Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support |
#21 (permalink) |
![]() "Now go to Governor/Expert/Headspeed Expert/Autorotation
Here you set the engine idle for your Motor Idle or Autorotation which can be a bit higher than the Idle Setup if you wish, again personal choice. This is the idle you'll get when doing an auto in Motor Idle or mid position on the Motor Switch." Everything worked exactly as you described, but the above. Is this a percentage? How do I verify this is working . I increase the percentage to alot, but dont see an servo movement . Also, what is the purpose of the motor off, motor idle,motor run. I thought I would be able to set up the motor off as the kill switch. Motor idle as idle and motor run for turning on the bank switch. That seems to make the most sense to me. |
#22 (permalink) | |
![]() Join Date: Feb 2012
![]() Quote:
The motor switch......you really have to forget all you've learnt on a traditional TX as its a bit different with V Control. Motor Off - means either your engine will be at idle or electric motor will be off. Motor Idle - is like a second hold if you like but when you auto this will give you a faster spool up if you have to bailout of the auto, assuming you have a electric/nitro bailout available and if not it will be hold. Motor Run - flick into motor run and your engine/motor will do whatever you have selected on the Bank switch.
George ![]() |
#23 (permalink) |
![]() Cool. Thanks for the tips on the autorotation bailout. I just ran the motor 1 tank on the ground. Next weekend, I will get it into the air.
Dont get me wrong. I love the vcontrol and how it operates. I even love the way they want me to think motor off means idle and motor idle means something else. Lol |
#24 (permalink) |
![]() Just new names for normal TX functions.
Motor OFF = Elec motor off, Nitro motor ground IDLE Motor IDLE= Elec motor in bail out, Nitro motor in flight IDLE (% added to ground idle) Motor RUN= obviously RUN for flying and banked values. Normal radios had CUT, HOLD and IDLE UPS, so CUT= SAFETY SWITCH on VC HOLD= IDLE on VC IDLE UP= BANKS on VC
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks ![]() |
#25 (permalink) | |
![]() Quote:
Team Only Fine Helis |
#26 (permalink) | |
![]() Quote:
![]() You have done something different to end up with that set up. Have a look at my guide at the beginning of this thread, I'd be interested to know what you did differently.
George ![]() |
#27 (permalink) |
![]() Out of curiosity are you running the neo or the older vbars? I'm using neos on all my nitros
#28 (permalink) |
![]() I'm running Neo's now but the only real difference is how you set up the glow switch through Macrocells.
George ![]() |
#29 (permalink) |
![]() So I run throttle cut = motor switch, and I don't have macrocells set up because I don't run a switch glo. Other than that I think my setup is the same.
I usually start by going to idle setup and tweaking one of the knobs (been too lazy to set it up more permanently, lol) then putting motor switch to idle position. Boost idle with the knob, start motor, drop to proper idle and go.
#30 (permalink) | |
![]() Quote:
George ![]() |
#31 (permalink) |
![]() Hello,
Maybe someone can help me understand the throttle cut set up a little better since this is my first nitro its all new to me. This set up guide was a giant help I must say. I'm using a Vcontrol with the neo and mikado's newest software. As soon as I adjust my global throttle up to attain a good idle in the direct bank it also raises the throttle cut setting. so all subsequent flights I have no way to shut the motor off unless I turn the idle down or pinch the fuel line. It doesnt matter if I'm in direct, bank 2 or bank 3. My throttle cut is dependant on my idle setting. If i raise the idle the cut raises and if I lower the idle the cut also lowers. If I make the throttle cut work (shut the engine off) then my heli won't idle at minimum stick. Or is that asking for too much? How do I get a good idle at min stick with a true throttle cut/engine off? Is that possible and I'm just missing or overlooking something? Thanks for the help |
#32 (permalink) |
![]() I followed this tutorial but still struggling a bit. I would like to use the back right spring loaded switch as the Throttle hold switch. I can't figure out how to set it so when the switch is all the way back its in regular flight mode and when clicked to the middle position it gives throttle hold. I wouldn't need the spring loaded setting and could disable it. I have it working now so when flipped to the back position it goes to throttle hold and mid its in regular flight setting. Can I reverse this so it operates like my two other TX?
Thx
Team Heliproz Align 450L, 500 Pro, 600 pro, 700e, 700n Goblin 630, Blade 180 cfx |
#33 (permalink) |
![]() If you go into the switch settings in the tx you can reverse the switch that should take care of it.
#34 (permalink) |
![]() When I reverse it changes from the A/B to B/C making the center and the spring loaded the two setting. So then I'd have to hold the switch forward to maintain throttle hold? Is there a way to reverse the A/B part of the 3 way switch?
#35 (permalink) | |
![]() Quote:
George ![]() |
#36 (permalink) |
![]() Thanks, I opened the case and turned the switch 180 and now the direction for TH hold work as expected. Now to figure the rest of it out...
#37 (permalink) |
![]() Whoops that didn't work.. Instead I opened the case and rotated the sprung loaded switch back 180 to where it started. To reverse the switch to make it work like my JR Throttle hold switches I swapped the outside wires in the switch's JST connector. Now when the switch is all the way back it is in flying position, click it once forward and it goes to idle, the one you set in Governor>Expert>Headspeed Expert>Autorotation.
Never would have figured this out without this thread!
#38 (permalink) |
![]() I have my run, hold, and off on the left rear switch. I replaced the spring loaded switch with a Futaba long three position non spring loaded switch. Just another option.
#39 (permalink) | |
![]() Copied from the main thread.
#40 (permalink) | |
![]() Quote:
It is not clear to me what is the "Min Throttle" parameter Someone can explain it with other words TIA ![]()
Align 800e PRO DFC // KRAKEN Yellow // Align 700N DFC, 105HZ-R HV // RAW Yellow // 2x Goblin 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo |
