350QX~TX Setups & Files Here. - Page 3 - HeliFreak
Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 01-20-2015, 06:47 AM   #41 (permalink)
Originally Posted by jdr00ejr View Post
So I'm using this setup except I don't ever use agility so I made FM2 run as stability with Stagility mixes turned on. Now I have safe, stability, stagility on that switch. However, I can't get into compass calibration. Is it my extra mixes? How do I cwlibrate the compass?
Of course, the instructions say that you need to flip the flight mode switch 4 times. But you need to think about what the quad expects to see happen when you do that. With the transmitter set up per the book, flipping the flight mode switch all the way from position 0 to position 2 will make it see a change from +100% to -100%. Flipping it back makes it change from -100% to 100%. So that's really what's going on - you're flipping back and forth from +100%, -100%, +100%, -100% and so on.
By changing the flight mode switch to put a different mode on position 2, that switch no longer moves through that entire range of values as expected.
If you think about it, rather than simply saying "flip the flight mode switch back and forth four times", what it's really saying is "toggle back and forth between Smart Mode and RTH four times," because that's what happens with the standard transmitter setup.
So that's what you need to do - use your switch setup to flip from Smart > RTH > Smart > RTH > Smart > RTH > Smart > RTH > Smart. That should get you into compass calibration.
I'm not sure how picky the QX3 would be about Smart Mode in particular. Stability and Agility Modes are above +100%, so it's possible that flipping from Stability > RTH > Stability > RTH and so on could also work. RTH is the only mode near -100%, so that has to be one of the two modes you flip through.
flightengr is online now        Reply With Quote Quick reply to this message
Old 01-20-2015, 09:35 AM   #42 (permalink)
Default JR9303 TX
Is there any files or settings available for the JR9303 TX that anybody knows of?
byrogil is offline        Reply With Quote Quick reply to this message
Old 01-20-2015, 07:22 PM   #43 (permalink)
I figured out I had to flip the gear switch the other way then toggle the flap switch. All better.
Joshua ~Proverbs 3:5-6
DX6i, DX5e, NQX, NCPX, Armattan V-Tail 355, Hubsan Qaud, ProtoX, Many Planes
jdr00ejr is offline        Reply With Quote Quick reply to this message
Old 01-31-2015, 10:15 AM   #44 (permalink)
Default Thanks flightengr
Thanks flightengr for the DX9 file. works great!!!!!!!!!
sal42na is offline        Reply With Quote Quick reply to this message
Old 01-31-2015, 12:12 PM   #45 (permalink)
Yes, I have a setup on my DSX9 which should be fine for yours if your on v2, the setup is on another post so will need to do a search for it.
Ill put a link here once ive found it.
DX18, Phoenix Sims, Blade Nano, mCP X, 130x, 180cfx.
Trex 250dfc Gpro, Mini Titan 325se 3G.
Trex 450v2pro Gpro, Trex 500EFL Gpro.
Trex 600Ndfc Gpro, Trex 600E Pro Gpro.
tourerjim is offline        Reply With Quote Quick reply to this message
Old 02-19-2015, 09:43 AM   #46 (permalink)
Default Question
Originally Posted by flightengr View Post
I finally got a setup working for the 350 QX3 and a DX8 that gives you all of the flight modes. However, due to some limitations in the DX8, I had to change the primary flight mode switch from F Mode to Flap. So the flight modes work as follows:
Flap Switch position 0, F Mode Switch position 0 = Smart Mode
Flap Switch position 1, F Mode Switch any position = AP Mode
Flap Switch position 2, F Mode Switch any position = Return to Home
Flap Switch position 0, F Mode Switch position 1 = Stability Mode
Flap Switch position 0, F Mode Switch position 2= Agility Mode
Similar to my other posts, the Stagility Mix is on the Mix switch and should only be used in Stability Mode.
I added low rates to this one on the AIL D/R Switch, position 1.
EDIT: Frostman83 discovered that if you use a value of +110% for Stability Mode instead of +125% (yes, that works!) then the Stagility Mix is a little less sensitive. That's set in Mix 1 - change 25% to 10%.
NOTE: Click on the SPM file link below to get your browser to download it. You can't right-click the mouse and "Save Target As..." because the forum will give you a PHP file if you do that!
Does the instructions or SPM file include Frostman83's discovery?
cMc214 is offline        Reply With Quote Quick reply to this message
Old 02-19-2015, 10:17 AM   #47 (permalink)
They do not. The instructions and the SPM file are both using 125% for Stability Mode. That's set in Mix 1. You can change it to 110% instead.
Old 02-19-2015, 12:51 PM   #48 (permalink)
Awesome and thank you for all the work you put into providing this information
Old 02-28-2015, 06:46 PM   #49 (permalink)
What is a SPM File?
When I download it.....Adobe file will not do nothing.....how do you make the SPM file work and how do you get it in your tx. or just do it by hand?
Roddie is offline        Reply With Quote Quick reply to this message
Old 03-01-2015, 02:16 AM   #50 (permalink)
Originally Posted by Roddie View Post
What is a SPM File?
Down load the file to My Documents then drag the spm file to your tx memory card, place card in tx the switch on tx, once tx has finished remove card & delete file.
Old 03-01-2015, 12:16 PM   #51 (permalink)
Thanks much for the info
Old 03-01-2015, 12:32 PM   #52 (permalink)
When I click download and save to my documents when I go to open to my documents its changes to PHP file....do you just drag that file to your card and install it in your dx9?
Old 03-01-2015, 12:35 PM   #53 (permalink)
If you're getting a PHP file instead of the SPM file, that's the forum messing with your Web browser. You can probably rename the file so that it has an SPM extension on it. An SPM file is a text file (containing XML), so you should be able to open it and see something like this at the top:
<Spektrum>
Generator="DX9"
VCode=" 1.05"
Originator=""
and so on...
Old 03-01-2015, 12:46 PM   #54 (permalink)
That don't work either....always says php file....I can't change it for some reason. I have puter with 8.1. I can install by hand I guess.....just thought I try the fast way.....lol
Old 03-02-2015, 06:20 AM   #55 (permalink)
Default Update for QX3 and DX6
The forum won't let me edit post #28 any more.
After some testing by edmontonhouse, it has been determined that the settings for Aux1 (throttle controls throttle vs. throttle controls gimbal) that are suggested by Blade just don't make sense with the DX6.
Firmware version 3 works a lot better on a DX6 if you leave the travel alone on Aux1 (use the default +100/-100) travel range) and reverse Aux1. That will make it behave like the RTF transmitter.
Old 03-02-2015, 07:16 AM   #56 (permalink)
If you feel it is necessary, contact a Moderator...ask about creating a total new post and have the Mod edit post 28 to delete all its contents and provide a link to your new post...(or simply have them edit post 28 for you)
If you also link back to post 29, the thread can be followed in order
nCPX(2)*mCPX(30)*HCP100S*130X(4)*130X-L(6)*180CFX(10)*270CFX*300X/CFX(4)
330X*450X(6)*470L*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 03-03-2015, 09:44 AM   #57 (permalink)
Default spm
Tested the long awaited SPM v3 file, see #1 for setup and #27 for expo.
In Channel Config use spare aux channels for Gimbal setup.
hi guys
so is the the definitive v3 qx3 file now?
i have one which gives me 5 modes and tilt on r knob but no stagility does this spm have the stagility now?
thanks in advance
dave
davebelton is offline        Reply With Quote Quick reply to this message
Old 03-04-2015, 07:59 AM   #58 (permalink)
There really is no "definitive" SPM file. Everyone will tweak the settings a little differently for personal preferences. There are a multiple choices for the QX3 in this thread for the DX8 and for the Gen 2 DX6/7/9/10/18 transmitters, and the posts explain the settings available in the SPM files.
Old 03-19-2015, 10:25 PM   #59 (permalink)
On this setting which switch do you use to make it go into compass mode?
Old 03-19-2015, 10:26 PM   #60 (permalink)
Sorry....which switch do you use to get into compass?
Human Verification
