Old 09-05-2014, 04:56 AM   #1 (permalink)
Hi folks,
Weight saving is a regular topic here, so I thought it might be handy to start a thread documenting the weights of various options.
I've been as accurate as I can with these, but some of the information is gathered from other threads, please let me know if you spot any mistakes.
Edit: Added URL to Google Docs Spreadsheet:
https://docs.google.com/spreadsheets...it?usp=sharing
Cyclic Servos
  • 7.6g - Eflite DS76
  • 12.7g - Align DS410
Tail Servos
  • 7.6g - Eflite DS76t
  • 8.4g - Hyperion DS09-GMD
  • 12.7g - Align DS420
  • 20g - KST DS215MG
  • 21g - DS95i
FBL Controllers
  • 6g - de-cased iKON
  • 10.62g - Spartan VX1e
  • 11g - BeastX MicroBeast Plus
  • 12.26g - Align 3GX
  • 13g - IKON
  • 18.6g - BeastX AR7200BX
  • 20g - BeastX MicroBeast
Canopy
  • 11g - Trex 250 Plus painted plastic canopy (may need trimming to fit)
  • 19g - Trex 250 SE fibreglass canopy
  • 20g - Trex 250 Pro fibreglass canopy (some folks have reported up to 24g!)
ESC
  • 7.2g - Talon 15 (with wires)
  • 15g - Align RCE-BL15X (yellow ESC)
Skids
  • 6.77g - Hobbyking HK-250GT skids with baseplate & pipes (GT250-121 )
  • 8.5g - Align multipiece skids (pipes with caps are included @1g each)
  • 8.9g - Align one piece skids
Base plate
  • 0g - Hobbyking integrated into skids
  • ?? - Stock plastic
  • 3.2g - Microheli Aluminium base plate
  • 6g - KDE Direct Alu base plate
Tail boom
  • 3.78g - Align CF boom
  • 4.82g - Align plastic boom
Tail pushrod
Battery connectors
  • 0.7g - JST connector pair (Rated for 3A)
  • 1.4g* - EC2 pair, weight without solder (Rated for 15-20A)
  • 2g - Mini-T connector pair (inc solder) (Rated for 15A)
  • 6g - EC3 male & female pair (inc solder)
Misc
  • 0.6g - Chinese Weights from HELM JOINT (adds 0.4g once screws are replaced).
  • 2-4g - Trim ESC & motor wires
Myx
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Last edited by TowPilot; 09-21-2014 at 07:38 PM.. Reason: added URL to Google Docs Spreadsheet
Old 09-05-2014, 07:55 AM   #2 (permalink)
Rudder servo:
Kst DS215MG-20g
Can get more weights when I get home tonight
hitman13429 is offline        Reply With Quote Quick reply to this message
Old 09-05-2014, 08:18 AM   #3 (permalink)
Which beastx are u referring to? Ar7200bx or a microbeast?
"I fly because it releases my mind from the tyranny of petty things."
Jay Helifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 09-05-2014, 08:43 AM   #4 (permalink)
I don't know, I don't have one myself and I've lost the thread where I saw the weight. I'll look those up and add them in separately
Old 09-05-2014, 11:42 AM   #5 (permalink)
Ar7200-18.6g
Micro beast-20g- no satellite attached.
Info off of horizons site.
Old 09-05-2014, 11:48 AM   #6 (permalink)
Thanks guys, added those in.
My tail died today and stripped my belt, and while digging through my spares drawer I realised I've a carbon boom I didn't know about. That's another gram of weight that'll be coming off as I rebuild it
Old 09-06-2014, 06:50 AM   #7 (permalink)
Fancied the carbon boom, but been a bit sceptical as it don't like vibes so was wondering if it would be a good idea, knowing what the 250 is like,
What goes up must come down, preferably controlled,
Trex 250 DFC with Vx1n, Trex 500 DFC with Brain
Emax 250 with CC3d, X4, Dx8 and iCharger 3010b
Slobberdog is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 01:17 AM   #8 (permalink)
The HK-250GT Base Plate and skids w/ Skid pipes is 6.77g.
I noticed no issues with swapping out my aluminum boom for the carbon.
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX.
buzzsaw 46 is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 10:19 AM   #9 (permalink)
Hey Buzzsaw, how well do those Hobbyking skids and base fit? Do they drop straight on?
For the price even if they break they're an easy way to shave a little more weight.
Old 09-07-2014, 11:49 AM   #10 (permalink)
Originally Posted by myxiplx View Post
Skids
What would the weight of the multipiece skids be if you remove the two alu tubes?
Helmet is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 12:28 PM   #11 (permalink)
The tubes plus end caps are exactly 1g each.
Old 09-07-2014, 04:00 PM   #12 (permalink)
My heli started as an HK250GT so I have the HK frame but from what I have read the HK frames are a direct replacement for the Align, So if the base plate didn't change between the SE and the Pro it should fit no problem.
Mine have held up to a crash on a gym floor and three waist high autos due to a loose tail hub, I should throw a couple in my cart next time I order, now that I know how light they are.
Old 09-07-2014, 04:06 PM   #13 (permalink)
They're dirt cheap too, I'm already wondering what I need from HobbyKing just so I can try a set :-)
Old 09-07-2014, 04:46 PM   #14 (permalink)
Makes it easy to have a set or two on hand just incase. You should just need the base plate and skid pipes, skid nuts if you want non-slip grip
Dooh Now I get it not worth shipping on $3.00 worth of landing gear
Old 09-07-2014, 04:56 PM   #15 (permalink)
Yah only thing thats costly on hk is shipping thats why u have to make big orders but then hk messes it up, oh the terrible paradox
Old 09-08-2014, 12:33 PM   #16 (permalink)
IKON: 13g
mba83 is offline        Reply With Quote Quick reply to this message
Old 09-12-2014, 12:45 PM   #17 (permalink)
Added some connector weights as I've got to get rid of the EC3's on mine. Think I'm gonna go for EC2s as I do like these little things
Old 09-20-2014, 10:44 AM   #18 (permalink)
Gonna have to post details later when I get time, but the HK 250 skids are epic! They're not as stiff or well made as the align parts, but there a huge weight saving from those.
I've swapped to EC2 connectors and the HK skids and I'm under 307g now with stock cyclic servos :-)
Old 09-20-2014, 11:14 AM   #19 (permalink)
Here we go:
Switching from EC3 to EC2 connectors saved me 3.3g. Then there's another 5g from the HK skids:
Align 250 baseplate & skids: 10g
HK 250 baseplate & skids: 5g
Old 09-20-2014, 11:20 AM   #20 (permalink)
Does anybody know if there's a way I can carry on editing the first post for this thread? I'd like to keep it up to date with weights we find out, but I can't edit it any more.
