Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
#1 (permalink) |
![]() Brand new set of Support Braces, u guys see whats wrong,,
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503 600ESP : 100AMP Castle. Scorpion Motor . AMA #962896 400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X. |
#2 (permalink) |
![]() One side of the ends are not turned to the side?
"In my opinion, the M1 rifle is the greatest battle implement ever devised"
- General George S. Patton, Jr. |
#3 (permalink) |
![]() Join Date: Apr 2008
![]() ding ding,,,sum bicches,lol...,
#4 (permalink) |
![]() the end pieces can't be turned by hand? Or maybe hold each end with some pliers and give a twist. If all else fails maybe the LHS will replace them for you
#5 (permalink) |
![]() Ya I'm gonna crunch around the ends and see if they come apart,,then epoxy back.hobby store is to far ,not worth the gas.
#6 (permalink) |
![]() worked perfect and allready epoxied back together..figured it would be no different then shortening the tail push rod..
#7 (permalink) |
![]() Did you heat up the linkage?
Blade 400, DS35000G,GY520, DS287MGs on cyclic, CC BEC Blade MSR Blade MCX |
#8 (permalink) |
![]() No,,I just took a pair of plyers and sqweezed all around it till it broke loose..then just re epoxied.
#9 (permalink) |
![]() One thing I've noticed too is that I had 1 left over from a crash & I found it was shorter than the other ones
#10 (permalink) |
![]() That aint nothing! The set I bought way back when with the aluminim ends were not the same length! Not even close. so I had to twist of the ends and cut the rods to the same length and epoxy them back on. I epoxy them with slow stuff and bolt every thing up and let it cure. I would rather do it that way from the start.
#11 (permalink) | |
![]() Quote:
Happy Thanksgiving all.
