DX7 flight mode switch - HeliFreak
Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 200QX
200QX Blade 200QX Helicopters Information and Help
Old 12-06-2014, 08:00 AM   #1 (permalink)
Default DX7 flight mode switch
Can anyone out there tell me how to assign the 200qx flight modes to the three position flight mode switch on my Dx7.I have only flown helis and cannot figure out how to do it on an acro setting.Following the manual I have two modes on the gear switch and one on the rudder dual rate and would like them on the flight mode switch where they belong. Also is there any way I could use heli settings on my radio to fly quads instead of the acro setting as this would suit me better.I would appreciate your help with this.Thanks
jack be nimble jack be quick
aysbirg is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 08:15 AM   #2 (permalink)
I fly my 200 in heli mode on my dx6i. Straight foward ...think of the 200 like setting up a fp heli, Set up as follows, for the dx6i its all defaults, 90 swash, no mix, no chanel reverse. Set throttle sub trim to 10-15 clicks.
You can set up a different throttle curve on the 1up switch, and as a fixed pitch craft it ignores the pitch curve, so no need to adjudt that. The qyro switch sets the flight modes. Dx6i has only a 2 pos switch so mine is set for 25 agility and 50 for stability, and safe/green mode kicks in at arounfd 75. You also get throttle hold
Hope that helps!
Current line up:200QX/Gemfan 5030 full FPV gear, 200qx LOS, Vortex 250 Pro, Chroma
flyingdrummer is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 12:59 PM   #3 (permalink)
Thanks for that flyingdrummer but I am sorry to say but it does not work on my Dx7.Cheers.
Old 12-06-2014, 03:23 PM   #4 (permalink)
If it helps, I didnt modify an existing slot on the tx, i created a fresh model and re bound the 200 to the new heli model
Old 12-06-2014, 07:30 PM   #5 (permalink)
EDIT: Sorry but I thought you were asking about general setup. Don't know how to assign the modes to the proper switch but would like to know as well.
visayan is offline        Reply With Quote Quick reply to this message
Old 12-07-2014, 05:44 AM   #6 (permalink)
Give this a try. So far it is working for my 200QX. I have an old DX7.
The switches are much like a CP heli. Flight modes switch works fine with Normal, Idle 1 and Idle 2 corresponding to the three Quad Flight modes.
You even get a TC, no more fiddling with the trim to get the motors to stop.
You also get Auto DR/Expo.
https://www.helifreak.com/showthread.php?t=582674
The above program has 25% and 20% throttle in modes 1 and 2 at low stick, I changed them both to 0 to be symmetric in inverted flight.
Good luck, and happy flying.
The Cactus - Just pick up the sticks, and FLY!
Blade (mCX, CX2, mSR, mCP X, mCPX BL; 180 CFX, 400) * T-Rex (450SE2, 600E)
Blade (Nano QX, 200 QX) * DX7 * Phoenix v5.5k
Helis and MRs wrecked while-U-wait since 2008-05-27
Creaky Cactus is offline        Reply With Quote Quick reply to this message
Old 12-08-2014, 04:21 AM   #7 (permalink)
Thanks for that creaky cactus just what I was looking for. Cheers.
Old 01-09-2017, 05:20 PM   #8 (permalink)
hey creaky cactus, the link you give sends me to the 300 qx heli mode setup? can I use the same programming for the 200 qx? and tell me about it!, having a TX with a three position flight mode switch and not being able to use it , and you mentioned you got throttle cut too which is icing on the cake! if you can respond to me i would appreciate it ! I've had the thing for 5 days now and haven't been able to get it airborne
jfera22 is offline        Reply With Quote Quick reply to this message
Human Verification
