Go Back   HeliFreak > Multi Rotor Support > NextD - Stingray 500
NextD - Stingray 500 CJY Stingray 500 Quad Discussions
Old 01-17-2015, 04:59 PM   #1 (permalink)
Unhappy Stingray 500 TG problem
Hello.
I open a new thread because I have a problem with my stingray.
I have test my stingray with 2 succesfully flight and at the third flight I have had a problem at the take off:
I have the TG multi flashing S and 3 and 4 led.
Hers is a vidéo of the proble :
" frameborder="0" allowfullscreen>
I have find other people have the same problem :
I have try to contact the Tech support but I haven't any answer.
Any one knows how to solve it?
Thanks a lot.
bets regards.
Fifou
fifou313 is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 08:11 PM   #2 (permalink)
Default tricky
Interesting doesn't seem to be much around on what the codes actually mean
Normally for me it would be something bent, or something set up wrong, which becomes obvious.
There is a phone number on the website, could try that.
Hopefully someone knows what the error codes means.
I assume you have tried more than once and it is not an initialisation problem.
Not so helpful
M
Trex Sport 450, Atom 500 (stubby), 6HV,Stingray, Wainman Rabbits smoke & boss, Leaf field charge station
Mostly is offline        Reply With Quote Quick reply to this message
Old 01-18-2015, 07:39 AM   #3 (permalink)
it is just the initialization reconnect and allow to initialize.
m
Old 01-18-2015, 10:26 AM   #4 (permalink)
Thanks for your reply but there is a good initialisation but when I try to take off the orror appear.
There is a probleme somewhere but I don't know where.....
Regards.
Old 01-18-2015, 10:37 AM   #5 (permalink)
Maybe you are spooling up too quick.
I think it is getting upset because it sees a wobble on take off too sooner than it would like.
If I get a wobble on spool up it does the same thing.
I don't think there is anything fundamentally wrong.
M
Old 01-18-2015, 10:39 AM   #6 (permalink)
Maybe.. But I can take off just before the error.
at the beginnig of my third fly I have broke my landing gear.
So maybe nothing wrong but I can broke the stingray...
Old 01-18-2015, 01:30 PM   #7 (permalink)
Hi
When I spool up if the heli tilts it does what you see.
To avoid this I spool up gently.
It may also require the a delay before take off
The TG/TG gyros appear to be getting upset for some reason
PS Where did you buy your stingray
M
Old 01-18-2015, 02:02 PM   #8 (permalink)
I have buy it in France.
If someone has other idea...
Regards.
Old 01-18-2015, 02:47 PM   #9 (permalink)
Fifou, I reached out to Cutris and waiting for a response to your issue.
Team Only Fine Helis
Rave ENV Nitro, Protos 380 Evoluzione, Protos Max v2, VBar Control
https://www.onlyfinehelis.com/
mystar60 is offline        Reply With Quote Quick reply to this message
Old 01-18-2015, 06:46 PM   #10 (permalink)
You have to hold the Stingray at idle for about 5 seconds before spooling the rest of the way up. The TG Multi does some diagnostics in that 5 seconds.
HeliFreak Support
Graupner MZ-32
Old 01-18-2015, 07:30 PM   #11 (permalink)
It does not appear that your Stingray goes into the "Idle" rpm which happens when you switch off throttle hold. Once you reach "Idle" rpm, then slowly advance the throttle until you liftoff.
The Multi G checks the gyros at a certain throttle position and if it sees bad data it will not allow the Stingray to take off (to prevent a crash).
If you are spooling up without going into the "Idle" rpm first, you may be moving through the "Idle" rpm too fast and you may get gyro errors.
Taping or banging on the Multi G just upsets the gyros and the Multi G will not allow further throttling up.
If you do not have the "idle" rpm set, then just slowly spool up and you can still get in the air. Once you've lifted off you'll be just fine....
Sky Dancer is offline        Reply With Quote Quick reply to this message
Old 01-20-2015, 12:07 AM   #12 (permalink)
What you guys are saying is finally sinking in. I had a similar issue with mine this weekend after configuring it for the set rpm governor. Basically like you described it disables the pitch channel and won't let me take off. Once, it let me get about a foot off the ground and then came back down. Fortunately I remembered what you'd said before Alan and figured it must be that, so I didn't worry about it too much. No damage luckily (I have some tougher modified landing gear), so I set it aside for the weekend and flew other things, but I'm going to go back through it this week and reconfigure it like I had it before where it was working with the "governor high" mode in the Castle ESC and similar settings from the manual.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 01-20-2015, 09:39 AM   #13 (permalink)
hello Guys.
Thanks a lot for your help.
I have discuss with Brian from CYE. After analysis he thinks that I'm not wainting 5 second on idle throttle before and put the TG multi in failsafe mode.
So I will try to fly nect week end to see if all is ok.
Once again thanks a lot guys for your help. I will keep you informed about any news.
Bets regards.
