Old 12-24-2014, 02:44 AM   #1 (permalink)
Thumbs down DX6i back from warranty service... wiped out
Well, the subject says it all. Seven different models.
If you're counting time you're spending in terms of dollars earned, buying a more expensive transmitter that allows you to export and import its configuration just might pay back plenty.
I wish I knew. And still don't see a reason for them to do that, it was a mechanical failure (bad pot).
DX6i, Jeti DS-16
MCPX BL, Mini Protos 6S, Stingray 500, SG704 post-maiden tuneup, SG381 in the making
Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik
Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition
madeye is offline        Reply With Quote Quick reply to this message
Old 12-24-2014, 05:45 AM   #2 (permalink)
In order to speed turn around, Spektrum may have just replaced with a new TX on receipt of the old one. (Is the returned TX your original with a new pot or a completely new one?)
When installing new pot's the TX must also be calibrated (so CPU aligns with mechanical pot resistances at centre stick). The calibration process does not remove models from memory, so if your original one, someone has deliberately removed the models.
If sending a TX in for work, usually it is good idea to save (or in the case of DX6i write down) the model settings. But in your case this is probably a horse, barn door, bolt scenario.
You have my sympathies. Hopefully you can reprogram them quickly and get back in the air soon.
Old 12-24-2014, 01:30 PM   #3 (permalink)
AFAIK in addition to any hardware work they also do a complete software/memory check and possibly even reflash the Airware. It may require resetting everything back to factory defaults.Its probably just as likely they replaced the entire Tx.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 12-26-2014, 12:58 AM   #4 (permalink)
The case is definitely mine, but the guts (at least gimbals) don't seem to be - I doubt anyone would be resetting the stick length and tension, I've had them long and stiff.
Another thing that surprised me was that the Tx came back with batteries (I removed mine before shipping) ... one NiMH and three alkaline
Yep.
I'm not that upset, I've moved everything except Spektrum-only mCPX BL to Jeti already anyway. Just wanted to raise awareness, lest fellow pilots fall into this trap.
DX6i, Jeti DS-16
Old 12-26-2014, 01:17 AM   #5 (permalink)
Default Duh...
Just found the invoice (been hiding in packaging materials before), says this:
"Replaced both gimbals in DX6i and update firmware to current production version."
Now's the juicy part:
SPMR75120 Gimbal T/R DX6i Rev. 4
SPMR75121 Gimbal A/E DX6i Rev. 4
Lo and behold, part numbers google up, turns out you can buy them separately. I'd rather do that than send the whole Tx for service. Hope this helps someone
DX6i, Jeti DS-16
Old 12-26-2014, 11:32 AM   #6 (permalink)
What did they charge you for the repair?
HELIFREAK !!!
Old 12-26-2014, 11:33 AM   #7 (permalink)
Nothing, it was still under warranty.
DX6i, Jeti DS-16
Old 12-29-2014, 01:24 AM   #8 (permalink)
HH warn you about this in their T&C's when you send a tx back for any kind of repair, so when you send a tx back for repair you automatically accept the T&C's.
Nigel.
A few little tiddlers ..SR, 300X, TRex 500E Pro with DFC, Trex 700DFC..... and quite a few Planks and Tanks !
nbells is offline        Reply With Quote Quick reply to this message
Old 04-13-2015, 04:03 PM   #9 (permalink)
Could have been much worse...
You could have had a greater memory model like the Dx7 or Dx8 and had 2-3 times as many models wiped...
It's a common scenario when the firmware is upgraded under warranty
nCPX(2)*mCPX(30)*HCP100S*130X(4)*130X-L(6)*180CFX(7)*300X/CFX(4)
330X*450X(7)*470L*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
JonJet is online now        Reply With Quote Quick reply to this message
Old 04-13-2015, 04:30 PM   #10 (permalink)
It shouldn't be if you use the SD card to back your models up regularly... (on the models that have that feature anyway). This is an excellent way to save yourself a lot of headache, but you have to do it before an issue arises.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote Quick reply to this message
Old 04-13-2015, 04:35 PM   #11 (permalink)
The DX6i has no SD card
Old 04-13-2015, 04:36 PM   #12 (permalink)
What I do with my Jeti configuration is keep it source controlled with Git, on my file server. That way, not only I have the backup, but the whole change history with detailed comments. The fact that the configuration is plain text JSON makes it easier to trace, I only wish they formatted it for human consumption instead of being the "compact" form.
DX6i, Jeti DS-16
Old 04-13-2015, 04:47 PM   #13 (permalink)
Which is exactly why I said on models that have that feature - in reference to your comment on the 8 specifically - I'm aware the 6i was the radio the OP had at the time and it doesn't have a card.
Old 05-06-2015, 09:55 AM   #14 (permalink)
He quoted a post that contained the DX8, which does have an SD card slot.
jadewarrior is offline        Reply With Quote Quick reply to this message
Tags
fail
Human Verification
