Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Scale Projects <790
Scale Projects <790 Scale Projects <790 Discussion
Like Tree47Likes
Old 04-20-2015, 05:30 AM   #141 (permalink)
Beautiful detail work!!
you inspire me to detail my Bell 407 700 size.
And you're right... time is the hardest thing to have enough of
Roy Mayoral
heli143 is offline        Reply With Quote Quick reply to this message
Old 04-20-2015, 07:07 AM   #142 (permalink)
Hey Roy, thanks for kind words! Inspiration is always welcome
Cheers,
Peter
SAB GOBLIN 700, Vbar,YGE 120HV,ALIGN MX750, Gryphon BEC
Scale JET RANGER III 700 size with Flasher 600 mechanics under developement,
Futaba Transmitter T14SG !
Xsiluro is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 04:33 PM   #143 (permalink)
Some goodies coming my way ,.. this time links for JR III head,.. made by Saso
Just can't wait to test them with psssst,... updated follower,...
To be continued
Old 04-21-2015, 09:16 PM   #144 (permalink)
Peter"
Pitch links are Fabulous !! .. Even tapered toward the threaded ends .. and maybe a check-nut near the ball end ?!
I've been dreaming of making pitch links like that, that don't look like "toothpicks" .. I actually bought a mini-lathe and mini-mill for some of these little projects !
Also noticed your added accordion boot between the swash plate and swash follower .. PERFECT !!
GREAT work, on your part .. keep those reports coming .. many of us are watching and enjoying your great scale work ..
Russ
MiniBoy is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 11:41 PM   #145 (permalink)
Hey Russ thanks for your reply. I will add blueprint in next posts with measures if someone wishes to manufacture pich links.
Cheers,
Peter
Old 04-22-2015, 08:19 PM   #146 (permalink)
Peter:
EXCELLENT ..
Also please include if you are using Left / Right threading and thread size on pitch link rods ..
Thanks,
Russ
Old 04-23-2015, 03:15 AM   #147 (permalink)
Will do Russ, threads are M3 but at this point since I do not have it yet with me I can't check what side threading it is manufactured.
Will report back as soon as I get my hands on those beauties
Cheers,
Peter
Old 04-23-2015, 06:18 PM   #148 (permalink)
Peter:
That is good info on the M3 threads ..
Really all I have to know .. I can make Left Hand and Right Hand threads and drill a small hole through the side of the pitch link to adjust pitch and tracking with a small piece of music wire, or small hex key ..
Please send me blueprint anyway .. for link diameter .. would guess at 5MM or so ..
Russ
Old 04-24-2015, 05:58 AM   #149 (permalink)
Russ you are near exact thickness with your guess. At the center it is 5,6mm. I will add bluprint as soon as I get back home.
Edit: adding blueprint
Peter
Old 04-24-2015, 11:09 PM   #150 (permalink)
Peter:
THANK YOU !!
Printed out .. in my Century Swift / Bell 206 file ..
Much appreciated ..
Russ
Old 04-25-2015, 12:55 AM   #151 (permalink)
No problem Ross, hope links bluprint will be useful. Maybe double check the lenght, for your main rotor head. I am using longer shaft.
Have a great weekend,
Peter
Old 04-30-2015, 04:17 PM   #152 (permalink)
Again I had some time to continue with my build,... I have moved hinges to the place where the real heli have them. Hols from previous Roban instalation are still seen.
Cargo bay,...
That is it for now,...
ID:	583145   Click image for larger version
ID:	583146   Click image for larger version
Old 04-30-2015, 09:02 PM   #153 (permalink)
WOW .. Peter:
You are certainly going to great effort to make your Jet Ranger as scale as possible ..
GREAT Work, as usual !!
Russ
Old 05-01-2015, 12:14 AM   #154 (permalink)
Russ thanks, I am trying my best, heli to look as close as possible to the real one,... I was adding another important detail, belly strobe light with tube where the light is installed.
On the real one this detail looks like this:
The look on my project is this:
I have used Aluminum tube that I have covered with Polystyrol and glued everything with epoxy glue to the fuselage.
Added some hols to the belly and now this would be more or less everything on the belly.
To be continued,...
ID:	583229   Click image for larger version
Name:	belly lights.jpg
ID:	583230   Click image for larger version
Name:	belly lights 2.jpg
ID:	583231   Click image for larger version
Name:	belly lights 3.jpg
Old 05-01-2015, 08:38 PM   #155 (permalink)
Peter:
AWESOME details !!
Would you mind sharing your source for the strobe light and lense ??
I am looking for REALLY bright strobes, as well as landing and position lights, and would like not to have to make my own Fresnel lenses, if I can buy them somewhere ?!
Russ
Old 05-02-2015, 12:08 AM   #156 (permalink)
Russ hi, regarding Led covers lens I used Emcotec lens cut one top off and glued with epoxy another one on the top. https://www.helifreak.com/showpost.p...2&postcount=96
Thaw I will probably try to 3D print those lens.
Well guys my work on cargo bay is more or less finished, did add some aditional details,..
The real one:
And my is looking like this after face lift Adding 0,5mm polystyrol and a lock from Hobby King
Details inside cargo bay,...Material used Glass fiber 0,1mm cut to reduce weight and covered with 0,5mm polystyrol,...
That is it for now
Cheers,
Peter
Name:	Cargo bay_real.jpg
ID:	583440   Click image for larger version
Name:	cargo bay upgrade 2.jpg
ID:	583441   Click image for larger version
Name:	cargo bay upgrade.jpg
Old 05-03-2015, 02:48 AM   #157 (permalink)
Hi today I was working on detail on the right rear side of the fuselage,...
Real one have it like this:
Detail on my fuselage;
Material used polystyrol and a lot of cuting and sanding,..
I have also trimmed a bit the tube for strobe light now it comes lower as on the real one.
Until next time enjoy,...
Name:	desni bok zadaj.jpg
ID:	583627   Click image for larger version
Name:	desni bok zadaj1.jpg
ID:	583628   Click image for larger version
Name:	desni bok zadaj2.jpg
ID:	583629   Click image for larger version
Name:	desni bok strobe light trimmed.jpg
Old 05-03-2015, 12:49 PM   #158 (permalink)
Well guys my good friend, persuaded me to use magnets instead of lock, since lock realy gives Cargo bay a redneck cottage look
Here is new look far more pristine,...
There are some details to be taken care off, but now Cargo bay looks like real one
Enjoy,.. Peter
Name:	cargo bay upgrade 3.jpg
ID:	583675   Click image for larger version
Name:	cargo bay upgrade 4.jpg
Old 05-03-2015, 02:09 PM   #159 (permalink)
Phoenix was right.. It does look a lot better...
Gh
goodhunting is offline        Reply With Quote Quick reply to this message
Old 05-03-2015, 02:25 PM   #160 (permalink)
Jepp he was right, Gh,..
