My Heliartist UH 60 500 size project - Page 3 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Scale Projects <790
Scale Projects <790 Scale Projects <790 Discussion
Old 05-10-2016, 07:46 PM   #41 (permalink)
Location: St-Julie Québec Canada and Isle La Motte Vermont USA
Originally Posted by mloo123 View Post
Hi Windmanquebec,
Im currently starting my new project on 500size apache. Thinking of getting the carbonhobby scale blades like yours. May I ask are they of good quality?
Currently im using some unbranded CF blade (wide chord) and have difficulty in balancing and tracking them causing much vibrations ( the microbeast seems dun like it). So wanna changed them out with either the Align 420D or the carbonhobby scale blades.
Also like to ask is the Beastx doing fine for your heli? Mine drifts during hovering (probably due to vibes) but headlock is good. Have read somewhere the beastx not suited for scale...
Martin
Sorry been busy lately.
To answer your question Yes I found those blades to be good quality for has much as I know. They balanced perfectly, If I remember they where sentas a set with close weight. I didn't have to add any tape for balancing, they did balanced perfectly as is.
SYMA S-107/BLADE (2)450 3D FBL/ALIGN(3)T-REX 500 (2)T-REX 550 T-REX 700L V2/DX8
SCALE
MD500(450) UH-60/AS350/BO105(500) A109(600)
Windmanquebec is offline        Reply With Quote Quick reply to this message
Old 05-18-2016, 06:58 AM   #42 (permalink)
very nice work!! It is looking good!
Roy Mayoral
heli143 is offline        Reply With Quote Quick reply to this message
Old 12-31-2016, 12:59 PM   #43 (permalink)
Didn't had time to play too much with y helico's this summer. I bought a boat and was on the water all season.
back to the build...I'm in the process of installing the mechanic inside the fuselage. I had some delrin made of to hold the mechanic inside...the provided plastic one where aged...breaking in peace.
My question is now I want to balance the heavy tail. I put the helico on 2 chairs holding by the blades and I measured the distance between the front wheels to the ground. I added some weight on the nose to have the same distance to the floor for the tail wheel.
I figured that I need 10 oz the make it perfect.
Is that too much...I mean, do it need to be perfectly balance?
Can I save some weight and have a bit of a heavy tail?
Just did not installed the 4 blades for weight since front weight will be equal to rear weight
SCALE
Old 12-31-2016, 11:55 PM   #44 (permalink)
HF Scale Support
Just a short note on the attitude of the Blackhawk. It hovers tail down, not level. What you need to do is balance the helicopter (not by the blades but by the tips of the blade bolts) so that the main gear is level to the ground. No matter how much you need to add (battery placement helps reduce dead weight like lead for instance), you need to have the main gear level or the main shaft perpendicular to the ground, not by the body. Hope this helps and it does look good.
Don
Old 01-01-2017, 11:34 AM   #45 (permalink)
thanks
SCALE
Old 01-01-2017, 12:15 PM   #46 (permalink)
I made the exercise as you said:
I put a level on the main gear(engine gear not landing gear)
I lift the helicopter with my fingers on the main rotor blade bolt nut (underneath the grip). I added weight on the nose till I got my main gear level. Still need 11.1 oz.
But with the weight in place when I lower the helicopter to the ground the main landing wheel touch the ground with the tail wheel still about 1/4 inch in the air...meaning that the attitude of the helicopter is nose slightly down...not the other way around like you suggest.
But yes when I look at a video of a Black hawk landing it is like you said...tail first
UH-60M Black Hawk Helicopter Landing At Wayland Expo 10/01/2011 (2 min 44 sec)
If I put no weight on the nose It has more likely the attitude of the real one???
What you should I do?....no weight?
SCALE
Old 01-01-2017, 02:07 PM   #47 (permalink)
HF Scale Support
Yes, the balance is needed as when you make it so that the model hovers as the original, it will fly like a sack of hammers. There are two things to try. One, balance so the gear is level to the ground and fly it, the second is to raise the mechanics (if you can) so that when the main gear is level, the tail drops towards the ground. A tail heavy helicopter is an ugly thing to attempt to fly and in many cases, the helicopter handles bad enough to crash at the slightest bit of inattention. Hope this helps.
Don
Old 01-01-2017, 03:00 PM   #48 (permalink)
OK I will go for the balance and will see how it fly.
Thanks for the fast answer
SCALE
Old 01-04-2017, 01:35 AM   #49 (permalink)
In process of adding weight in the nose. I ordered a scale plastic tail gear case. I have the pro aluminum case now...it will remove a bit of weight on the tail and as it is far it should be noticeable on what I have the put in the nose. On the 11.1 Oz I figured I need in the nose I already put close to 9 oz using lead tape under the scale cockpit
ID:	686964   Click image for larger version
SCALE
Old 01-06-2017, 03:15 PM   #50 (permalink)
Waiting for my scale plastic tail case.
Installed stickers
ID:	687401   Click image for larger version
ID:	687403   Click image for larger version
ID:	687405   Click image for larger version
ID:	687406   Click image for larger version
SCALE
Old 01-07-2017, 05:38 AM   #51 (permalink)
Somehow that US Navy sign with USAF sticker on the tail just does not look the part. Also the stickers are really glossy.
I would consider painting the signs myself
Gh
goodhunting is offline        Reply With Quote Quick reply to this message
Old 01-07-2017, 12:07 PM   #52 (permalink)
It's a Budget helicopter share by the USAF and the NAVY
SCALE
Old 01-08-2017, 03:03 AM   #53 (permalink)
Don't forget US Army on the weapons - it is a real hybrid, and has the Blackhawk tail wheel as well, not Seahawk
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 01-08-2017, 06:47 AM   #54 (permalink)
damn budget cuts......
Old 01-18-2017, 02:59 PM   #55 (permalink)
Damn. ..the plastic tail case weight exactly the same weight than the metal pro one(32 gr)...I will use it anyway...It look like it will fit better in the tail fuselage
SCALE
Old 03-12-2017, 04:33 PM   #56 (permalink)
Ordered a 4 blades tail rotor from cnchelicopter
http://www.cnchelicopter.com/trex-50...l-grips-combo/
Not align quality but OK. I found that the slider had a defect of assembly...probably the sleeve was not installed properly and induced a movement that I didn't like. I contact cnchelicopter and they are sending me another slider.
http://www.dailymotion.com/video/x5e...ze-faster_tech
SCALE
Old 03-12-2017, 05:22 PM   #57 (permalink)
I finalized the weight balance with the new 4 blade rotor. Installed the cockpit and mechanic in.
Use 3m 4011 tape to secure pilots
first used seam of epoxy to secure dash, but after changed with 3m tape
ID:	698474   Click image for larger version
ID:	698475   Click image for larger version
ID:	698476   Click image for larger version
ID:	698479   Click image for larger version
ID:	698481   Click image for larger version
ID:	698482   Click image for larger version
ID:	698483   Click image for larger version
ID:	698484   Click image for larger version
SCALE
Old 03-12-2017, 05:25 PM   #58 (permalink)
Lighting with mechanic installed
http://www.dailymotion.com/video/x5e...-lighting_tech
SCALE
Old 03-12-2017, 05:48 PM   #59 (permalink)
First run-up with mechanic in the frame
http://www.dailymotion.com/video/x5e...-up-uh-60_tech
SCALE
Old 04-05-2017, 11:09 AM   #60 (permalink)
Received the new CNCHelicopter pitch slidder
Now the sleeve is properlly installed but the inside diameter is way too big I have like 0.0095 to 0.0185" clearance on diameter...as opposed to 0.0015" on align part. contact Jeff at xmhobbies...he is looking after that....
SCALE
Human Verification
