Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 09-29-2014, 01:22 PM   #1 (permalink)
Default KDE 700XF-535-G3
Just changed out my Goblin 700 Comp, Scorpion 4525-520LE for the KDE 700XF-535-G3.
Wow,
Nough said.
Scotty
Goblin 700 KDE700XF-535, Vbar NEO 6.1, BL9180 9188, Kosmik Cool 160 Goblin 630 HK 4525-520, Vbar NEO 6.1, BL9180 9188, Jive Pro 120 Goblin 380 Xnova 3215-930, Vbar NEO 6.1, DS-3001HV, DS5005HV, Koby 90
Scottyb410 is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 01:12 AM   #2 (permalink)
Love KDE motors!!!
Bubba
Goblin 700
Jeti DS-16
Bubbasanjohn is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 01:12 PM   #3 (permalink)
absolutely! i have one of these, and one of the 505KV motors in my Synergy E7s. they are truly amazing motors!
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 10-02-2014, 06:33 AM   #4 (permalink)
I have a KDE 700XF-495 v1 motor on my Whiplash and a KDE 700XF-495 v2 motor on my Synergy E7SE. They both work excellently. I have a spare v2 700XF-495 motor I was going to swap and install on the Whiplash, but the v1 version works so well, I have not bothered to swap it out. It's hard to believe that these newer G3 versions are even better than the previous generations. Good job Patrick
Protos 770 Evoluzione Leggero, Synergy E5, Logo 700/550SX V2, SAB Comet/700 KSE/380 KSE/miniComet; Spirit Pro/Brain2 BT;Jeti DS-24/DX8 Gen 2
Mac sims: neXt, Heli-X, AccuRC, RF8, Phoenix, AeroFly RC7 Ultimate
Citizen 259
curmudgeon is offline        Reply With Quote Quick reply to this message
Old 07-20-2015, 10:54 AM   #5 (permalink)
I flew my new Forza 700 with 700fx 535 g3 on Saturday. The power is amazing. Had to take it easy though. I had to break in my new 5000 stick pack.
I got about 4.5 minutes flying them down to 45% or so.
Running 2100 for about 2 minutes then 1900 for the remainder of the flight.
Its geared for 2200. I want a few cycles on the packs before I put a beating on them.
Team JR Americas
Synergy Helicopters
Rail Blades
Scorpion Motors
justinspicer is offline        Reply With Quote Quick reply to this message
Old 08-22-2015, 12:13 AM   #6 (permalink)
I just ordered one for my new Protos Max 700 V2. I think this will be a awesome motor. I am going to use a Kontronik Heli Jive 120 HV with heat sink. I use this ESC on my other 700s. I think it should work well with this motor ?
Looks like the Kontronik Heli Jive should be fine if it is running version 11 and higher in KSA mode.
Mine has version 13 firmware.
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is online now        Reply With Quote Quick reply to this message
Old 08-23-2015, 08:58 AM   #7 (permalink)
Yes you will be fine with the helijive
Team Jr Americas
LaDon is offline        Reply With Quote Quick reply to this message
Old 09-16-2015, 09:57 AM   #8 (permalink)
Hi, don't mean to steal your thread but I am using this same motor 700XF 535KV with a Kosmik 160 on a new Kyle Stacy Goblin. I had never done a build thread so I posted some pictures and I get a few guys saying that's a bad setup on a 3 bladed heli. The Kosmik will shut down from overpower on the motor.
Can I get some replies on this, I try not to listen to negative posts but they always leave that doubt in your head.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Reply With Quote Quick reply to this message
Old 09-16-2015, 11:18 PM   #9 (permalink)
You should be fine with G3 motor. I read the thread on the Goblin forum but didn't reply. Back in the original and G2 with 8 poles, there were few shut down with the Kontronik ESC in auto timing mode. One have to run in KSA mode to reduce the chance of shut down. The main reason: the ESC was optimized for higher pole counts. Starting from G3 with 10 poles design, KDE motor can run with all the major ESC brands without any issue. I have been running mine in auto timing since G3 without any issue. There are few KDE team pilots run G3 with Kosmik without any issue also.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2, KDE motors on all helis
taoY is offline        Reply With Quote Quick reply to this message
Old 09-17-2015, 07:11 AM   #10 (permalink)
We run ours on a castle 160hv. It works fine on it and we did run one on a kosmic I for some speed runs. We ran it a 100% output with no problems. It didn't shut down. A lot of it has to do with collective management. On Ryan's forza he runs a castle 120 hv on the two blade and he only pulls around 5800 watts and 130 amps and he is flying it hard. If I can get a break on the weather here I will get a video of a flight and will get some numbers. Maybe that will help. I do have a friend that has the same setup and he is pulling 10500 to 11000 watts on his and don't do near the stuff and isn't near as quick. He don't have good collective management
Team Jr Americas
Old 09-17-2015, 10:02 AM   #11 (permalink)
I wasn't going to change the setup. I'm sure I will be fine. I don't do smack 3d or speed. So I will check some logs after flying but I didn't think it was a bad setup. I hate having a doubt put into my head.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-16-2016, 10:36 PM   #12 (permalink)
I plan on running a Hobbywing 160A platinum ESC with this motor in my 700C..will the ESC handle the AMP draw from this motor..
Synergy 766 12s/ 766 14s / Synergy N7 / Align 700X/700XN
Black Thunder 700T / Black Nitro 700x2 / 2x Fireball Comp
SAB Mini Comets/Synergy 516x2 /SAB 500 Sport /GUAI X7FZ.
Vcontrol/Neo
Locktite is offline        Reply With Quote Quick reply to this message
Old 03-17-2016, 02:34 PM   #13 (permalink)
My Castle 160 handles it perfectly fine with plenty of room to spare. Amp draw is determined by using a proper setup and gearing for the RPM you are using and the way you fly, not the brand ESC you choose.
There is no such thing as a blanket statement that "X motor draws too many amps for X ESC"
The exact same ESC motor combo can draw much higher amps in the hands of a pilot that doesn't understand proper setup vs the same combo used by one that does.
There are many variables that determine what size ESC will work for you.
Tony
Synergy 516, Gaui R-5 Speed, Spirit FBL, Hobbywing and Scorpion Tribunus ESC
Xrayted is offline        Reply With Quote Quick reply to this message
Old 03-18-2016, 07:10 AM   #14 (permalink)
Xrated is exactly right. I have seen ppl do average 3D moves and pull peaks of 230amps or more. Then there are ppl that do hard eye popping 3D and don't pull more than 160 amps. When we started in this Ryan and I couldn't figure out how we could have the same parts as say a Nick Maxwell type of pilot but the Heli seemed to not have the power and snap his did. I have seen Ryan in the beginning years pull over 300 amps and 12000 watts on the logs. Now that he has gotton better his amp draw on a flight is down to around a max of 160 and watts of 6000 max and his flying is way better. A 160 will work well. We are flying ours on castle 120s but your setup better be right and your collective management better be spot on
Team Jr Americas
Old 03-19-2016, 03:14 PM   #15 (permalink)
Your 160a esc should be just fine. I run KDE gen 3 motors on all my 7 and 800 two blade head setups with YGE 160s without any problems. Xrayted post is right on.
I did do a 14s changeover on all mine, and immediately saw close to 20% lower amp draws and much cooler electronics. Picked up more power also. So if you can?
The only issue I have had with the gen 3 in my Triabolo 800, was it actually had too much power, and was torturing my gears. So I stepped it down with the big 800 koz, which contrary to their claims. Doesn't have as much power as the KDE Gen 3s, so it is living with it.
Old 03-22-2016, 08:00 PM   #16 (permalink)
After getting comfortable with the heli I get around 3:40 at 2150 with the 535 G3. Its a beast.
Team JR Americas
Synergy Helicopters
Rail Blades
Scorpion Motors
Human Verification
