Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Old 02-06-2015, 02:57 PM   #201 (permalink)
I'm been using ikon gov with castle edge 120 for about a year (about 300 flights). Never had a "hot start". Don't use dead zone as my ikon throttle min is calibrated at arming and not way below it. I looked at the mtr posted, and I certainly see nothing wrong with it, but don't understand why the throttle min has been taking below arming point and then dead zone added. I use the KISS principle. I've been using 4.19 on castle. Just updated to 4.22, hopefully my troubles aren't about to begin ;-)
Field rep for Discover Card and team Visa.
MSH Brain super fan and crash test dummy.
kthane is offline        Reply With Quote Quick reply to this message
Old 02-07-2015, 09:28 AM   #202 (permalink)
I'm using plane fast mode, I never got the "secret" external gov mode to work.
The ikon has full control of my esc.
XLPower 520 - Spirit
XK K110 - BLheli
TX: Fr-Sky X9 Lite
P.I.Engineer is online now        Reply With Quote Quick reply to this message
Old 02-07-2015, 10:53 AM   #203 (permalink)
Originally Posted by OnTheSnap View Post
Thanks for the kind words! Well my hobby plate is insanely full right now with interesting stuff on the R&D side of the world (not to mention an unhealthy obsession with pushing my flying). Lots of stuff going on, so I'm running away from any extra load. Maybe in a month or so when I can get out from under it I would consider it. But perhaps Chris or Mike would consider it if they have the bandwidth.
I will be happy to try to get something up on youtube showing the new features..
This is my first full weekend off work in a while and this would be an awesome little project for these.next two days to get my self back into the swing of things.
I will do my best to have something up by Sunday night.
I don't have that smooth radio voice like Deater or the electric outgoing personality of Pinion (John Johnson) but I will give it my best
Sent from my SAMSUNG-SM-N900A using Tapatalk
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote Quick reply to this message
Old 02-07-2015, 01:54 PM   #204 (permalink)
Weather let up and got a chance to try new software today.
Initial impressions on an old timer 3D set-up on a Protos 500, YGE 60, MSH Motor, 14 tooth pinion, 430 blades. 2200 & 1880 head speeds.
Cyclic felt good on new default settings with just the rotation rate turned down a touch. Cyclic possibly felt more predictable and consistent than previous version, but no back to back so cant be sure. Tail was pretty well sorted before and kept same settings. Never liked Pitch boost on other systems but this one felt good (predictable!). Very helpful with lower head speed set-ups.
The Governor.... Tried the previous version and for me, it worked well for on load manouvers, but I did not like it when off-loaded. For same set-up, previous version was however very close to V-Bar governor in that they both seemed to suffer same advantages and disadvantages. The new Gov software feels like a step up. It was very smooth, very consistent and very reactive to on or off loads. Early days, but (on my set-up) I would say as smooth and well behaved as a Kontronic Jive, but holds RPM a lot better. Impressive work!
RussD.
RussD is offline        Reply With Quote Quick reply to this message
Old 02-07-2015, 02:49 PM   #205 (permalink)
Defintely 2 thumbs up on the governor. Fantasic work done there. Working really well on my 700 electric. Also hit the size to load new defaults. Working well on both my 700 e and n models.
Old 02-07-2015, 06:27 PM   #206 (permalink)
Tried out the new firmware on both my 480xx and E5s today and I liked it quite a bit. I need to work on the tail gains again as it seemed to be a bit soft in the wind with the new FW. Otherwise everything flew nicely and the gov was way better doing on-off-on load type maneuvers. I did have one issue:
BUG REPORT:
On the E5s, my second flight of the day I powered up (2S flight pack) and went through my preflight and the tail refused to go past the middle of it's travel. It init'd to the center and then simply would not go further to the tail hub side but worked normally going towards the tail box side. Also trying to get extension by moving the heli around in HH mode would not get the slider past the center.
It's like the half the tail endpoints got set to 0. I did try pushing on the tail servo arm to see if I could get it to go past center and it resisted me when powered up. I powered it down and the tail servo was smooth and had full travel.
I unplugged the power and plugged in again and I had full travel again and the ikon behaved normally and worked fine for the other 4 flights I did.
Let me know if you guys need any details or logs(if there are any). This could have ended badly if I hadn't done my control surface check and noticed this issue.
Synergy E5s 12S!
Minicopter Diabolo 550
Mikado 480 eXXtreme
GauiX3 350mm 6S
TucsonFlyer is offline        Reply With Quote Quick reply to this message
Old 02-08-2015, 09:38 AM   #207 (permalink)
Default Playing in the garden
Try out the new Firmware with my HD500 cell.
Very stable governor mode with mezon 120rpm and turnado v3 Motor
Tail is much mor stable as before, perhaps the governor improvement.
I'm really glad to get the new Firmware Thanks.
Was damned cold here in german, so i tried it only in my neighbours garden.
@ onTheSnap, do you have a mtr file for your HD500 to be able to compare your file with mine ???
Would be great if possible, if not doesn't matter.
Regards
Marco
marco@lottacustoms is offline        Reply With Quote Quick reply to this message
Old 02-08-2015, 01:11 PM   #208 (permalink)
Regards
Marco
Hi Marco,
That is an awesome pic!!!
I haven't flown a Cell for over a year. I plan on trying one again some day though. (-:
Xpert
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 03:52 AM   #209 (permalink)
Hi, any news about android app ?
TNX
mezanu is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 08:27 AM   #210 (permalink)
If I use multitrotor ESC, which is 400Hz, is it better for iKON gov than other ESC???
ddhuans is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 04:22 PM   #211 (permalink)
When you say you are running collective precomp in the Gov settings @ 30, Are you referring to the common menu in advanced under Pitch Precomp or Cyclic precomp or Both? I
fletch3d is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 04:35 PM   #212 (permalink)
I run 30 on collective, 20 on cyclic and 5 on tail on my 700 electric. Works great... And yes these advanced menu common governor gains.
Old 02-10-2015, 04:36 PM   #213 (permalink)
Tested my goblin 700c some days ago with the new firmware, awsome improvment on the governer, nice work, pitch pump is fun!
Goblin 570 - vBar Neo | Trex 700 V3 - vBar Silverline | Trex 500 DFC Pro - vBar Mini | vBar Control
JonasNyman is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 04:38 PM   #214 (permalink)
What would be the sane precompensation values for a 450? I set the collective precompensation to 50 just to see how it works, and got an involuntary autorotation on my next flight - I wonder if it could have contributed.
DX6i, Jeti DS-16
MCPX BL, Mini Protos 6S, Stingray 500, SG704 post-maiden tuneup, SG381 in the making
Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik
Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition
madeye is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 04:42 PM   #215 (permalink)
Awesome.. Thank you for the clarification
Old 02-11-2015, 04:12 PM   #216 (permalink)
got some flights in today.
It's good. Good job OTS and Highfreq. Gov felt good. Did you do any tail stuff? My piro's were flatter and more consistent with my X3. But they may also be that i made sure i was at 10 degree cyclic.
thanks again.
XK K110 - BLheli
TX: Fr-Sky X9 Lite
Old 02-11-2015, 04:22 PM   #217 (permalink)
thanks again.
Thanks! It was a ton of work, but I appreciate that others see the results.
The gov feed forward and other major parts of the gov were complete re-writes of code. The new gov is far better in terms of minimal impact to the tail.
There is also tail drag compensation. So during piro pogos for example the heli stays much flatter.
Xpert
Old 02-11-2015, 05:05 PM   #218 (permalink)
OTS. When is ready the Android app?
Align 800e PRO DFC // KRAKEN Yellow // Align 700N DFC, 105HZ-R HV // Goblin 700Comp // 2x Goblin 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 02-11-2015, 07:36 PM   #219 (permalink)
I'm not the one doing the work. (-: But hear it should be inside a week. Please don't quote me if I'm wrong.
Xpert
Old 02-11-2015, 07:42 PM   #220 (permalink)
Corrado said another week, but you know how development goes. Things have a way of slowing down the process when least expected.
Dave
Lanman is offline        Reply With Quote Quick reply to this message
