Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Old 01-10-2015, 08:12 AM   #1 (permalink)
Question Trouble fitting canopy on G570
My stock G570 canopy does not sit well on one side. I'm using the SAB quick release mounts.
On the left side, it's all good. The quick release button "clicks" into place nicely, and the trailing edge of the canopy follows the boom contours on that side.
On the right, I have to use quite a bit of force to pull the canopy back in order for the mount to engage. All that pressure causes the right rear edge of the canopy to adopt a weird angle - it sits too low on the boom. Even worse, the right-side quick release doesn't "click" solidly, and I'm worried that it might pop off in flight.
This is even without batteries or a tray. The wiring is reasonably neat, and I don't believe the canopy is rubbing on anything it shouldn't.
Is this a common thing? I would prefer to avoid elongating the mount holes.
Thanks in advance for any tips.
H2SO4 is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 08:26 AM   #2 (permalink)
It only takes a slight misalignment in the holes to make the canopy difficult to install. Conversely, it only takes a small amount of opening up (not elongating) the holes with a small round file to make it much easier to install... Bert actually talks about it in one of the videos.
The canopy on my 630C didn't fit well at all initially, but I spent a little time and opened the holes up a *small* amount, and it fits fine. I've also seen guys trim the front bottom edge of the canopy or make the notch bigger in cf skids, too.
Spend the time getting it right now... You don't want it to come off in flight
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 09:03 AM   #3 (permalink)
I had issues with my canopies from Fusuno. I took off a bit of material at the front edge that allowed the canopy to slide on and off more easily.
NX4|Tri-Chronos|Chronos|7NT|Specter700
*AccuRC Substance Guru*
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 11:28 AM   #4 (permalink)
My best guess without looking at photos is that your motor wires are probably not flat against the side frame or other wires are pushing on the canopy from the inside. One remedy is to open the holes a little on the canopy. I prefer to take a little off the canopy under the chin where it meets the front of the heli/landing gear strut. The latter method has worked well on every goblin I have owned, or any other heli for that matter.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Tags
570, canopy, fit, goblin, mount
