Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree4Likes
Old 02-19-2015, 01:31 AM   #1 (permalink)
Default V Control Nitro Gov Setup Guide
I've been asked a few times about the Vbar control nitro gov setup so thought i'd do a quick summary. I don't profess to be an expert so of course stand happily to be corrected and if anyone can add please do but we've set up quite a few nitro helis now on V Control and V6 all of which the vbar governor is working well so this should be a good starting point.
Go to Model Setup/Gov Mode and select vBar n-governor.
Then go to Nitro Special
Throttle Direct Bank = Bank 1 which gives a 'traditional' normal mode for starting and spooling up etc.
Throttle Idle Poti = Fixed.
Throttle Cut/Glow Switch = Switch of your choice. I like the back left spring switch and have my Switchglow on the click part and Throttle Cut on the spring part. Don't worry about Throttle Cut here as it will just work automatically once the rest is setup.
Go to Gov Setup.
Sensor Config = 1 (magnet or backplate sensor)
Gear Ratio = Self explanatory.
Runup Limit = 10 works good but personal choice.
Min Throttle = Start at 25-30 and adjust as in v5.3, if at 100 the gov won't work though.
Now set they throttle servo low/high in Throttle End Points
You need good mechanical setup here and should end up with numbers between 80-120 (I'm getting between 80-100 on my nitros) bit of trial and error here as you don't get full travel on the servo, it's a known issue and Mikado are looking into it but it's of course possible so stick with it.
Model Setup is now complete so go to Governor.
Set chosen head speeds for banks 1, 2 & 3.
Gov Gain = your choice, 60 has been working well so far though.
Now go to Idle Setup and set the 'global' idle. This is your engine idle for bank 1/ bottom collective and also when in motor off and will probably end up somewhere between 35 - 50. Change this number to get a good idle.
Now go to Governor/Expert/Headspeed Expert/Autorotation
Here you set the engine idle for your Motor Idle or Autorotation which can be a bit higher than the Idle Setup if you wish, again personal choice. This is the idle you'll get when doing an auto in Motor Idle or mid position on the Motor Switch.
Governor/Expert/Gov Expert has the more in depth settings, collective add, cyclic add etc etc = your choice here.
You can go to Model Status/Gov Info/Active and look at the small square to the left , turn your motor by hand to check if the gov sensor is working etc.
On the first start of the day I use Bank 1 with motor switch in Motor Run position, this gives you full control of the throttle for getting some fuel through etc and after that will start the heli in Bank 1/Motor Off but you need a good running motor for this.
Hopefully this will help out but of course chip in if you know a better way or have different settings etc.
George J is offline        Reply With Quote Quick reply to this message
Old 02-19-2015, 03:16 PM   #2 (permalink)
Hey good write up guy
mc20piece is offline        Reply With Quote Quick reply to this message
Old 02-21-2015, 02:43 PM   #3 (permalink)
Excellent and just how I did mine.
OptiFuel TEAM PILOT
busterboy is offline        Reply With Quote Quick reply to this message
Old 02-26-2015, 05:24 AM   #4 (permalink)
on my set up I used the left turn knob to adjust the idle when in bank1 and low stick and when in motor off. This makes it easy when starting a cold motor to set the idle.
joeflash211 likes this.
My name is Paul, and I am a helifreak....
paulmedford is offline        Reply With Quote Quick reply to this message
Old 04-17-2015, 01:32 AM   #5 (permalink)
Throttle Idle Poti in Nitro Special you can assign one of the turn pots here for idle control if you prefer.
Sensor Config in Gov Setup - If you have 1 positive magnet or back plate sensor set 1 but if you had 2 x positive magnets set 2 here etc.
George
Old 05-07-2015, 09:13 AM   #6 (permalink)
My only problem with this write up is how to you kill the engine? If I don't put my global idle on a knob, then how do I shut down the engine when done flying?
If I am missing something simple please feel free to point it out lol. My N7 flies great but I have not been able to use this setup method because the engine doesn't kill in motor off.
Right now I have all of my banks as flight modes and I am using global idle adjust on a knob to start in hold. Motor off shuts the bowl and kills the engine. I would rather use a linear normal mode because the soft start on nitro isn't so soft lol
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 05-07-2015, 01:23 PM   #7 (permalink)
Nevermind i figured it out.. RTFS stupid lol.. I didn't read that the Throttle Cut/Switch Glo switch was CUT LOL
All good and tested 4 flights at lunch today.
Thanks for the great write up!
Old 05-08-2015, 03:07 AM   #8 (permalink)
DOH!!!!!
I was just about to tell you to read the thread again and you figured it out pmsl..
OptiFuel TEAM PILOT
Old 05-08-2015, 03:51 PM   #9 (permalink)
Ha ha, glad you got it sorted Chris and pretty sure Tim above would've put you straight anyway!!
George
Old 06-14-2015, 11:32 AM   #10 (permalink)
I don't have a throttle idle poti selection available on my nitro special screen. I only show direct bank and cut switch. No glow swith either. Do I need to make a change somewhere else to get these options?
dbcaster is offline        Reply With Quote Quick reply to this message
Old 06-15-2015, 04:19 AM   #11 (permalink)
I take it this is on a Neo and v6.1? You need to have Pro and the Macrocell app installed as setting up the glow switch is now done in Macrocells where you can assign pretty much anything.
See here at the bottom of the page..... http://www.vstabi.info/en/node/1949
George
Old 06-15-2015, 09:11 AM   #12 (permalink)
It is a Neo with 6.1. I'm not using a switch glo so no problem there. I would like a way to use a poti for idle adjustment though.
Old 06-15-2015, 05:36 PM   #13 (permalink)
I don't really know why you would want to do that though, if you choose Bank 1 in Throttle Direct Bank you will effectively have a trditional 'normal' mode on Bank 1 and get direct control of the throttle for starting and spooling up etc.
George
Old 06-15-2015, 06:38 PM   #14 (permalink)
That's the direction I have gone. That just cuts me down to two fliable banks but it will work.
Old 07-16-2015, 09:28 PM   #15 (permalink)
In my Vcontrol/Neo 6.1 (pro with macrocells loaded) system, I'm not finding/seeing the options to set:
These would be very useful setting to change on my N7. Does anyone know how to get these options to appear, have a missed loading a piece of software?
Bryan
UPDATE: I found this missing software, I needed to install some other Vstabi "Pro" options. Working great now!
datatools is offline        Reply With Quote Quick reply to this message
Old 09-09-2015, 03:49 PM   #16 (permalink)
HOW CAN I SET MY THROTTLE IN ( NORMAL MODE) IT SEEMS TO GO 3/4 THROTTLE BEFOR IM AT MID STICK HOW DO I ADJUSTT THIS SO IT WONT GO TO FULL THOTTLE IN BANK ONE. LIKE A THROTTLE CURVE I DID TAKE OUT SOME COLLECTIVE UNDER MID STICK I HAVE NOT STARTED IT YET
IM STILL DOING SET UP
Chris ryan is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 07:05 PM   #17 (permalink)
did you calibrate your radio
T-bone-1 is offline        Reply With Quote Quick reply to this message
Old 11-18-2015, 08:24 AM   #18 (permalink)
I would like to thank the OP for making this thread, and the staff for making it a sticky. this was a great help! one of the most aggravating things about changing radios is relearning the programming. this made it fairly easy, other than the switch glow (that could use a little more detail). thanks guys!
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 11-18-2015, 09:06 AM   #19 (permalink)
I need to add the 'how to' for setting up the glow switch with the Neo as that's different again and you need to use the Macrocells app which takes a bit of getting your head round. Have helped a couple of people over the phone set up their glow switches as needed mine in front of me to remember how I did it!
Anyway I'm glad this thread has helped so many people, it was worth the effort.
George
Old 11-18-2015, 09:11 AM   #20 (permalink)
Even with bank 1 selected as the direct throttle bank you don't really get a traditional normal mode so you kind of need to forget what you are used to. What it will give you is a linear style throttle bank so that you can get fuel through the engine at the beginning of the day and to start the heli whilst having control of the throttle. Bank 1 really is only for this and spooling up and once spooled up flick into one of the other banks and go fly.
There is no way of limiting the amount of throttle you get when set up like this but it does work fine but maybe not what people are used to.
George
