Go Back   HeliFreak > Multi Rotor Support > Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Open Source Flight Controllers (CC3D, Ardupilot, etc.) Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Old 02-24-2015, 11:45 AM   #1 (permalink)
Default Spektrum satellite with Naze32/flip32 and Cleanflight (How to)
It wasn't intuitive at all on what needs to be done to get naze32 (or flip32) to work with a sat using Cleanflight, and I wasn't able to find a single article that had everything in it, so I decided to create a new thread here.
1) Instead of connecting the signal (gray) wire to the 3-pin sat connector (available on flip32) you need to connect it to the signal pin of input channel 4.
2) Connect sat ground to any ground (ground on 3-pin sat connector on flip32 works).
3) Connect sat V to 3V out (V on 3-pin sat connector on flip32).
4) In Ports tab, set UART2 to Serial RX.
5) In Configuration tab, set the receiver mode to RX_SERIAL.
6) Use 1024 for DMS2 and 2048 for DMSX.
7) In the Receiver tab, map channels to TAER1234.
(There were a few sources for these tips, some from http://forum.flitetest.com/showthrea...e-reciever-fix).
Let me know if anything here is not clear enough, or if some steps are not really needed. Good luck!
mba83 is offline        Reply With Quote Quick reply to this message
Old 02-24-2015, 01:27 PM   #2 (permalink)
HF MR Support
Thank you for posting!
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 02-25-2015, 03:51 PM   #3 (permalink)
Good job, mba!
I might change out my Orange 6-ch DSMX single-line PPM RX to Spektrum Sat Rx (or Orange sat Rx if compatible) for the extra 2 AUX channels and lower weight. This info will save me lots of head-scratching time.
Old 02-25-2015, 05:31 PM   #4 (permalink)
I'm not doing a sat. I used an AR8000 with an external sat (I like diversity). But what amazed me was how easy it was to eat up 8 channels on a 250 quad with the Naze.
1. Throttle
2. Aileron
3. Elevator
4. Rudder
5. Flight Mode
6. Auto-tune
7. Arm/Disarm
8. Buzzer
After my experiences with auto-tune I guess I'll probably ditch that one, so I may have one spare for something like controlling LEDs or whatnot.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 04-10-2015, 07:28 AM   #5 (permalink)
By chance I find your post, thanks so much !
For the rookies like me I would add that each modification in a Cleanflight GUI page must be "saved" before stepping to next page.
Right now I am using Flip32 v2.3_OEM_RTF and I connected the spektrum satellite with a level converter cable, directly to RC4.
And for binding you also must go to CLI to enter:
set spektrum_sat_bind = <value>
save
where <value> is:
3 for DSM2 1024/22ms
5 for DSM2 2048/11ms
7 for DSMX 22ms
9 for DSMX 11ms
after reboot, the satellite will blink showing binding mode.
NicoV is offline        Reply With Quote Quick reply to this message
Old 04-27-2015, 11:58 PM   #6 (permalink)
Thank You mba83! This thread was the exact information i needed .
-Kevin
wsntme is offline        Reply With Quote Quick reply to this message
Old 04-28-2015, 12:10 AM   #7 (permalink)
Old 05-06-2015, 10:39 PM   #8 (permalink)
I've tried all of the above for hours and can't get my Spektrum satellite to enter bind mode.
I have the 9645 remote receiver if that makes any difference. Does anyone know how to get this to work? Soooo frustrating.
Cyclic-Psycho is offline        Reply With Quote Quick reply to this message
Old 05-07-2015, 11:29 AM   #9 (permalink)
Just kidding. I spent two hours doing this, but never typed "save". Oops.
Old 05-07-2015, 11:43 AM   #10 (permalink)
Just kidding again. I typed save and still nothing.
Old 05-07-2015, 12:43 PM   #11 (permalink)
This stuff is not very intuitive - sorry can't help with your specific case.
But when you figure it out, please post your solution here, in case it will help someone else in the future.
Old 05-08-2015, 10:38 AM   #12 (permalink)
HF MR Support
I went ahead and made this a sticky, since it sounds like the kind of question that many might ask. Including me, since I'm thinking of using a spare Spektrum satellite RX I have laying around for my new Aerial Freaks Mojo that comes with a Naze32 and a cord already to go with a satellite. Thanks to the OP for sharing!
3 years cancer free! Woot!! ~ Cancer can kiss my grits! Ainokea!
If you never crash, you're not having enough fun!
Pilot, Team Lavaquad
Big Island Guy is offline        Reply With Quote Quick reply to this message
Old 05-09-2015, 06:54 PM   #13 (permalink)
Smile
Thanks guys! This thread just saved me a bunch of work!!!
rcflyair is offline        Reply With Quote Quick reply to this message
Old 05-09-2015, 06:55 PM   #14 (permalink)
Old 05-11-2015, 09:15 PM   #15 (permalink)
Ok I solved my problem...kind of...
I had to connect my satellite receiver to the AR7200BX on my Blade 450x and re-bind to my dx6. Then I connected the satellite to my 250 quad with the flip32+ a described above and the magic happened.
Sadly I could not get it to bind just through the software, I had to use my available hardware (Blade 450X) to do it, BUT I got it to work!
I wasn't aware of the satellite port on the AR7200BX as it is hiding a bit, but it's there.
Thanks everybody!
Old 05-12-2015, 09:01 AM   #16 (permalink)
Default problem
hi,
I have a problem with my spectrum satelit on the flip32.
I proceeded exactly according to the instructions above. but when i connect the flip ti my computer, cleanflight shows for every chanel 988.
Here are two photos:
http://fpv-community.de/attachment.p...7&d=1431437962
http://fpv-community.de/attachment.p...8&d=1431437976
I have bound the satellite with another receiver to my dx18. the LED is on
what can I do?
thanks
skdjonas is offline        Reply With Quote Quick reply to this message
Old 05-14-2015, 12:20 AM   #17 (permalink)
Default thanks for posting
great posting.
however can anyone add an idiots guide to adding GPS with the spektrum sat setup please?
Pete
130X,,130X Redbull, 300cfx, Trex 450V2, Trex Dominator 6S, Trex 500 Seahawk
Petebarrow is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 11:49 AM   #18 (permalink)
EXCELLENT!!!
Within 30 seconds of finding this post I was up and running. Thank you
Blade Nano cpx (stock)
Trex 150 (various Lynx upgrades)
Some planks (more than I care to admit)
Rotor_Freak_RC is offline        Reply With Quote Quick reply to this message
Old 07-07-2015, 07:38 PM   #19 (permalink)
Default Why? LOL
Why couldn't I have found this before I spent 6 hours figuring it out! LOL I got it but it was not straight forward at all.
69maverick is offline        Reply With Quote Quick reply to this message
Old 07-07-2015, 11:31 PM   #20 (permalink)
Cyclic P. That is the proper way to bind it. Even the Real Naze32 does it like that.
