image for larger version
Name:	front triangle opening_closed.jpg
ID:	786579   Click image for larger version
Old 04-16-2019, 11:43 PM   #545 (permalink)
Peter
The metal side plates on the lower nav lights are apart of the BHT / AA float kit, to stop the glare from the lights hitting the floats, while still visable from the front, plus the lower lights are only on float equiped heli's as the type cert with the floats on, did not meet the full spectrum that the cert requires regarding on what angles the nav lights must be visable to other aircraft.
Hope that info helps, great build project you have going
Xsiluro likes this.
rex09 is offline        Reply With Quote Quick reply to this message
Old 04-17-2019, 11:44 AM   #546 (permalink)
I'm still puzzled. With the metal plates shaped the way they are, doesn't that mean that each individual of the two lights is seen from the opposite side (green from the left, red from the right), while the metal plates prevent them from being seen from the "correct" side (red from the left, green from the right)?
I'm sure I must be misunderstanding something here, but I wonder what it is.
Old 04-19-2019, 10:01 PM   #547 (permalink)
That is how the real heli kit instructions are. I too, remember asking the tech rep the same question 20+ years ago, it is all to do with what the side on coming aircraft see's, you are only allowed one nav light visable from the side, hence these are diffrent locations, in a banking turn you may not see the top light, and if the lower light was hidden by the float you would not see any?, but you will see the opposite light, but if the colours are the same, then you would be seeing the wrong light? that is why they put them that way, straight and level, head on you would only see the top lights, not the lower one.
It still sound confusing, but that what is in the BHT, SI. I do not have access to the SI at home, but can look it up at work.
It tells you to install them that way, not why!!
Xsiluro likes this.
Old 04-20-2019, 02:50 AM   #548 (permalink)
Moving forward with build. Made structure hardening on the left front part of cabin,...
Waiting for Epoxy to cure to move forward,..
Enjoy,
Peter
Name:	Structure hardening front.jpg
ID:	788603   Click image for larger version
Name:	Structure hardening front left.jpg
rex09 likes this.
Old 05-18-2019, 01:02 PM   #549 (permalink)
Finally manage to squeeze some time to make templates for seats,..
Templates are roughly done, some trimming to be done and gluing ahead,..
Till next time enjoy!
Peter
ID:	793625   Click image for larger version
ID:	793627   Click image for larger version
ID:	793629   Click image for larger version
ID:	793631   Click image for larger version
