View Poll Results: Should you ground the frame?
Yes, its worth it to avoid glitches 38 33.04%
No, too much chance of shorting something out 39 33.91%
Not sure 38 33.04%
Voters: 115. You may not vote on this poll
Old 03-25-2008, 12:42 PM   #1 (permalink)
Default Negative to the frame
It has been pointed out that if you run the battery black wire (the ESC negative input) to the frame (or the motor mount) thereby making the whole frame negative, that if you ever shorted anything to the frame it would be bad.
Do you think think this is important enough of a drawback to not do it?
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 04:11 PM   #2 (permalink)
Team Taco VP
After all the testing and seeing things myself. I do not believe you need to ground the neg side of the battery to the frame. I don;t believe the ESC noise was causing the DX RX shut downs. It is static causing that. However if your gyro is not liking your specific setup (like my Solid-G) because your specific setup's BEC is generating too much noise then YES ground it. Or if you don;t like that, then get a separate BEC.
Thus I voted NO for this poll.
Bob
Old 03-25-2008, 05:49 PM   #3 (permalink)
If you use a seperate bec , do you change the esc or can you use the standard esc with a seperate bec??
Glenn
noste500 is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 05:51 PM   #4 (permalink)
Team Taco VP
Use ths standard ESC but pull out the RED wire from the cable that goes from the ESC to the RX.
Bob
Old 03-25-2008, 06:04 PM   #5 (permalink)
I initially had some tail kicks and moved the gyro and changed the tape which seemed to have eliminated the problem, but i also grounded the esc to the frame (for peace of mind), im now having second thoughts about the grounding due to the possibility of a short ! so i voted not sure
RADTECH is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 06:17 PM   #6 (permalink)
I grounded mine to the neg. ESC. And i have a bare aluminum frame! I dont worry about it.
dieselracer is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 06:30 PM   #7 (permalink)
ChasHeliCop says using my gyro mount stopped his tail kick. I'll wait and see whether I have a kick before grounding the frame to the negative.
Rick
Old 03-25-2008, 06:35 PM   #8 (permalink)
I have NOT grounded my frame to the neg. on the ESC / Battery. I never agreed with it from the beginning. As Bob stated, I don't think that was the original issue either, and I don't believe it's necessary. Fry your ESC or Lipo from a short, and the cost goes up from there. I have seen post of the damage and the potential. I also voted NO on this poll. Especially since I installed that nice gyro / Rx tray some dude on here was making.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep
Donut Connoisseur
HELI-FREAK, You couldn't have picked a better place to land !
ChasHeliCop is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 09:03 PM   #9 (permalink)
Rick
Are you saying; anything that gets shorted to a UNGROUNDED Carbon Frame is OK?
chichiuno is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 09:14 PM   #10 (permalink)
Unbelievable, simply unbelievable
Tailrotor Joe is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 09:35 PM   #11 (permalink)
No, but the result would typically not be as catastrophic. Why take this risk when the other mods fix the problem for most people?
Rick
Old 03-25-2008, 09:48 PM   #12 (permalink)
epl
Team Taco Member
If the people building the heli paid more attention when setting up the wiring then a grounded frame would not be a issue.IMO!
Logo 500SE Vbar, Jive100LV, BLS451, BLS251, Edge 553
Logo 600SE Vbar,Jive 120, BLS451s, 9254, 5020-450 10S
T 700 Vbar , YS91SR , Hatori SB19 , DS8717 , AR7100R , Radix 710
epl is offline        Reply With Quote Quick reply to this message
Old 03-25-2008, 09:52 PM   #13 (permalink)
Well, personally I think most people would say I'm pretty careful about my wiring.
I'm more thinking about wires getting pulled hard during a crash and rubbing against a sharp edge. Next thing you know the LIPO and/or ESC catches on fire and a minor cost crash becomes a major cost crash.
If this was the only way to make my heli dependable, I would take the risk. As it stands, I don't see it as mandatory.
Rick
Old 03-25-2008, 09:54 PM   #14 (permalink)
AMEN.
Old 03-25-2008, 09:58 PM   #15 (permalink)
Rick
So what is the reasoning to SHORT the boom/bearings to the UNGROUNDED CF Frame? Is this to TRANSFER all the EMI/RFI to the boom/bearings radiating from the CF frames via the AC motor?
Old 03-25-2008, 10:05 PM   #16 (permalink)
Actually the effect of grounding the bearings is to neutralize the Van de Graaf effect and the production of static from the belt. The overall effect is not grounding the bearings to the frame, but connecting the front and rear gears.
But let's not make this another argument thread, people have their personal opinions on the matter and peoples opinions will always differ.
Donut Connoisseur
Old 03-25-2008, 10:09 PM   #17 (permalink)
Actually I would like to explore this a little without arguing. Making sure the pulleys and boom are at the same potential avoids the Van de Graaf affect.
Taking all that and grounding it to the frame keeps most of the heli at the same potential to avoid a spark between heli parts. I would agree that the heli now is floating with respect to the electronics so a spark could jump to the electronics. You have now hit the basis for why I made this poll.
Hopefully, and empirical evidence supports this so far, when the Van de Graaf affect is removed, not that much voltage is generated so there is not enough difference in potential to cause a spark.
I've never had to ground my frames to the negative on my other helis.
Rick
Old 03-25-2008, 10:16 PM   #18 (permalink)
Why do you think the EMI/RFI from the motor would be conducted in this way. Any EMI experts care to comment on that one?
Rick
Old 03-25-2008, 10:29 PM   #19 (permalink)
Rick
I see your point.
It has been proven even with all these mods done, still a static field is still present.
btw: I NEVER had to do any Boom/bearing grounding to ANY of my helis to date.
Old 03-25-2008, 10:33 PM   #20 (permalink)
I see your point.
Yep. Neither have I. I'm assuming its the combination of the plastic boom and tail blocks, and the belt hitting the boom block that all add up to trouble on this heli.
It seems when the Van de Graaf is defeated, the rest of the static is tolerable by the electronics.
Rick
