Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 09-26-2014, 09:46 PM   #1 (permalink)
Default Camera not working?
Hi All,
Just got my first Blade. It appears that I have installed/charged the camera the right way. When I turn it on, I use the mode selector on the camera to just either mode. The camera led light is solid blue. However as soon as I pull the trigger on the transmitter, the blue led goes off....and the camera subsequently does not take either a picture or a video.
Any thoughts?
My thinking is that it could be a transmitter problem?
purdue1410 is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 01:35 PM   #2 (permalink)
What kind of microSD card do you have in it? Anything faster than a class 4 might not work well.
Larry N.
120SR, 180QX, Hubsan X4, Proto X, DX6i
lnuss is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 03:23 PM   #3 (permalink)
It's a 8gb micro SDHC Kingston card. Any thoughts?
The same thing happens if I press play (and not pull the trigger); the blue light just turns off. Perhaps it's a camera issue?
Old 09-27-2014, 08:38 PM   #4 (permalink)
its an sd card incompatability issue, you just gotta find one that works, i use Kingston 8 Gb class 4 cards and they seem to work most of the time, every once in a while one will start doing that error again and i switch em around, i got 3 of those cameras that i use for flying..
firepower is offline        Reply With Quote Quick reply to this message
Old 09-28-2014, 04:07 AM   #5 (permalink)
Thumbs down
How can I find ouT the class of what I'd buy? Say, on Amazon...
Old 09-28-2014, 10:05 AM   #6 (permalink)
You can use a 16gb class 4 Sandisk with no problems.
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 09-28-2014, 05:48 PM   #7 (permalink)
Would this work?!?
Old 09-28-2014, 08:55 PM   #8 (permalink)
Originally Posted by purdue1410 View Post
Would this work?!?
That is what I use.
Old 09-28-2014, 11:08 PM   #9 (permalink)
same exact one i bought. worked for about 30 days, but now started shutting off immediately on start. so now i am back to the 2gb that came with the 720 camera.
MB604 is offline        Reply With Quote Quick reply to this message
Old 09-30-2014, 08:36 PM   #10 (permalink)
I took the camera to a local store and they checked it out and called Horizon. Horizon said its defective so they are going to ship me a new one. We shall see!
Old 10-04-2014, 10:37 PM   #11 (permalink)
Yeah...well...unfortunately I am on my second and they both behave the same way. This is a totally flawed product unfortunately.
Old 10-11-2014, 11:26 AM   #12 (permalink)
I abandoned the 721 awhile ago.
I now use the 808,#16 keychain camera with a "D" lens
QX180 at School (1 min 11 sec)
Gearhead5 is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 06:37 PM   #13 (permalink)
Would this work?!?
If it has the HC on it, probably not. Mine does not and works flawlessly!
Old 02-15-2015, 05:35 PM   #14 (permalink)
You have to use a 4 gig card.
I have it working but functions are limited from the dx6i
any suggestions?
B.Nyce is offline        Reply With Quote Quick reply to this message
Old 02-17-2015, 04:20 PM   #15 (permalink)
I've had two of them. The first would record and seemed to be working with a 32GB class 10 card. However, when I hooked it up to the computer to pull the files off it would disconnect mid download. I called and they sent me a replacement. It seemed to record fine Hooked it up to the computer and it literally just connects then disconnects endlessly.At that point I just gave up since the support guy basically said they were junk on the phone.
Krinaman is offline        Reply With Quote Quick reply to this message
Old 02-18-2015, 08:05 AM   #16 (permalink)
Default Battery
Please try charging the camera battery first... It has its own lipo.
Then make sure the SD is fully seated in its slot.
ppccmd is offline        Reply With Quote Quick reply to this message
Old 05-23-2015, 10:01 AM   #17 (permalink)
Question JJRC H8C
hi i too am having the same issue except i have a JJRC H8C drone and the camera picks up sound but no video any suggestions?
mexicano14 is offline        Reply With Quote Quick reply to this message
Old 06-05-2015, 12:52 PM   #18 (permalink)
Good fix for camera is, take a hammer and proceed to hit it until its smashed to bits, or just sell it like I did mine and get an 808 keychain cam, much better quality and no sd card problems.
Crazy Canadian is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 07:22 AM   #19 (permalink)
I had the same problem. Out of three different SD cards, I had one that would take video sometimes . That hammer fix is looking mighty tempting
Nano cps,MCPXv2,130X(x3), 180 CFX, HK 250 DFC Hybrid, 450 SE, DX6i
Pilotrob is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 05:13 PM   #20 (permalink)
Just use a good brand card, Class 4. I use a 16gb, class 4 sanddisk card. No problems!
