Old 09-20-2014, 02:19 PM   #21 (permalink)
Originally Posted by myxiplx View Post
Does anybody know if there's a way I can carry on editing the first post for this thread? I'd like to keep it up to date with weights we find out, but I can't edit it any more.
How about this shared Google docs spreadsheet? (The URL is below.) They use one over on the Goblin 500 forum to track setups, and the OpenPilot open-source flybarless project uses one for shared tracking too. Anyone with the URL (below) can modify it. It's a great collaboration tool. (You can add links, too, which makes it easy for people to do research. I went ahead and added a few.)
I added some entries just to get it started. <edit> I also loosened up the log in restrictions so anyone can edit it now. </edit>
If everyone tries to use the same format, it should be pretty sortable. (BTW, press CTRL+Enter to add a second line to a cell.)
https://docs.google.com/spreadsheets...Ppw/edit#gid=0
Last edited by Harbormaster; 09-22-2014 at 09:55 AM.. Reason: Updated link for spreadsheet
Harbormaster is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 02:21 PM   #22 (permalink)
Originally Posted by Harbormaster View Post
How about a shared Google docs spreadsheet? (Link below). They use one over on the Goblin 500 forum to track setups, and the OpenPilot open-source flybarless project uses one for shared tracking too. Anyone with the URL (below) can modify it.
I pasted in some numbers just to get it started. Press CTRL+Enter to add a second line to a cell.
https://docs.google.com/spreadsheets/d/1SVHgJXqkEfSbF5Hs-CyBvkAZgY_DpOByxbVZk-x5WCo/edit?usp=sharing
Thats not a bad idea, OP you could ask a mod if they could add the link to the first post and then it will always be able to be edited, and others can help too
"I fly because it releases my mind from the tyranny of petty things."
JayHelifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 03:01 PM   #23 (permalink)
Works for me, what do you think to this guys:
https://docs.google.com/spreadsheets...it?usp=sharing
It's accessible to anybody with the link, and editable by anyone. If you think it looks good I'll see about getting the top post edited with the link.
Electronics: Spartan Vortex, MSH Brain, Jeti DS-14
Sims: RealFlight & AccuRC
Other: Team rep for Lynx/Oxy, working on NightWave Systems
Old 09-20-2014, 03:17 PM   #24 (permalink)
Got to be said, the more I look at this the more I wish Lynx would release a version of their LX9001 for the 250. A high voltage servo that's only 5.25g, and the specs look perfect!! I'd love three of those for the cyclic, and a slightly higher geared one for the tail. That'd save me 27g, which is an insane amount of weight to drop.
Same for their ultra lightweight canopies too. They do this one for the mCPX BL at 3.5g!!
Old 09-20-2014, 03:26 PM   #25 (permalink)
Ask them to Sticky it too!
Old 09-20-2014, 07:05 PM   #26 (permalink)
Not a big fan of the skeleton canopy but if they could make one in the 6-8g range, I'm In!
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX.
buzzsaw 46 is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 01:23 PM   #27 (permalink)
OK, this time for sure. I think the spreadsheet is editable by anyone now, so go ahead and add your weights!
I added all the weights too. (Procrastinating doing actual work I need to do...)
Old 09-21-2014, 02:22 PM   #28 (permalink)
Link:
Whoops, didn't you see my link earlier :-)
Any objections if I stick with my layout and bring all your data in?
Old 09-21-2014, 02:36 PM   #29 (permalink)
It's publicly available data now, so do with it what you will!
The idea, of course, is that it's a freely editable spreadsheet that everyone can share and add to....
Old 09-21-2014, 03:19 PM   #30 (permalink)
Thanks Harbourmaster,
I've pulled everything into this spreadsheet, with the components grouped by category:
By default each category is sorted by weight, with the lightest items at the top, but you can re-order or filter the spreadsheet at will by clicking on a column title.
I'm not entirely happy with how to present the data for the skids and the baseplate. Since hobbyking have a one piece item you can't easily compare the others unless you take the combined weight of the skids and the baseplate. Originally I had a combined "skids & baseplate" category, but I think that was too messy, so I've put them under skids and given them a 0g entry under the baseplate category.
Old 09-21-2014, 04:47 PM   #31 (permalink)
Wow, that looks great! In my experience, there is no perfect solution for databases and spreadsheets. There's always at least one weird case that doesn't really fit. But there is a ton of great info there, and it's very easy to do the needed sorting and comparing, so we're looking good!
Old 09-22-2014, 05:24 AM   #32 (permalink)
Oh nice, this is working already :-)
I can see somebody's been busy adding details, we have some tidying up on the descriptions and a whole bunch of batteries have appeared. I think we have a typo though, should this be 750mAh?
Battery 70.76 Turnigy Nano-tech 350 25-40C
Also, for the batteries we need to include the connector type as that can make quite a lot of difference.
Some of the details are eye opening, they make you realise where you need to balance performance and weight. My chinese weights and plastic tail blades are double the weight of the stock align carbon blades. They're letting me save significant weight with the servo so it's well worth it, but I'm already wondering if I could make them work with the carbon blades now :-)
Old 09-22-2014, 07:43 AM   #33 (permalink)
Oh damn, now I need to de-case my Spartan.
Angelos just posted the weight without the case - 5.07g. That's a 5g weight saving!!
http://forum.spartan-rc.com/viewtopi...162&p=692#p692
Old 09-22-2014, 09:36 AM   #34 (permalink)
I fixed the battery entries (JST connectors and 850 mAh).
Nice chart. I wish I had had it *before* I started my diet plan rather than after.
Yeah, stripping off the case does save some weight. I'm still most impressed by how much weight I lost by replacing my 20+ gram canopy!
I went back and changed the link in two of my earlier posts. Myx and Soccerjay, if you could go and edit out the old link in your replies, that might save some confusion...
Old 09-22-2014, 10:09 AM   #35 (permalink)
Lol, me too, thats why i started this. I've learnt so much about dropping weight over the past few months, and keep discovering new bits.
Feel free to add links, they'd probably fit best over the product part codes.
Old 12-01-2014, 03:39 PM   #36 (permalink)
Myx update on the zippy compact 25c's weight in the spreadsheet, all mine weigh between 74.12g and 74.97g
What goes up must come down, preferably controlled,
Trex 250 DFC with Vx1n, Trex 500 DFC with Brain
Emax 250 with CC3d, X4, Dx8 and iCharger 3010b
Slobberdog is offline        Reply With Quote Quick reply to this message
Old 12-02-2014, 01:04 AM   #37 (permalink)
What connector do you have on those? Still JST?
Old 12-02-2014, 02:22 AM   #38 (permalink)
yep still jst
Old 12-02-2014, 02:30 AM   #39 (permalink)
Thanks, I've updated that. Buly the way you should be able to edit the spreadsheet yourself if you have any new weights :-)
Old 12-02-2014, 02:53 AM   #40 (permalink)
I was looking at it on ipad and not got the stuff on there to do it with
